The L298n motor can't move when I activate the severo motor
The L298n motor works well when the program is no code with severo motor but the motor doesn't move while the severo motor code is in the program
#include <Ultrasonic.h>
#include <Servo.h>   //
Servo myservo;  // ???
//IRsencor
int DigitalPin =7;
int AnalogPin =A1;
//uira
const int trigPin = 5;             //Trig Pin
const int echoPin = 6;             //Echo Pin
long duration, cm, inches;
int BackwardSpeed = 50;
//Ultrasonic ultrasonic(8,9); // (Trig PIN,Echo PIN)//
//motor
int m1p1 =8;
int m1p2 =9;
int m2p1 =12;
int m2p2 =13;
const int pwm1 =10;
const int pwm2 =11;
void motorStop(){
  digitalWrite( m1p1 , LOW);
  digitalWrite( m1p2 , LOW);
  digitalWrite( m2p1 , LOW);
  digitalWrite( m2p2 , LOW);
  analogWrite(10, 0);
  analogWrite(11, 0);
void Backward(){
  digitalWrite( m1p2 , HIGH);
  digitalWrite( m2p1 , HIGH);
  analogWrite(10, 200);
  analogWrite(11, 200);
void forward(){
  digitalWrite( m1p1 , HIGH);
  digitalWrite( m2p2 , HIGH);
  analogWrite(10, 150);
void Fforward(){
  analogWrite(11, 250);
void left()
  analogWrite(11, 0);
void right()
  analogWrite(10, 0);
  analogWrite(11, 150);
    myservo.attach(3);  //
    pinMode(m1p1, OUTPUT);
    pinMode(m1p2, OUTPUT);
    pinMode(m2p1, OUTPUT);
    pinMode(m2p2, OUTPUT);
    pinMode(pwm1, OUTPUT);
    pinMode(pwm2, OUTPUT);
    pinMode(DigitalPin, INPUT); //
    pinMode(AnalogPin, INPUT); //
    pinMode(trigPin, OUTPUT);          //
    pinMode(echoPin, INPUT);
  analogWrite(10, 170);
  delay (4000);
  analogWrite(10, 0);
  analogWrite(11, 0);
  myservo.write(180); //
  delay (1000);
  //IR
  boolean D_val = digitalRead(DigitalPin); //
  int A_val = analogRead(AnalogPin);
  //if(A_val >400 )//
  //ultra
  digitalWrite(trigPin, LOW);
  delayMicroseconds(5);
  digitalWrite(trigPin, HIGH);     //
  delayMicroseconds(10);
  pinMode(echoPin, INPUT);          //
  duration = pulseIn(echoPin, HIGH);   //
  cm = (duration/2) / 29.1;         //
  Serial.println(cm);
if (cm>30 && A_val>400)
    forward ();
else if (10<cm<30 &&A_val>400)
Fforward ();
else if (cm<10 &&A_val>400)
//myservo.write(120);
Fforward ();
delay(2000);
else if (A_val<400 && cm>30)
motorStop();
delay (10);
Backward();
left();
delay (2000);
forward();
delay (1000);
else if (A_val<400 && cm<30)
  motorStop();
delay (10);
Backward();
left();
delay (2000);
forward();
delay (1000);
    motorStop();
When using the servo lib on UNO R3 ( or any 328P based board) you cannot use analog wite at pins 9 and 10. You must switch to an other pwm pin. See reference of servo.h:
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10
so can the pwm pins t3,5,6or11 still work?
thanks!
Yes, only pins 9 and 10 are affected.
