"The Joystick library can only be used with a USB MCU" while using pro micro
Here's the error message:
Arduino: 1.8.13 Hourly Build 2020/02/19 03:33 (Windows 10), Board: "Arduino Micro"
E:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino\hardware -hardware C:\Users\justi\AppData\Local\Arduino15\packages -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -tools C:\Users\justi\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino\libraries -libraries C:\Users\justi\Documents\Arduino\libraries -fqbn=arduino:avr:micro -vid-pid=0X2341_0X8037 -ide-version=10813 -build-path C:\Users\justi\AppData\Local\Temp\arduino_build_210816 -warnings=none -build-cache C:\Users\justi\AppData\Local\Temp\arduino_cache_258320 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\examples\JoystickTest\JoystickTest.ino
E:\Arduino\arduino-builder -compile -logger=machine -hardware E:\Arduino\hardware -hardware C:\Users\justi\AppData\Local\Arduino15\packages -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -tools C:\Users\justi\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino\libraries -libraries C:\Users\justi\Documents\Arduino\libraries -fqbn=arduino:avr:micro -vid-pid=0X2341_0X8037 -ide-version=10813 -build-path C:\Users\justi\AppData\Local\Temp\arduino_build_210816 -warnings=none -build-cache C:\Users\justi\AppData\Local\Temp\arduino_cache_258320 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\justi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\examples\JoystickTest\JoystickTest.ino
Using board 'micro' from platform in folder: C:\Users\justi\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\justi\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\justi\\AppData\\Local\\Temp\\arduino_build_210816\\sketch\\JoystickTest.ino.cpp" -o nul
Alternatives for Joystick.h: [ArduinoJoystickLibrary-master@2.0.7]
ResolveLibrary(Joystick.h)
  -> candidates: [ArduinoJoystickLibrary-master@2.0.7]
"C:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\justi\\AppData\\Local\\Temp\\arduino_build_210816\\sketch\\JoystickTest.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\justi\AppData\Local\Temp\arduino_build_210816\sketch\JoystickTest.ino.cpp
"C:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src\\DynamicHID\\DynamicHID.cpp" -o nul
"C:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src\\Joystick.cpp" -o nul
Error while detecting libraries included by C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src\Joystick.cpp
Generating function prototypes...
"C:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\justi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\justi\\Documents\\Arduino\\libraries\\ArduinoJoystickLibrary-master\\src" "C:\\Users\\justi\\AppData\\Local\\Temp\\arduino_build_210816\\sketch\\JoystickTest.ino.cpp" -o "C:\\Users\\justi\\AppData\\Local\\Temp\\arduino_build_210816\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\examples\JoystickTest\JoystickTest.ino:13:0:
C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master\src/Joystick.h:32:2: error: #error The Joystick library can only be used with a USB MCU (e.g. Arduino Leonardo, Arduino Micro, etc.).
Using library ArduinoJoystickLibrary-master at version 2.0.7 in folder: C:\Users\justi\Documents\Arduino\libraries\ArduinoJoystickLibrary-master
exit status 1
Error compiling for board Arduino Micro.
