The good mosfet
Hi everyone,
In playing around with arduino, I often need to add a mosfet here and there. I have had some lying around, but now want to purchase a bunch for general purposes.
By general purposes, it is all from motors, to solonoids to relays and whatnot.
The question is though - what is a good general purpose mosfet?
I have been using some TIP125, but what would you recommend?
Thank you in advance!
The TIP125 is a PNP darlington, which begs the question do you want an n-channel
or p-channel MOSFET or both?
For general use normally n-channel would be used. It must be logic-level,
and an on-resistance of 0.015 ohms or less is desireable. Unless you are
dealing with voltages higher than 12V go for 20V or 30V MOSFETs - the
lower the voltage the cheaper a low-resistance MOSFET is (and there
are more to choose from).
If you want p-channel for high-side switching then the supply voltage matters.
If you were switching 12V LED strips for instance then a non-logic-level
p-channel device would be appropriate, driven by a small NPN transistor
as level-shifter. If everything is 5V then logic-level p-channel would be
required.
IRL540 are popular/easy to get....
... but Rds of IRL540 won't be anywhere near that (datasheet says 0.077 Ohms @ 5V).
0.015 Ohms seems very low to me. Something like an HUF76137 will do it but they're not so easy to find.
Search Digikey - N-channel MOSFET for sinking current thru LED strips, motors, relay coils, etc. Logic Level, Low Rds, Low gate capacitance, In stock, low price:
39mOhm
8mOhm
5mOhm
Overall list of thru hole parts - sort by price, find 1-lot price with lowest Rds you are comfortable paying for.
Can do similar search for P-Channel. List of available parts is far smaller, and parts are pricier tho:
200mOhm
50mOhm
7mOhm
Thank you for the response MartT. I had an idea that the TMP125 was a PNP, and that this was not what I wanted - I was not quite sure enough of that though, which is also why I asked.
Most voltages I would be switching is around 12V in most cases.
I have also used:
IRF520NPbF (http://arduino.cc/documents/datasheets/MOS-irf520npbf.pdf)
These were from the Arduino Starter Kit I got a while back - so I would assume they are recommendable. I have found them quite affordable ($0.74 a piece):
http://www.aliexpress.com/item/Free-Shipping-20pcs-lot-IRF520NPBF-IRF520N-IR-TO220-IC/1473225690.html
Are those worth using? They apparently have an on-resistance of 0.20Ohm, which is of course quite far from your recommendation.
I understand that the moment I start going for much higher loads, I may need something else, but for general purpose?
The IRL540 also seem quite good (http://www.vishay.com/docs/91300/91300.pdf), and at an excellent price:
http://www.aliexpress.com/item/Free-Shipping-20PCS-IRL540N-IRL540-IR-T0-220-IC/1366673716.html
The lower resistance when on, should mean it heats less (as I understand it), thus better at higher loads.
Are there any distadvantages over this vs the other?
CrosssRoads: Thank you for the links. I will try going through it, once I understand it all better.
Thank you for taking your time to help me out understanding all of this :slight_smile:
Casper
Hotcut:
I have also used:
No.... the IRF520 is NOT a logic level MOSFET. It cannot be fully switched on with a 5V signal.
Hotcut:
The clue is in the name.
The 'L' in IRL540 indicates "Logic Level".
I'm using this one in a temperature controller project:
It should be able to switch pretty high loads without a heatsink. My device is 3.6 amps @ 12v.
fungus:
0.002 ohms is very low. 0.01 ohms isn't exceptional these days.
Fungus, thank you for that clarification! I was sure it was a logic level, considering that it is the one Arduino sent with their starter kit.
This might explain why I am having so many problems with my drink-dispensing project (solonoid not opening fully perhaps).
I will be going for the IRL540 - logic level, and seems to be easier to find than the IRLB8721PBF suggested by Planecrazy29.
Thank you all for your help with this. I believe I have gotten a somewhat better understanding of this now.
Have a great day!
Casper
