chilliman:
Thanks all for the tips ,i shall remember them, is there a right way to add multiple input and out that you what to happen at the same time i.e . what order etc.
thanks chilliman
I write sketches that need to do multiple things responsively as Finite State Machine (please look it up for details as that saves a lot of typing) sketches.
Only one thing happens at a time but what happens can be broken down into small parts that run quickly, in perhaps 100 microseconds or often less to much less and sometimes a bit more.
Those small parts I have execute different sub-tasks; the inputs, outputs and processes; in turn.
One natural separator of sub-tasks is when any one has to wait for the next step it does. In that waiting time other parts of other sub-tasks get done. In as little as 1 millisecond many things may get done. For example, the time between Serial characters arriving can take 1000's of Arduino-cycles of which there are 16,000 per millisecond.
I break up Serial input into pieces that logically follow each other or branch depending on what characters arrive. My method checks each character as it comes in and acts then while some people will collect all the characters and then check and act, but either way is valid.
So if I am looking for user codes that always end with a carriage return (I set up serial monitor to add one to every line, there's a box in the monitor lower-right near the baud rate box) and start with G (for Go) or S (for Stop) and after G expect 3 digits then if the user sends S my code looks for the carriage return to know the command is valid and then the code does the stop action.
If the user sends G then the code goes on to try and collect the 3 digits and carriage return before acting on that input.
Anything else, any input that does not match the pattern is rejected with an error message output back to the user and new input is awaited.
Just to get S then carriage return and do the stop action, I have done in 2 parts. The break is after receiving S since there is a wait time before the next character arrives. If a G is received then there are essentially 5 parts to get G # # # '/r' (carriage return). If the user message starts with neither then my code handles the message as an input error.
I coordinate all these actions by putting the code for each part inside an if() { ... } block or a case block within a switch-case statement. Sometimes I use an else if() { ... } or else { ... } to extend the logic of an if() block.
Each if() or case block checks the value of a variable used to track the process state of that sub-task. If the first character is S, the process would get changed to a different state than if the first character is a G.
Using the state method I can have the code for each part stand alone inside its own block inside of loop() and not inside an if() or while() for some other process. Keeping the parts code separate is key to simpler, easier to change or add-to code.
Side-excursion on -why- you want to keep the parts separate:
A simple example of the other way is code to push a switch and led goes on we have an if ( digitalRead ) for the switch with the digitalWrite to turn the led on inside -- and then more logic to know when to turn the led off. And then of course more actions must be fit in, the levels of nested control statements like if()'s can and usually does get very complicated/messy quickly. Code like that is hard to change except in ways that "go with the grain" of the original idea; that idea changing is what leads to spaghetti code, probably the root of more programming headaches than any other and usually the hallmark of poor to bad management, a think-it-through approach rather than a think-ahead approach. But even using think-ahead and flow-plans, a load of top-down approach nesting generally results in a spaghettified mess.
In the G # # # /r input example, my state 0 will be the 'waiting for input' state. The code block that runs when a character is read and state is 0 will look for S or G, anything else is error. ALWAYS handle errors.
When the 0 state code sees a G it may change state to 2 and sets a variable to put the expected number following G to zero. Then that code is done.
Next time a character is received the state 2 code runs and it is looking for a digit. When it gets the digit, it counts the digit and starts evaluating the expected number entered. Since 3 digits are expected, state stays at 2 and the count of digits is used to track the process of number entry.
Each digit gets turned into a value by subtracting the character '0' ('9' - '0' == 9), the variable for the input number is multiplied by 10 and then the value for the digit just received is added. So for G123, the final number variable goes through 0 x 10 + 1, 1 x 10 + 2, 12 x 10 + 3 = 123.
When the digit count gets to 3 and there's been no errors, the state may be changed to 4 or any other number not used and the code for that state looks for the carriage return to finish the input process then change state to one that runs the G### action part of the sketch.
Any time there is an error, say instead of G### there was G#F, the state should be changed to either a general error state that handles all errors the same way or one with special handling. The next time through loop the error code runs in its own block, you don't need to wedge it into the code where the error was found or find a way out of a loop or other logic except to change the state and return from loop() which... runs loop() again with that state changed!
You can have as many state variables as you want but I caution against too many as you can end up with 'battling states'. It is best to keep a simple plan of what you want the sketch to do and then break the parts down and assign sub-tasks and states until that gets down to code level. Use all the lines of the plan as comments and that will help you immensely with your code.
If you go read up on finite state machines, find and play with some examples before you go making your own then the time you spend doing that will pay off well in time saved learning by mistakes when you don't.
Good luck and remember to take breaks when you get tired, walk away and come back for a fresh look when you get stuck. The logical-focus part of the brain will miss simple things that it has dismissed ("I know that's right") but minutes spent away will usually help clear that block.
See ya when you hit the next big snag but I will expect you to ask more specific questions then.
