The library file is in there, but got error of: No such file or directory
Hi everyone,
the code below got error of :
esp32-cam-cat-dog_inferencing.h: No such file or directory
but the file is in there, why?
Thanks
adam
#include <esp32-cam-cat-dog_inferencing.h>  // replace with your deployed Edge Impulse library
#define CAMERA_MODEL_AI_THINKER
#include "img_converters.h"
#include "image_util.h"
#include "esp_camera.h"
#include "camera_pins.h"
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#define TFT_SCLK 14 // SCL
#define TFT_MOSI 13 // SDA
#define TFT_RST  12 // RES (RESET)
#define TFT_DC    2 // Data Command control pin
#define TFT_CS   15 // Chip select control pin
                    // BL (back light) and VCC -> 3V3
#define BTN       4 // button (shared with flash led)
dl_matrix3du_t *resized_matrix = NULL;
ei_impulse_result_t result = {0};
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// setup
  // button
  pinMode(4, INPUT);
  // TFT display init
  tft.initR(INITR_GREENTAB); // you might need to use INITR_REDTAB or INITR_BLACKTAB to get correct text colors
  tft.setRotation(0);
  tft.fillScreen(ST77XX_BLACK);
  // cam config
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_240X240;
  config.jpeg_quality = 10;
  config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, 0); // lower the saturation
  Serial.println("Camera Ready!...(standby, press button to start)");
  tft_drawtext(4, 4, "Standby", 1, ST77XX_BLUE);
// main loop
  // wait until the button is pressed
  while (!digitalRead(BTN));
  delay(100);
  // capture a image and classify it
  String result = classify();
  // display result
  Serial.printf("Result: %s\n", result);
  tft_drawtext(4, 120 - 16, result, 2, ST77XX_GREEN);
// classify labels
String classify() {
  // run image capture once to force clear buffer
  // otherwise the captured image below would only show up next time you pressed the button!
  capture_quick();
  // capture image from camera
  if (!capture()) return "Error";
  tft_drawtext(4, 4, "Classifying...", 1, ST77XX_CYAN);
  Serial.println("Getting image...");
  signal_t signal;
  signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_WIDTH;
  signal.get_data = &raw_feature_get_data;
  Serial.println("Run classifier...");
  // Feed signal to the classifier
  EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false /* debug */);
  // --- Free memory ---
  dl_matrix3du_free(resized_matrix);
  // --- Returned error variable "res" while data object.array in "result" ---
  ei_printf("run_classifier returned: %d\n", res);
  if (res != 0) return "Error";
  // --- print the predictions ---
  ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
  int index;
  float score = 0.0;
  for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
    // record the most possible label
    if (result.classification[ix].value > score) {
      score = result.classification[ix].value;
      index = ix;
    ei_printf("    %s: \t%f\r\n", result.classification[ix].label, result.classification[ix].value);
    tft_drawtext(4, 12 + 8 * ix, String(result.classification[ix].label) + " " + String(result.classification[ix].value * 100) + "%", 1, ST77XX_ORANGE);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
  ei_printf("    anomaly score: %f\r\n", result.anomaly);
#endif
  // --- return the most possible label ---
  return String(result.classification[index].label);
// quick capture (to clear buffer)
void capture_quick() {
  camera_fb_t *fb = NULL;
  fb = esp_camera_fb_get();
  if (!fb) return;
  esp_camera_fb_return(fb);
bool capture() {
  Serial.println("Capture image...");
  esp_err_t res = ESP_OK;
  if (!fb) {
    Serial.println("Camera capture failed");
    return false;
  // --- Convert frame to RGB888  ---
  Serial.println("Converting to RGB888...");
  // Allocate rgb888_matrix buffer
  dl_matrix3du_t *rgb888_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
  fmt2rgb888(fb->buf, fb->len, fb->format, rgb888_matrix->item);
  // --- Resize the RGB888 frame to 96x96 in this example ---
  Serial.println("Resizing the frame buffer...");
  resized_matrix = dl_matrix3du_alloc(1, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3);
  image_resize_linear(resized_matrix->item, rgb888_matrix->item, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3, fb->width, fb->height);
  // --- Convert frame to RGB565 and display on the TFT ---
  Serial.println("Converting to RGB565 and display on TFT...");
  uint8_t *rgb565 = (uint8_t *) malloc(240 * 240 * 3);
