Sorry to bother you, it was a very obvious problem.
Have you tried to set limits...
if (stateA == stateB) {
encoder1Pos--;
if encoder1Pos < 15 // if less than limit
encoder1Pos = 15; // remain at limit
encoder1Pos++;
if encoder1Pos > 500 // if greater than limit
encoder1Pos = 500; // remain at limit
What did you observe in post #2? I wonder if setting both limits was needed. Can you test it and modify it for your needs?
Hello everyone! I used an encoder motor and used an emg sensor to control it. When there is a long compression, the motors rotate forward and stop when the encoder value exceeds 500, if there is a short compression, the motors rotate back to the encoder value of 15. I have motors, its encoder, emg signal, everything works fine, there is one problem, after exceeding the value of the encoder, the motor does not stop, can you please help?
#include <ELEMYO.h>
#define CSpin 10 // chip select pin
#define sensorInPin A1 // analog input pin that the sensor is attached to
int signalReference = 524; // reference of signal, 2.5 V for MYO, MYO-kit, BPM, BPM-kit
//int signalReference = 369; // reference of signal, 1.8 V for MH-BPS101 and MH-BPS102
long timer = 0; // time length of EMG signal
const int motorPin1 = 7;
const int motorPin2 = 6;
const int encoderPin1A = 2;
const int encoderPin1B = 17;
const int sleepPin1 = 29;
volatile long encoder1Pos = 0;
unsigned long EMGStartTime = 0;
bool motorRunning = false;
ELEMYO MyoSensor(CSpin); // create ELEMYO object to work with signal
Serial.begin(115200); // initialize serial communications at 115200 bps
MyoSensor.gain(x2); // initial value of gain
pinMode(sensorInPin, INPUT); // initialize sensorInPin
Serial.println("Type 1 - short muscle contraction");
Serial.println("Type 2 - long muscle contraction");
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(encoderPin1A, INPUT_PULLUP);
pinMode(encoderPin1B, INPUT_PULLUP);
pinMode(sleepPin1, OUTPUT);
digitalWrite(sleepPin1, HIGH);
attachInterrupt(digitalPinToInterrupt(encoderPin1A), updateEncoder1, CHANGE);
moveMotorBackward1();
delay(1500);
stopMotor1();
encoder1Pos = 0; // Сброс энкодера
Serial.println(encoder1Pos);
int signalValue = analogRead(sensorInPin); // read the analog in value:
signalValue = MyoSensor.BandStop(signalValue, 50, 4); // notch 50 Hz filter with band window 4 Hz.
signalValue = MyoSensor.BandStop(signalValue, 100, 6); // notch 100 Hz (one of 50 Hz mode) filter with band window 6 Hz
int signalValueMA = MyoSensor.movingAverage(signalValue, signalReference, 0.92); // moving average transformation with 0.92 smoothing constant
// start timer if EMG amplitude is greater than the given threshold and it is new start of EMG signal
if (signalValueMA >= 100 && timer == 0)
timer = millis();
// if EMG amplitude is bellow than the given threshold
if (signalValueMA < 100 && timer != 0) {
if ((millis() - timer) < 500) // if EMG time length less then 0.5 c
Serial.println("Type 1");
if (encoder1Pos > 15) {
stopMotor1();
} else // if EMG time length more then 0.5 c
Serial.println("Type 2");
if (encoder1Pos < 500) {
moveMotorForward1();
stopMotor1();
timer = 0;
delay(1); // wait before the next loop
void updateEncoder1() {
int stateA = digitalRead(encoderPin1A);
int stateB = digitalRead(encoderPin1B);
encoder1Pos--;
encoder1Pos++;
void stopMotor1() {
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, LOW);
void moveMotorBackward1() {
digitalWrite(motorPin2, HIGH);
void moveMotorForward1() {
digitalWrite(motorPin1, HIGH);
