What do you mean by that? If you are talking about the full code, this is it but I don't think most of it would be necessary to find the cause of the issue:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ezButton.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI 9
#define OLED_CLK 10
#define OLED_DC 11
#define OLED_CS 12
#define OLED_RESET 13
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
ezButton button(2);
int timersec = 0;
int timermin = 0;
int timepertick = 100;
unsigned int mode = 0;
unsigned int disabledmode = 1;
unsigned int temp = 0;
unsigned int timeafter = 0;
const unsigned int width = 128;
const unsigned int height = 64;
float model[] = {1, 0, 0, 0,
0, 1, 0, 0,
0, 0, 1, 0,
0, 0, 0, 1};
float view[]= {1, 0, 0, 0,
0, 1, 0, 0,
0, 0, 1, 2,
0, 0, 0, 1};
float proj[] = {1.2f, 0.0f, 0, 0,
0.0f, 2.4f, 0, 0,
0.0f, 0.0f, 0, 1,
0.0f, 0.0f, 1, 0};
const PROGMEM float vertices[] = {
-0.5f, -0.5f, 0.5f,
-0.5f, 0.5f, 0.5f,
0.5f, 0.5f, 0.5f,
0.5f, 0.5f, 0.5f,
0.5f, -0.5f, 0.5f,
-0.5f, -0.5f, 0.5f,
0.5f, -0.5f, -0.5f,
0.5f, 0.5f, -0.5f,
-0.5f, 0.5f, -0.5f,
-0.5f, 0.5f, -0.5f,
-0.5f, -0.5f, -0.5f,
0.5f, -0.5f, -0.5f,
0.5f, -0.5f, 0.5f,
0.5f, 0.5f, 0.5f,
0.5f, 0.5f, -0.5f,
0.5f, 0.5f, -0.5f,
0.5f, -0.5f, -0.5f,
0.5f, -0.5f, 0.5f,
-0.5f, 0.5f, -0.5f,
-0.5f, 0.5f, 0.5f,
-0.5f, 0.5f, 0.5f,
-0.5f, -0.5f, 0.5f,
-0.5f, 0.5f, 0.5f,
-0.5f, 0.5f, -0.5f,
0.5f, 0.5f, -0.5f,
0.5f, 0.5f, -0.5f,
0.5f, 0.5f, 0.5f,
-0.5f, 0.5f, 0.5f,
0.5f, -0.5f, 0.5f,
0.5f, -0.5f, -0.5f,
-0.5f, -0.5f, 0.5f,
0.5f, -0.5f, 0.5f
unsigned int angle = 0;
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(700);
// Clear the buffer
display.clearDisplay();
display.setCursor(0, 0);
display.setTextColor(WHITE);
display.setTextSize(3);
button.loop();
if(button.isPressed()){
temp = mode;
mode = disabledmode;
disabledmode = temp;
if(mode == 0){
if(timermin < 10){
display.print("0");
display.print(timermin);
display.print(F(":"));
if(timersec < 10){
display.print("0");
display.print(timersec);
display.display();
timeafter = millis();
Serial.println(timeafter);
if(timeafter % timepertick == 0){
timersec++;
Serial.println("Times are changing!");
if(timersec >= 60){
timersec = 0;
timermin++;
if(timepertick < (timerend - timerstart)){
timepertick = timerend - timerstart;
delay(timepertick - (timerend - timerstart));
}else if(mode == 1){
drawtrianglearray(vertices, sizeof(vertices)/sizeof(float));
display.display();
angle += 8;
mat4_rotate(angle, 1, model);
void mat4_mul(float l[16], float r[16], float *out){
out[0] = r[0] * l[0] + r[4] * l[1] + r[8] * l[2] + r[12] * l[3];
out[1] = r[1] * l[0] + r[5] * l[1] + r[9] * l[2] + r[13] * l[3];
out[2] = r[2] * l[0] + r[6] * l[1] + r[10] * l[2] + r[14] * l[3];
out[3] = r[3] * l[0] + r[7] * l[1] + r[11] * l[2] + r[15] * l[3];
out[4] = r[0] * l[4] + r[4] * l[5] + r[8] * l[6] + r[12] * l[7];
out[5] = r[1] * l[4] + r[5] * l[5] + r[9] * l[6] + r[13] * l[7];
out[6] = r[2] * l[4] + r[6] * l[5] + r[10] * l[6] + r[14] * l[7];
out[7] = r[3] * l[4] + r[7] * l[5] + r[11] * l[6] + r[15] * l[7];
out[8] = r[0] * l[8] + r[4] * l[9] + r[8] * l[10] + r[12] * l[11];
out[9] = r[1] * l[8] + r[5] * l[9] + r[9] * l[10] + r[13] * l[11];
out[10] = r[2] * l[8] + r[6] * l[9] + r[10] * l[10] + r[14] * l[11];
out[11] = r[3] * l[8] + r[7] * l[9] + r[11] * l[10] + r[15] * l[11];
