The code stopped at ' Serial.print(cm1);'
with serial monitor : cm 26 …
why this happened and what should I do?
Thanks
Adam
//self driving car
// written by sijah
// feel free to edit give respect
// thanks to all friends @awh
#include "HMC5883L.h"
#include <I2Cdev.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Servo.h>
#include <NewPing.h>
int mo1 = 2, mo2 = 3, mo3 = 4, mo4 = 5;
int vcc = 13;
#define trig1  9
#define echo1  8
#define MAX_DISTANCE 200
//int trig2 = 11;
//int echo2 = 10;
//int gnd = 4;
long cm1;//,cm2;
int i = 0;
NewPing sonar(trig1, echo1, MAX_DISTANCE);
//NewPing sonar2(trig2,echo2,250);
int f1 = 0;
float heading;
TinyGPS gps;
SoftwareSerial ss(11, 12);
void gpshead();
void stopp();
void rightturn();
void gostraight();
void leftturn();
void turn();
//Servo myservo;
float x2lon = radians(00000000), x2lat = radians(000000000); //enter ur final location here as lon and lat
HMC5883L mag;
int16_t mx, my, mz;
float head, distance = 0.0;
  Wire.begin();
  mag.initialize();
  ss.begin(9600);
  pinMode (vcc, OUTPUT);
  // pinMode (gnd,OUTPUT);
  pinMode(mo1, OUTPUT);
  pinMode(mo2, OUTPUT);
  pinMode(mo3, OUTPUT);
  pinMode(mo4, OUTPUT);
  //myservo.attach(7);
  digitalWrite(vcc, HIGH);
  if (f1 != 0)
    gostraight();
  cm1 = sonar.ping_cm();
  delay(50);
  Serial.print("cm");
  Serial.print(cm1);
  if (cm1 < 20 && cm1 > 0)
    mag.getHeading(&mx, &my, &mz);
    heading = atan2(my, mx);
    if (heading < 0)
      heading += 2 * M_PI;
    heading = heading * 180 / M_PI;
    if ((i % 2) == 0)
    { head = heading + 100;
      if (head > 360)
        head = head - 360;
      leftturn();
      /*myservo.write(180);
        delay(2000);*/
      //myservo.write(180);
      //i++;
    { head = heading - 100;
      if (head < 0)
        head = head + 360;
      rightturn();
      /*myservo.write(0);
        delay(1000);*/
      // myservo.write(0);
      //i++;
    while ((heading > head + 8) || (heading < head - 8)) // this loop turns the bot till its facing (head)degrees east of north
      turn();
      delay(5);
      if (heading < 0)
    stopp();
    delay(100);
  else {
    /*cm2=sonar2.ping_cm();
      delay(50);
      cm2+=sonar2.ping_cm();
      cm2=cm2/2;*/
    //while((cm1<50)&&(cm1>0))
    gostraight();
    delay(50);
    //cm2=sonar2.ping_cm();
    //delay(50);
    //cm2+=sonar2.ping_cm();
    //cm2=cm2/2;}
    stopp();
    do {
      gpshead();
    } while (distance == 0.0);
    if (distance < 15)
      while (1)
        stopp();
    if (f1 == 0)
    { mag.getHeading(&mx, &my, &mz);
      if (heading < 0)
        turn();
        delay(5);
        if (heading < 0)
      f1 = 4;
    f1--;
void turn()
{ float tur = heading - head;
  //if (tur < 0.0 && tur > -180 )
  // { //if (tur > -180.0)
  //rightturn();
  //  else {
  //leftturn();
  if (tur < 0.0)
  { if (tur > -180.0)
      rightturn();
      leftturn();
  { if (tur < 180.0)
      leftturn();
    else rightturn();
void leftturn()
{ digitalWrite(mo1, LOW);
  digitalWrite(mo2, LOW);
  digitalWrite(mo3, HIGH);
  digitalWrite(mo4, LOW);
  delay(10);
void stopp()
  digitalWrite(mo3, LOW);
void rightturn()
  digitalWrite(mo2, HIGH);
void gostraight()
void gpshead()
  bool newData = false;
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (ss.available())
      char c = ss.read();
      // Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    float flat1, flon1;
    unsigned long age;
    gps.f_get_position(&flat1, &flon1, &age);
    flon1 = radians(flon1);  //also must be done in radians
    flat1 = radians(flat1);  //also must be done in radians
    head = atan2(sin(x2lon - flon1) * cos(x2lat), cos(flat1) * sin(x2lat) - sin(flat1) * cos(x2lat) * cos(x2lon - flon1));
    head = head * 180 / 3.1415926535; // convert from radians to degrees
    float dist_calc = 0;
    float diflat = 0;
    float diflon = 0;
    diflat = x2lat - flat1; //notice it must be done in radians
    diflon = (x2lon) - (flon1); //subtract and convert longitudes to radians
    distance = (sin(diflat / 2.0) * sin(diflat / 2.0));
    dist_calc = cos(flat1);
    dist_calc *= cos(x2lat);
    dist_calc *= sin(diflon / 2.0);
    distance += dist_calc;
    distance = (2 * atan2(sqrt(distance), sqrt(1.0 - distance)));
    distance *= 6371000.0; //Converting to meters
    if (head < 0) {
      head += 360; //if the heading is negative then add 360 to make it positive
    head = 0.0;
    distance = 0.0;
This section of code looks like a potential trap where the processor would get stuck:
    do {
      gpshead();
    if (distance < 15)
      while (1)
        stopp();
Add some debug Serial.prints before and after this section. Print the value of “distance” just before the "if( distance < 15 )…
Blackfin:
   do {
     gpshead();
   if (distance < 15)
     while (1)
       stopp();
Add some debug Serial.prints before and after this section. Print the value of "distance" just before the "if( distance < 15 )...
Thanks,
It is some thing wrong, he car keep turning left side, but never goes out of, the 'T3a' never been printed.
How should I do then?
[code]Serial.print(“T3”);
      turn();
      delay(5);
      if (heading < 0)
Serial.print(“T3a”);
[/code]
Before doing much I would add prints of the variable heading each pass of the while loop. You could also print the values of my and mx to see if the values coming back from the magnetometer make sense:
   while((heading > head + 8) || (heading < head - 8)) // this loop turns the bot till its facing (head)degrees east of north
        turn();
        delay(5);
        if (heading < 0)
        Serial.print( "Heading: " ); Serial.print( heading, 3 );
        Serial.print( "\tmy: " ); Serial.print( my, 3 );
        Serial.print( "\tmx: " ); Serial.print( mx, 3 );
Blackfin:
       turn();
       delay(5);
       if (heading < 0)
Thank you so much.
I’ll test it tomorrow.
