The code works on Arduino Mega but not on Uno
I can run the code I added below on arduino mega. I can't run it even if I switch it to uno with the same connections. What do you think is the reason? I couldn't solve the problem for days.
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <Servo.h>
#include <IRremote.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
Servo servoMotor;
IRsend irsend(3);
int ledPin = 13; // choose the pin for the LED
int inputPin = 11; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int angles[] = {0, 90, 180}; // Açılar dizisi
// Horizontal soldan 1
unsigned int sendbuf34[] = {
  2956, 9648, 476, 1560, 472, 532, 472, 532, 472, 532, 472, 1564, 472, 532, 472, 532, 472, 532, 472, 532, 476, 528, 472, 532, 472, 1564, 472, 532, 472, 532, 472, 1560, 504, 1532, 472, 532, 472, 532, 504, 500, 472, 548, 456, 1564, 472, 532, 472, 1564, 472, 1560, 504, 1532, 500, 1536, 500, 1532, 504, 1532, 504
// Horizontal soldan 3
unsigned int sendbuf36[] = {
  2988, 9620, 504, 1528, 508, 500, 500, 500, 508, 496, 508, 1528, 504, 500, 504, 500, 504, 500, 504, 500, 504, 500, 504, 500, 504, 1528, 508, 500, 504, 496, 508, 1528, 504, 1532, 504, 500, 504, 500, 504, 500, 504, 500, 504, 1528, 504, 1532, 504, 500, 504, 1532, 504, 500, 504, 500, 504, 500, 504, 1528, 504
// Horizontal soldan 5
unsigned int sendbuf38[] = {
  2988, 9620, 504, 1528, 504, 500, 504, 500, 504, 500, 504, 1532, 504, 500, 504, 500, 504, 500, 504, 500, 504, 500, 504, 500, 504, 1528, 508, 496, 508, 500, 500, 1532, 508, 1528, 504, 500, 504, 512, 492, 500, 504, 500, 504, 1532, 504, 1528, 504, 1532, 504, 1532, 504, 500, 504, 500, 504, 1528, 504, 1532, 504
// Economy %80
unsigned int sendbuf42[] = {
2952, 9640, 472, 1560, 472, 532, 472, 532, 496, 508, 500, 1532, 472, 532, 468, 532, 472, 532, 472, 1560, 472, 1560, 472, 532, 472, 532, 496, 508, 472, 528, 500, 504, 472, 532, 468, 532, 472, 1564, 468, 1564, 472, 1560, 472, 1560, 472, 1560, 472, 532, 472, 1560, 472, 532, 472, 532, 468, 532, 472};
// Economy %60
unsigned int sendbuf43[] = {
2984, 9612, 500, 1536, 500, 504, 496, 508, 500, 504, 496, 1536, 500, 504, 500, 500, 500, 504, 500, 1532, 500, 1536, 472, 532, 496, 504, 500, 504, 500, 504, 500, 504, 500, 504, 496, 504, 500, 1536, 500, 1532, 500, 1532, 500, 1536, 496, 1536, 496, 1536, 500, 504, 500, 504, 500, 504, 496, 504, 500, 1536, 496};
// Economy %40
unsigned int sendbuf44[] = {
2980, 9616, 500, 1532, 500, 504, 500, 504, 504, 500, 500, 1532, 504, 500, 500, 504, 500, 504, 500, 1532, 500, 1532, 500, 504, 500, 504, 500, 504, 500, 504, 496, 508, 500, 500, 500, 1536, 496, 504, 500, 504, 500, 504, 500, 504, 500, 504, 496, 508, 500, 500, 500, 504, 500, 1532, 500, 504, 500, 504, 472};
// TURN off
unsigned int sendbuf2[] = {
3020, 9484, 548, 1468, 548, 464, 524, 488, 524, 492, 520, 1492, 524, 492, 548, 464, 548, 464, 520, 1492, 524, 1492, 520, 492, 524, 492, 520, 492, 520, 492, 524, 492, 520, 492, 552, 460, 524, 492, 520, 492, 548, 464, 524, 492, 520, 1492, 524, 488, 524, 1492, 520, 492, 524, 492, 520, 492, 520, 1492, 524};
// Exit Economy Mode
unsigned int sendbuf45[] = {
2984, 9616, 500, 1532, 504, 500, 500, 504, 500, 504, 500, 1536, 496, 504, 500, 504, 500, 504, 500, 1532, 500, 1536, 500, 504, 500, 500, 500, 504, 500, 516, 488, 504, 500, 504, 496, 508, 496, 1536, 500, 1532, 500, 1536, 496, 1536, 500, 1532, 500, 1536, 500, 1532, 504, 500, 500, 504, 500, 1532, 504, 500, 500};
unsigned long previousMotionTime = 0; // variable to store the last time motion was detected
unsigned long currentTime = 0; // variable to store the current time
unsigned long delayStart =0 ; // Alternate code attemp for 'delay()' . 'delay()' blocks code for getting PIR signals constantly.
