Hi, hope some one can help me out trying to combine this two programs, I´m trying to make a stopwatch but the start buttons instead of being buttons I want to make them with FSR sensors,
I have already a program that works as a stopwatch but I need to change it to use the FSR and also because on the start is a pullup button (wich is good) but the stop is also a pullup button and while you keep pressing the time keeps running, and it should be a press button to just stop.
The First piece of code is the program that I use for the stopwatch, and the second is the program I use for the FSR sensor.
The goal is to combine the two programs, modify the stopwatch so instead of using regular buttons, use the FSR sensors, and make the start based on Pull up (so while you are standing the timer is not working) and the stop make it a press button but also with FSR, two different FSR that work differently.
Thanks in Advance, here is the code for the stopwatch
// StopWatch trying to change the way it starts and stops but using FSR
#include "LedControl.h"
LedControl lc = LedControl(12, 11, 10, 1);//Set up the Max7219 display pins
unsigned long previousMillis = 0;
unsigned long interval = 6;
const int buzzer = 6;// Defines the pin for the buzzer
byte estado = 0;// variable to avoid re-start of the timer before the other is on the race
byte pinsBut [] = { 7, 8, 9 };// Array for the start and finish button, Problem I have to change with FSR
#define N_BUT sizeof(pinsBut)
byte butState [N_BUT];
bool run = false; //States if the timmer is running or not
unsigned long msec0 = 0;
//Here I put the variables for the FSR Sensors
int fsrAnalogPin = 0; // FSR is connected to analog 0
int LEDpin = 4; // connect Red LED to pin 11 (PWM pin)to check if activates or not
int fsrReading; // the analog reading from the FSR resistor divider
int LEDbrightness;
int chkButtons ()
for (unsigned n = 0; n < sizeof(pinsBut); n++) {
byte but = digitalRead (pinsBut [n]);//Reads the state for the pins that are installed in the buttons
if (butState [n] != but) {
butState [n] = but;
delay (10); // debounce
if (HIGH == but)// Problem here is that for the start is better to have it as High so when you stop touching the timer starts but for the stop if you keep touching the timer keeps going
return n;
return -1;
char *//Calculates the functions that are shown in the Serial monitor and in the timer
fmtTime (
unsigned long msec )
static char s [80];
unsigned mins = msec / (60L * 1000);
unsigned hour = mins / 60;
mins = mins % 60;
unsigned secs = msec % (60L * 1000);
sprintf (s, " %2d:%02d:%02d.%03d",
hour, mins, secs / 1000, secs % 1000);
return s;
void loop ()
unsigned long msec = millis ();
unsigned mins = msec / (60L * 1000);// for the timing data
mins = mins % 60;
// Checks the FSR sensor
LEDbrightness = map(fsrReading, 0, 1023, 0, 255);
if (run) {
estado = 1;// This is what stops from starting again while the person is running
unsigned long time = msec - msec0;
Serial.println (fmtTime (time));//Display the data in the serial monitor
int ones, tens, fsec, sec, minute, reminuto, dsec;
// First display fsec
fsec = time / 10;
ones = time / 10 % 10; // hundreds of a second
tens = (fsec / 10) % 10; //Tens of a second
lc.setDigit(0, 0, (byte)ones, false); //Shows the Hundreds and is correct
lc.setDigit(0, 1, (byte)tens, false); //Shows the Tens and is correct
// Now display sec
lc.setChar(0, 2, '.', false);//Puts the dot in the middle of the 7216 Display
lc.setChar(0, 5, '.', false);//Puts the other dot in the middle of the 7216 Display
sec = (time / 1000) % 10;
dsec = (time / 10000) % 6;
lc.setDigit(0, 4, (byte)dsec, false);//Shows seconds
lc.setDigit(0, 3, (byte)sec, false);
// Next display mm
ones = (time / 60000) & 59; //turns into a minute
tens = (time / 600000);
lc.setDigit(0, 7, (byte)tens, false); //shows 2 minutes
lc.setDigit(0, 6, (byte)ones, false); // shows seconds
switch (chkButtons ()) {
case 1: // Stop case, the timmer is not running
run = false;
estado = 0;//to be sure it does not start again
tone(buzzer, 200, 250);// makes noise when stops
digitalWrite(5, LOW);// Turns off a light when is not running
digitalWrite(4, HIGH); // Turns On a light when the timer si running
case 0: // start, The stop watch is running
if(run == true and estado == 1) {//I make sure that it has stopped before starts again
} else if(estado == 1);{
run = true;
tone(buzzer, 850, 350);//Makes noise when starts
digitalWrite(5, HIGH);// The led that indicates that its running starts
digitalWrite(4, LOW);// The ready light is turned off
msec0 = msec ;
digitalWrite(5, HIGH);// I think this is a mistake
digitalWrite(4, LOW);}// I think this is a mistake because its already turned on..
void setup ()
Serial.begin (9600);
pinMode(buzzer, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
// the zero refers to the MAX7219 number, it is zero for 1 chip
pinMode(LEDpin, OUTPUT);//Pin for the led of the FSR
lc.shutdown(0, false); // turn off power saving, enables display
lc.setIntensity(0, 12); // sets brightness (0~15 possible values)
lc.clearDisplay(0);// clear screen
int fsec, sec, minute, reminuto;// declares the time variables
for (unsigned n = 0; n < sizeof(pinsBut); n++) {//Checks the pin variables in case there are changes
pinMode (pinsBut [n], INPUT_PULLUP);
butState [n] = digitalRead (pinsBut [n]);
________________________________ Code for the FSR sensors__________
//* FSR testing sketch.
//Connect one end of FSR to 5V, the other end to Analog 0, and the second FSR to Analog 1
//Then connect one end of a 10K resistor from Analog 0 to ground
//Connect LED from pin 11 through a resistor to ground
int fsrAnalogPin = 0; // FSR is connected to analog 0 for to work as a button for start, when stops having preasure
int fsrAnalogPin2 = 1; // FSR is connected to analog 1 for stop when it feels pressure.
int fsrReading2; // the analog reading from the FSR resistor divider
int FSRpad;//store the value of the start sensor
int FSRpad2;// store the value for the stop sensor
void setup(void) {
Serial.begin(9600); // We'll send debugging information via the Serial monitor
void loop(void) {
fsrReading = analogRead(fsrAnalogPin);
fsrReading2 = analogRead(fsrAnalogPin2);
Serial.print("Analog reading = ");
Serial.println(fsrReading);
Serial.println(fsrReading2);
// we'll need to change the range from the analog reading (0-1023) down to the range
// used by analogWrite (0-255) with map!
FSRpad = map(fsrReading, 0, 1023, 0, 255);
FSRpad2 = map(fsrReading2, 0, 1023, 0, 255);
if (FSRpad > 100) {
tone(buzzer, 200,300);// means the runner has started
if (FSRpad2 > 400) {
tone(buzzer, 200,500);// means the runner should have stopped
delay(1);
