HI I've been trying to use the variable function in arduino lot cloud and there have been errors in the sketch to initialize the actual arduino cloud can someone help me here's the code:
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/34e733c9-8f26-4421-8678-c07fcd855920
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
- No variables have been created, add cloud variables on the Thing Setup page
to see them declared here
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
/usr/local/bin/arduino-cli compile --fqbn arduino:avr:mega:cpu=atmega2560 --build-cache-path /tmp --output-dir /tmp/4141019179/build --build-path /tmp/arduino-build-22427CDC28F732843B1EAB1C58D815EE --library /mnt/create-efs/webide/f7/cf/f7cf2c9d73ce35efab2bf2d6ac490142:zm476/libraries_v2/DS1307RTC --library /mnt/create-efs/webide/f7/cf/f7cf2c9d73ce35efab2bf2d6ac490142:zm476/libraries_v2/HCSR04 ultrasonic sensor --library /mnt/create-efs/webide/f7/cf/f7cf2c9d73ce35efab2bf2d6ac490142:zm476/libraries_v2/Servo /tmp/4141019179/Untitled_aug04a
WARNING: library ArduinoIoTCloud claims to run on mbed, samd, esp8266, mbed_nano, mbed_portenta, mbed_nicla, esp32, mbed_opta, mbed_giga, renesas_portenta, renesas_uno architecture(s) and may be incompatible with your current board which runs on avr architecture(s).
WARNING: library Arduino_ConnectionHandler claims to run on samd, esp32, esp8266, mbed, megaavr, mbed_nano, mbed_portenta, mbed_nicla, mbed_opta, mbed_giga, renesas_portenta, renesas_uno architecture(s) and may be incompatible with your current board which runs on avr architecture(s).
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino: In function 'void setup()':
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino:31:3: error: 'ArduinoCloud' was not declared in this scope
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino:31:3: note: suggested alternative: 'Arduino_h'
Arduino_h
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino:31:22: error: 'ArduinoIoTPreferredConnection' was not declared in this scope
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino: In function 'void loop()':
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino:45:3: error: 'ArduinoCloud' was not declared in this scope
/tmp/4141019179/Untitled_aug04a/Untitled_aug04a.ino:45:3: note: suggested alternative: 'Arduino_h'
Arduino_h
Error during build: exit status 1