unsigned long delayStop = 0;
// Define the time thresholds for economy mode control (in milliseconds)
const unsigned long timeThreshold80 = 10000; // 10 seconds
const unsigned long timeThreshold60 = 25000; // 25 seconds
const unsigned long timeThreshold40 = 40000; // 40 seconds
const unsigned long timeThresholdOff = 60000; // 60 seconds
const unsigned long timeThresholdExitEconomy = 1000; // 1 seconds to exit economy mode immediately
bool sent80 = false;
bool sent60 = false;
bool sent40 = false;
bool sentOff = false;
bool exitingEconomyMode = false; // flag to control exiting economy mode
  mlx.begin(); // Sensörü başlat
  servoMotor.attach(9); // Servo motorun sinyal pini
  servoMotor.write(angles[0]); // İlk açıya getir
  pinMode(ledPin, OUTPUT); // declare LED as output
  pinMode(inputPin, INPUT); // declare sensor as input
  delayStop=millis(); // RTC'den anlık zaman değerini alır.
  //Serial.print("Fark: "); // Sayacın işlediğini görmek için bu satırı açabilirsin !!
  //Serial.println(String(delayStop-delayStart)); //
  if ((delayStop-delayStart)>30000){ // Tarama işlemi bittiğindeki zaman ile anlık zaman arasındaki fark 10 saniyeden büyükse tekrar tarama yapar !
scanRoom();  // Odayı tarama fonksiyonuna gider
 val = digitalRead(inputPin); // read input value from PIR sensor
  if (val == HIGH) { // check if motion is detected
    digitalWrite(ledPin, HIGH); // turn LED ON
    if (pirState == LOW) {
      // we have just turned on, i.e., motion detected after no motion
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH; // update the PIR state to HIGH
      // Reset the flags to allow sending signals again
      sent80 = false;
      sent60 = false;
      sent40 = false;
      sentOff = false;
    // Reset the timer since motion was detected
    previousMotionTime = millis();
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH) {
      // we have just turned off, i.e., motion ended after motion detected
      Serial.println("Motion ended!");
      pirState = LOW; // update the PIR state to LOW
  // Get the current time
  currentTime = millis();
  // Check the time elapsed since the last motion was detected
  unsigned long timeSinceMotion = currentTime - previousMotionTime;
  // Control the air conditioner's economy mode based on time thresholds
  if (timeSinceMotion >= timeThresholdOff && !sentOff) {
    // Turn off the air conditioner
    sendSignal(sendbuf2, sizeof(sendbuf2) / sizeof(int));
    Serial.println("Air conditioner OFF");
    sentOff = true;
  } else if (timeSinceMotion >= timeThreshold40 && !sent40) {
    // Set the economy mode to 40%
    sendSignal(sendbuf44, sizeof(sendbuf44) / sizeof(int));
    Serial.println("Economy mode: 40%");
    sent40 = true;
  } else if (timeSinceMotion >= timeThreshold60 && !sent60) {
    sendSignal(sendbuf43, sizeof(sendbuf43) / sizeof(int));
    Serial.println("Economy mode: 60%");
    sent60 = true;
  } else if (timeSinceMotion >= timeThreshold80 && !sent80) {
    // Set the economy mode to 80%
    sendSignal(sendbuf42, sizeof(sendbuf42) / sizeof(int));
    Serial.println("Economy mode: 80%");
    sent80 = true;
  } else if (timeSinceMotion >= timeThresholdExitEconomy && !exitingEconomyMode) {
    // Exiting the economy mode
    sendSignal(sendbuf45, sizeof(sendbuf45) / sizeof(int));
    Serial.println("Exiting the economy mode!");
    exitingEconomyMode = true;
float readTemperature(int angle) {
