The Button2 sketch didn't get enough output
Hi everyone.
The example sketch from button2.h
#include "Button2.h"
#define BUTTON_PIN  2
Button2 button;
  delay(50);
  Serial.println("\n\nButton Demo");
  button.begin(BUTTON_PIN);
  // button.setLongClickTime(1000);
  // button.setDoubleClickTime(400);
  Serial.println(" Longpress Time:\t" + String(button.getLongClickTime()) + "ms");
  Serial.println(" DoubleClick Time:\t" + String(button.getDoubleClickTime()) + "ms");
  // button.setChangedHandler(changed);
  // button.setPressedHandler(pressed);
  button.setReleasedHandler(released);
  // button.setTapHandler(tap);
  button.setClickHandler(click);
  button.setLongClickDetectedHandler(longClickDetected);
  button.setLongClickHandler(longClick);
  button.setDoubleClickHandler(doubleClick);
  button.setTripleClickHandler(tripleClick);
  button.loop();
void pressed(Button2& btn) {
    Serial.println("pressed");
void released(Button2& btn) {
    Serial.print("released: ");
    Serial.println(btn.wasPressedFor());
void changed(Button2& btn) {
    Serial.println("changed");
void click(Button2& btn) {
    Serial.println("click\n");
void longClickDetected(Button2& btn) {
    Serial.println("long click detected");
void longClick(Button2& btn) {
    Serial.println("long click\n");
void doubleClick(Button2& btn) {
    Serial.println("double click\n");
void tripleClick(Button2& btn) {
    Serial.println("triple click\n");
void tap(Button2& btn) {
    Serial.println("tap");
Serial Monitor:
long click detected
released: 1024
long click
it is the output when pressed button once, should it output all void result such as and why didn't:
pressed
released = 1024
changed
click/1
etc....
thanks
Adam
You didn't register a pressed or changed handler so why should it print anything on these events?
Thanks.
I guess it is the point I like to make clear:
What's the different above two voids, why the first one doesn't print, and second one does.
You defined the routines but you didn't register the pressed and changed event callbacks!
YES YES .
Thank you.
Removed the commented out, OK now.
