The I2C lcd display question
Hello. So, for two days I have been trying to make one project that includes an I2C lcd display, a slide switch and a pushbutton. So basically, every time I press the pushbutton the text on the lcd should change. But when the slide switch is on the left the lcd should turn off. So, I managed to do all of that(90 % of the code on my own) and the code works, but I dont understand how one part of it works. Here is the code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
int button = 7;
int buttonValue = 0;
int prevButtonValue = 0;
int buttonHits = 1;
int rightSwitchSide = 4;
int rightSwitchSideValue;
  pinMode(button, INPUT);
  pinMode(rightSwitchSide, INPUT);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(3,0);
  lcd.print("CURIOSITY");
  delay(2000);
  lcd.setCursor(1,1);
  lcd.print("NEW ERA BEGINS");
  delay(2000);
  lcd.clear();
  buttonValue = digitalRead(button);
  rightSwitchSideValue = digitalRead(rightSwitchSide);
  lcds();
void lcds(){
  if(rightSwitchSideValue == HIGH){
    lcd.init();
    lcd.backlight();
    if(buttonValue == HIGH){              /*This is the part that I dont understand */
        buttonHits = buttonHits + 1;
        delay(20);
    if(buttonHits == 1){
      lcd.setCursor(1,0);
      lcd.print("Hello");
    else if(buttonHits == 2){
      lcd.setCursor(1,0);
      lcd.print("Friends");
    else if(buttonHits == 3){
      lcd.setCursor(1,0);
      lcd.print("Mates");
    else if(buttonHits > 3){
      buttonHits = 1;
  else{
    lcd.noDisplay();
    lcd.noBacklight();
How can that part of the code work? Couse, if I release the button, then what should happen is that buttonHits would stop being 2. .... I dont know if you understand what I am saying, but I hope you can help me figure out how why the hell this works... The code is working fine, but I don't know why xD
Ohhh, yeaa, there are no instructions for when buttonValue is LOW. Ahh, thanks alot, thats all I needed. Hah, sorry, this was a weird topic to make. I am still new to all of this so I sometimes get confused when there is alot of code...
Also I use resistors when connecting both slide switch and pushbutton. I dont know why I am not using input_pullup :frowning:
