Hi
I'm using the monster moto shield VNH2SP30 to control a 12V DC motor but, the current pin shows a constant value (16)!
my code is:
#define BRAKE 0
#define CW 1
#define CCW 2
#define CS_THRESHOLD 15 // Definition of safety current (Check: "1.3 Monster Shield Example").
//MOTOR 1
#define MOTOR_A1_PIN 7
#define MOTOR_B1_PIN 8
//MOTOR 2
#define MOTOR_A2_PIN 4
#define MOTOR_B2_PIN 9
#define PWM_MOTOR_1 5
#define PWM_MOTOR_2 6
#define CURRENT_SEN_1 A2
#define CURRENT_SEN_2 A3
#define EN_PIN_1 A0
#define EN_PIN_2 A1
#define MOTOR_1 0
#define MOTOR_2 1
short usSpeed = 150; //default motor speed
unsigned short usMotor_Status = BRAKE;
pinMode(MOTOR_A1_PIN, OUTPUT);
pinMode(MOTOR_B1_PIN, OUTPUT);
pinMode(MOTOR_A2_PIN, OUTPUT);
pinMode(MOTOR_B2_PIN, OUTPUT);
pinMode(PWM_MOTOR_1, OUTPUT);
pinMode(PWM_MOTOR_2, OUTPUT);
pinMode(CURRENT_SEN_1, OUTPUT);
pinMode(CURRENT_SEN_2, OUTPUT);
pinMode(EN_PIN_1, OUTPUT);
pinMode(EN_PIN_2, OUTPUT);
Serial.begin(9600); // Initiates the serial to do the monitoring
Serial.println("Begin motor control");
Serial.println(); //Print function list for user selection
Serial.println("Enter number for control option:");
Serial.println("1. STOP");
Serial.println("2. FORWARD");
Serial.println("3. REVERSE");
Serial.println("4. READ CURRENT");
Serial.println("+. INCREASE SPEED");
Serial.println("-. DECREASE SPEED");
char user_input;
while(Serial.available())
user_input = Serial.read(); //Read user input and trigger appropriate function
digitalWrite(EN_PIN_1, HIGH);
digitalWrite(EN_PIN_2, HIGH);
if (user_input =='1')
Stop();
else if(user_input =='2')
Forward();
else if(user_input =='3')
Reverse();
else if(user_input=='4')
Serial.println(A2);
else if(user_input =='+')
IncreaseSpeed();
else if(user_input =='-')
DecreaseSpeed();
Serial.println("Invalid option entered.");
void Stop()
Serial.println("Stop");
motorGo(MOTOR_1, usMotor_Status, 0);
motorGo(MOTOR_2, usMotor_Status, 0);
void Forward()
Serial.println("Forward");
usMotor_Status = CW;
motorGo(MOTOR_1, usMotor_Status, usSpeed);
motorGo(MOTOR_2, usMotor_Status, usSpeed);
void Reverse()
Serial.println("Reverse");
usMotor_Status = CCW;
void IncreaseSpeed()
usSpeed = usSpeed + 10;
if(usSpeed > 255)
usSpeed = 255;
Serial.print("Speed +: ");
Serial.println(usSpeed);
void DecreaseSpeed()
usSpeed = usSpeed - 10;
if(usSpeed < 0)
usSpeed = 0;
Serial.print("Speed -: ");
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm) //Function that controls the variables: motor(0 ou 1), direction (cw ou ccw) e pwm (entra 0 e 255);
if(motor == MOTOR_1)
if(direct == CW)
digitalWrite(MOTOR_A1_PIN, LOW);
digitalWrite(MOTOR_B1_PIN, HIGH);
else if(direct == CCW)
digitalWrite(MOTOR_A1_PIN, HIGH);
digitalWrite(MOTOR_B1_PIN, LOW);
analogWrite(PWM_MOTOR_1, pwm);
else if(motor == MOTOR_2)
if(direct == CW)
digitalWrite(MOTOR_A2_PIN, LOW);
digitalWrite(MOTOR_B2_PIN, HIGH);
digitalWrite(MOTOR_A2_PIN, HIGH);
digitalWrite(MOTOR_B2_PIN, LOW);
analogWrite(PWM_MOTOR_2, pwm);