out[12] = r[0] * l[12] + r[4] * l[13] + r[8] * l[14] + r[12] * l[15];
out[13] = r[1] * l[12] + r[5] * l[13] + r[9] * l[14] + r[13] * l[15];
out[14] = r[2] * l[12] + r[6] * l[13] + r[10] * l[14] + r[14] * l[15];
out[15] = r[3] * l[12] + r[7] * l[13] + r[11] * l[14] + r[15] * l[15];
void mat4_vec4_mul(float mat[16], float vec[4], float *out){
out[0] = vec[0] * mat[0] + vec[1] * mat[1] + vec[2] * mat[2] + vec[3] * mat[3];
out[1] = vec[0] * mat[4] + vec[1] * mat[5] + vec[2] * mat[6] + vec[3] * mat[7];
out[2] = vec[0] * mat[8] + vec[1] * mat[9] + vec[2] * mat[10] + vec[3] * mat[11];
out[3] = vec[0] * mat[12] + vec[1] * mat[13] + vec[2] * mat[14] + vec[3] * mat[15];
void mat4_rotate(int degrees, unsigned int axis, float *out){
float radians = degrees * (22.0f / 7.0f) / 180.0f;
if(axis == 0){
out[0] = 1.0f;
out[1] = 0.0f;
out[2] = 0.0f;
out[3] = 0.0f;
out[4] = 0.0f;
out[5] = cosf(radians);
out[6] = -sinf(radians);
out[7] = 0.0f;
out[8] = 0.0f;
out[9] = sinf(radians);
out[10] = cosf(radians);
out[11] = 0.0f;
out[12] = 0.0f;
out[13] = 0.0f;
out[14] = 0.0f;
out[15] = 1.0f;
}else if(axis == 1){
out[0] = cosf(radians);
out[1] = 0.0f;
out[2] = sinf(radians);
out[3] = 0.0f;
out[4] = 0.0f;
out[5] = 1.0f;
out[6] = 0.0f;
out[7] = 0.0f;
out[8] = -sinf(radians);
out[9] = 0.0f;
out[11] = 0.0f;
out[12] = 0.0f;
out[13] = 0.0f;
out[14] = 0.0f;
out[15] = 1.0f;
}else if(axis == 2){
out[1] = -sinf(radians);
out[2] = 0.0f;
out[3] = 0.0f;
out[4] = sinf(radians);
out[6] = 0.0f;
out[7] = 0.0f;
out[8] = 0.0f;
out[9] = 0.0f;
out[10] = 1.0f;
out[11] = 0.0f;
out[12] = 0.0f;
out[13] = 0.0f;
out[14] = 0.0f;
out[15] = 1.0f;
int vertexshader(float position[3], float model[16], float view[16], float proj[16], int out[2]){
float int1[4];
float int2[4];
float int3[4];
float int4[4];
float int5[2];
float int6[2];
int3[0] = position[0];
int3[1] = position[1];
int3[2] = position[2];
int3[3] = 1.0f;
mat4_vec4_mul(model, int3, int1);
mat4_vec4_mul(view, int1, int2);
mat4_vec4_mul(proj, int2, int4);
int5[0] = int4[0] / int4[3];
int5[1] = int4[1] / int4[3];
int6[0] = int5[0] * 0.5f + 0.5f;
int6[1] = int5[1] * 0.5f + 0.5f;
out[0] = (int)(int6[0] * width);
out[1] = (int)((1.0f - int6[1]) * height);
void drawtriangle(float pos1[3], float pos2[3], float pos3[3]){
int v1[2];
int v2[2];
int v3[2];
vertexshader(pos1, model, view, proj, v1);
vertexshader(pos2, model, view, proj, v2);
vertexshader(pos3, model, view, proj, v3);
display.fillTriangle(v1[0], v1[1], v2[0], v2[1], v3[0], v3[1], WHITE);
void drawtrianglearray(float *positions, int size){
float pos1[3];
float pos2[3];
float pos3[3];
int i;
for(i = 0; i < size / 9; i++){
pos1[0] = pgm_read_float_near(positions + i * 9); //positions[i * 9];
pos1[1] = pgm_read_float_near(positions + i * 9 + 1); //positions[i * 9 + 1];
pos1[2] = pgm_read_float_near(positions + i * 9 + 2); //positions[i * 9 + 2];
pos2[0] = pgm_read_float_near(positions + i * 9 + 3); //positions[i * 9 + 3];
pos2[1] = pgm_read_float_near(positions + i * 9 + 4); //positions[i * 9 + 4];
pos2[2] = pgm_read_float_near(positions + i * 9 + 5); //positions[i * 9 + 5];
pos3[0] = pgm_read_float_near(positions + i * 9 + 6); //positions[i * 9 + 6];
pos3[1] = pgm_read_float_near(positions + i * 9 + 7); //positions[i * 9 + 7];
pos3[2] = pgm_read_float_near(positions + i * 9 + 8); //positions[i * 9 + 8];
drawtriangle(pos1, pos2, pos3);
