the ide doesnt recognizing the funduino nano
i bought funduino nano and the ide doesnt recognie it and the lights on the funduino are working
how can i fix that ?
thanks in advance
What do you mean by "doesnt recognizing it"?
noam:
the ide doesnt recognizing it
did you install the drivers for the usb to serial chip?
if not it’s the ch340g chip, install the drivers for the chip and try again
rednez: did you install the drivers for the usb to serial chip?
if not it's the ch340g chip, install the drivers for the chip and try again
thanks for the quick reply
yes and i tried to install it from chinese website that i found on a youtube video about this problem and it didnt work and now i tried again from here http://www.arduined.eu/ch340g-converter-windows-7-driver-download/ and http://www.arduined.eu/tag/ch340g/ and its not working and its downloading ch341ser and i found also ch340ir but it doesnt working
and the windows is recognizing it as ft232 usb uart
pert: What do you mean by "doesnt recognizing it"?
[quote author=pert link=msg=3365263
pert:
the port tab is disabled and i cant choose anything and when im connecting the fuduino at the first time or after im deleting it on the device manager and then when the windows is trying to install it so it says that its failed
FTDI FT232 driver is located in the drivers subfolder of the Arduino IDE installation folder.
pert: FTDI FT232 driver is located in the drivers subfolder of the Arduino IDE installation folder.
i found thr folder but i didnt found anything with the name ftd and or ft232 can you please explain it better ?
The folder is named "FTDI USB Drivers"
pert: The folder is named "FTDI USB Drivers"
and i dont have this folder
That makes no sense but just look around on the FTDI website for the FT232 driver.