  jpg2rgb565(fb->buf, fb->len, rgb565, JPG_SCALE_2X); // scale to half size
  tft.drawRGBBitmap(0, 0, (uint16_t*)rgb565, 120, 120);
  rgb565 = NULL;
  dl_matrix3du_free(rgb888_matrix);
  return true;
int raw_feature_get_data(size_t offset, size_t out_len, float *signal_ptr) {
  size_t pixel_ix = offset * 3;
  size_t bytes_left = out_len;
  size_t out_ptr_ix = 0;
  // read byte for byte
  while (bytes_left != 0) {
    // grab the values and convert to r/g/b
    uint8_t r, g, b;
    r = resized_matrix->item[pixel_ix];
    g = resized_matrix->item[pixel_ix + 1];
    b = resized_matrix->item[pixel_ix + 2];
    // then convert to out_ptr format
    float pixel_f = (r << 16) + (g << 8) + b;
    signal_ptr[out_ptr_ix] = pixel_f;
    // and go to the next pixel
    out_ptr_ix++;
    pixel_ix += 3;
    bytes_left--;
  return 0;
// draw test on TFT
void tft_drawtext(int16_t x, int16_t y, String text, uint8_t font_size, uint16_t color) {
  tft.setCursor(x, y);
  tft.setTextSize(font_size); // font size 1 = 6x8, 2 = 12x16, 3 = 18x24
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(strcpy(new char[text.length() + 1], text.c_str()));
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, 80MHz"
edge-impulse-esp32-cam:11:10: fatal error: esp32-cam-cat-dog_inferencing.h: No such file or directory
compilation terminated.
exit status 1
option enabled in File -> Preferences.
I would ask where "there" is. Also check your spelling, a case or _ instead of - etc will cause this error.
If the above doesn't help I suggest you run an example from that library. Its always good to test pieces of code before full integration.
You mean locally and in the same folder structure as your other includes?
If so, then try
#include "esp32-cam-cat-dog_inferencing.h"
Thanks for the reply.
the new error came out: Error compiling for board AI Thinker ESP32-CAM. the board is AI Thinker ESP32-CAM and the code is for AI Thinker ESP32-CAM.
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_accumulate_q7_to_q15.c: In function 'arm_nn_accumulate_q7_to_q15':
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_accumulate_q7_to_q15.c:57:22: warning: implicit declaration of function '__PKHTB' [-Wimplicit-function-declaration]
         vo2 = (q31_t)__PKHTB(v1, v2, 16);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_accumulate_q7_to_q15.c:58:22: warning: implicit declaration of function '__PKHBT' [-Wimplicit-function-declaration]
         vo1 = (q31_t)__PKHBT(v2, v1, 16);
c:/users/hua.dellv-pc/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\espressif\objs.a(debug_log.cpp.o): in function `DebugLog(char const*)':
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\espressif/debug_log.cpp:34: multiple definition of `DebugLog(char const*)'; libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\arduino\objs.a(debug_log.cpp.o):C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\arduino/debug_log.cpp:34: first defined here
c:/users/hua.dellv-pc/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\espressif\objs.a(ei_classifier_porting.cpp.o): in function `ei_read_timer_ms()':
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\espressif/ei_classifier_porting.cpp:47: multiple definition of `ei_read_timer_ms()'; libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\arduino\objs.a(ei_classifier_porting.cpp.o):C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\arduino/ei_classifier_porting.cpp:41: first defined here
c:/users/hua.dellv-pc/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\espressif\objs.a(ei_classifier_porting.cpp.o): in function `ei_read_timer_us()':
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\espressif/ei_classifier_porting.cpp:51: multiple definition of `ei_read_timer_us()'; libraries\cats_and_dogs_inferencing\edge-impulse-sdk\porting\arduino\objs.a(ei_classifier_porting.cpp.o):C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\cats_and_dogs_inferencing\src\edge-impulse-sdk\porting\arduino/ei_classifier_porting.cpp:45: first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
checked the mbed.h that included lot of statement as:
#if MBED_CONF_NSAPI_PRESENT
#include "netsocket/nsapi.h"
#include "netsocket/nsapi_ppp.h"
#endif
and:
#include "platform/mbed_wait_api.h"
#include "platform/mbed_thread.h"
seems Arduino can't use '/' , '_' in library file?
I can search out the esp32-cam-cat-dog_inferencing.h in library, maybe the IDE can't use the files in a deep multiple nesting?
Does your library have an "example" you could run?
