Hi. First of all, I am not very good in C++ but know the basic of it. I wrote a program sample, where arduino talk to my xig (internet gateway) using xbee.
void loop(void)
// allocate two bytes for to hold a 10-bit analog reading
char payload[] = "http://192.168.1.3/pachube/temp.php?temp=38&feed=6519\r\n";
// payload array lenght needs to be at least one higher than the number of bytes to be transmitted
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx_5001 = Tx16Request(0x1966, (uint8_t*)(payload), strlen(payload));
TxStatusResponse txStatus = TxStatusResponse(); //Check this out.
xbee.send(tx_5001);
delay(5000);
The problem is, I do not know the best way to rewrite above program just to have variables in URL's parse.
Something like this, char payload[] = "http://192.168.1.3/pachube/temp.php?temp=<float value>&feed=<char type>\r\n";
where temp value is a float type (example, temp = ((float)DHT11.temperature,2) .
I am totally no idea how to write and already spend a week just to find a good programming but I faced a lot of errors. Maybe my programming skill is not good enough. So, I really need help, so that my project could forward as plan.
The sprintf() function could do that, except that it doesn't handle floats. The dtrostrf() or dtostre() functions can convert a float to a string, but they don't allow a lot of flexibility in the formatting of the value. Perhaps the default would be good enough, though.
Yes. It can not handle float. So, my next question, if I convert float to string, can I convert it again char? how?
or make everything as a string, append or concat them and finally convert to char?
or I need to rewrite payload type in (Tx16Request(0x1966, (uint8_t*)(payload), strlen(payload));)? I think Tx16Request only except uint8_t*. Am I right?
A string is a NULL terminated array of chars. So, if you convert a float to a string, you have an array of chars. You can't convert a float to a char.
You can convert a string to a float, using atof().
A string is a char array. The strings can be concatenated using strcat(). You can't convert a string (an array of chars) to a char. That would be like trying to put 100 feet in one shoe.
Yes, but you can cast any one byte type (byte, char, unsigned char, signed char, etc.) array to a uint8_t *, using (uint8_t *)in front of the array name.