  servoMotor.write(angle); // Servo motoru belirtilen açıya getir
  delay(500); // Servo motorun konum alması için biraz bekleyin
  float temp = mlx.readObjectTempC(); // Nesne sıcaklığını oku
  return temp;
void scanRoom (){
  float maxTemp = -273.15; // Minimum sıcaklık değeri
  int maxTempIndex = -1; // En yüksek sıcaklık değerinin dizideki indeksi
  for (int i = 0; i < 3; i++) {  // 3 farklı açıyı tarayarak sıcaklık ölçümü yap
    float temp = readTemperature(angles[i]);
    Serial.print("Açı: ");
    Serial.print(angles[i]);
    Serial.print(" Derece, Sıcaklık: ");
    Serial.print(temp);
    Serial.println(" °C");
    if (temp > maxTemp) {
      maxTemp = temp;
      maxTempIndex = i;
    delay(1000); // Her açı için 1 saniye bekle
  if (maxTempIndex != -1) {
    // Determine the corresponding signal based on the highest temperature
    if (maxTempIndex == 0) {
      sendSignal(sendbuf34, sizeof(sendbuf34) / sizeof(int));
      Serial.println("Sending signal: Horizontal 1");
    } else if (maxTempIndex == 1) {
      sendSignal(sendbuf36, sizeof(sendbuf36) / sizeof(int));
      Serial.println("Sending signal: Horizontal 3");
    } else if (maxTempIndex == 2) {
      sendSignal(sendbuf38, sizeof(sendbuf38) / sizeof(int));
      Serial.println("Sending signal: Horizontal 5");
    // Move the servo motor to the angle with the highest temperature
    servoMotor.write(angles[maxTempIndex]);
    delayStart=millis(); // Tarama işleminin bittiği zamanı kaydeder.
void sendSignal(unsigned int *signal, int length) {
  irsend.sendRaw(signal, length, 38); // kHz
  delay(200);
Why did you start a topic in the Uncategorised category of the forum when its description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Your topic has been moved to the Programming category
Which pins are you using for SDA and SCL on the Uno ?
Hello,
I use from UNO,
A5 for SCL
A4 for SDA
You also can use the pins labeled SCL and SDA at the opposite corner of the Uno.
What does that mean?
Hello,
I meant it doesn't work on Uno.
Sorry.
My glass ball is in the dishwasher to see what happens or doesn't happen.
But note that they are connected in parallel with A5 and A4
Do you think it could be a memory problem?
Yes, it is quite possible you've forgotten something.
You could try keeping those big constant arrays in PROGMEM
Right, but they are in the same position on the Mega. I'm pretty sure that I'd confuse A4 and A5.
Then make it work. Easy, eh?
If you don't tell us what does not work as expected then nobody can help you.
Have you tried to actually confirm on the Uno with a scope that you are actually receiving signals or getting signals from those pins ?
3
13
11
4
5
for the outputs you could use a Blink sketch.
The idea being perhaps its a faulty board or perhaps it's labelled incorrectly (i had a few instances where boards that i ordered were not as numbered)
Did you Confirm Visually via a scope that those pins work and are actually what they say they are ?
I highly suspect it is this:
"Global variables use 1973 bytes (96%) of dynamic memory, leaving 75 bytes for local variables. Maximum is 2048 bytes."
75 bytes could easily get overrun by stack and local variables.
As mentioned you should utilize progmem for some of the tables. You have plenty of that.
Use the F macro when printing constant strings:
Serial.println(F("Motion detected!"));
This will save a lot of SRAM.
