The Backlight properties of the Grove RGB LCD Backlight simply not working
A while ago I bought a Grove RGB Backlight LCD from the official Seeed Store, and right away I had problems with setting up the RGB Backlight. I'm using the V5.0 LCD, with the text output working "as advertised" and strangely enough after running this I2C Diagnostic Code:
#include <Wire.h>
  Serial.begin (115200); //*****  make sure serial monitor baud matches *****
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
from this post:
Uno + Grove Shield + Grove LCD RGB Backlight not working.
It shows both of the I2C Addresses for the LCD and it's Backlight (Which is normal):
Found address: 48 (0x30)
Found address: 62 (0x3E)
Done.
Found 2 device(s).
And the code cannot be wrong, because I'm using the Official Library for the device along with the example code snippet.
I'm really confused, and really hope that I wouldn't need to buy another one :confused: .
Thanks in advance for your contributions.
KronTheDev
Have you installed the rgb_lcd library and tried the provided examples?
For everyone out there who has the same problem (Thx: 2112):
DO NOT DOWNLOAD THE LIBRARY FROM THE ARDUINO SEARCH LIST!
That version is outdated, and a working version can be found here:
Official 1.0.1 Grove RGB Backlight LCD Library (Download everything directly)
To be specific, the library available in the Arduino Library Manager is not compatible with the V5.0 display. It does work with previous versions
