The Arduino Journey
What did you do with your Arduino today? It would be nice to hear where like-minded people are at.
For my part, I am in a waiting pattern for an Arduino Zero to arrive so that I can begin to experiment with the debug potential of the new IDE 2.0. From Ted, Lake City, Michigan, USA.
Your topic has been moved to a more suitable location on the forum.
I just woke up so haven't done anything yet today :smiley:
I mostly use it to improve my non-existing C++ skills and help people on the forum.
I hooked up an old UNO to my Win 11 box just to make certain that my memory from 2012 was correct about something I had written in the forum.
Ray
Atlanta, Ga
I played with some 700 ohm ferrite beads to remove power switching noise from a Pro Mini project.
Building piece parts from next project on 3d printer.
Nylon standoffs are EXPENSIVE, especially when you have to buy 100 minimum! My projects use a couple dozen each.
To: sterretje -- Thanks for moving this to a better location. I appreciate your help because this was the first new topic I had written and I was uncertain as to where to place it.
Trying to finish a merge/port of 2 arduino mega programs to an Adafruit PyGamer and adding a Adafruit Arcada user interface. Arcada is a PITA! Almost there.
Today, Aug 25, 2022, I soldered 2 LEDs, resistors, and a pushbutton to a protoshield for my Arduino Uno. I should try to figure out how to add a picture. My idea is to end up with something like Basic Stamp 2's homework board, but for my Arduino.
To: LarryD and madmark2150 -- very nice pictures that you included with your replies!
Well, with my Arduino IDE, I have just got a GPS tracker for the ESP32CAM working.
The ESP32CAM reads the GPS sends its location, saves a picture to SD, then transmits the picture to an Arduino DUE which is saved on SD. Uses LoRa.
