The limit value of PID integral term problem
Hello,
I've opened the PID library created by Brett Beauregard with Notepad++ to see what's inside the file. I'm interested in this part of the code
PID::PID(double* Input, double* Output, double* Setpoint,
        double Kp, double Ki, double Kd, int ControllerDirection)
    myOutput = Output;
    myInput = Input;
    mySetpoint = Setpoint;
	inAuto = false;
	[color=red][b]PID::SetOutputLimits(0, 255);	[/b]	[/color]		//default output limit corresponds to
												//the arduino pwm limits
    SampleTime = 100;							//default Controller Sample Time is 0.1 seconds
    PID::SetControllerDirection(ControllerDirection);
    PID::SetTunings(Kp, Ki, Kd);
    lastTime = millis()-SampleTime;
void PID::SetOutputLimits([color=red][b]double Min, double Max[/b][/color])
   if(Min >= Max) return;
 [color=red][b]  outMin = Min;
   outMax = Max;[/b][/color]
   if(inAuto)
	   if(*myOutput > outMax) *myOutput = outMax;
	   else if(*myOutput < outMin) *myOutput = outMin;
	   if(ITerm > outMax) ITerm= outMax;
	   else if(ITerm < outMin) ITerm= outMin;
bool PID::Compute()
   if(!inAuto) return false;
   unsigned long now = millis();
   unsigned long timeChange = (now - lastTime);
   if(timeChange>=SampleTime)
      /*Compute all the working error variables*/
	  double input = *myInput;
      double error = *mySetpoint - input;
     [color=red][b] ITerm+= (ki * error);
      else if(ITerm < outMin) ITerm= outMin;[/b][/color]
      double dInput = (input - lastInput);
      /*Compute PID Output*/
      double output = kp * error + ITerm- kd * dInput;
	  if(output > outMax) output = outMax;
      else if(output < outMin) output = outMin;
	  *myOutput = output;
      /*Remember some variables for next time*/
      lastInput = input;
      lastTime = now;
	  return true;
   else return false;
As the code which is highlighted with red color, It's shown that the integral term will be limited on the range of 0 to 255.
But I think the integral term should be on the range of -255 to 255. My reason is the steady state error might be caused by an excessive output so the Setpoint-Feedback < 0
I've tried to do sth. like this, delete the old file and resave the new one:
if(ITerm > 255) ITerm= 255;
      else if(ITerm < -255) ITerm= -255;
After I run the program I got an error as shown in the picture
Is there any good way to do this? (I need the case that SP-FB<0 because I'm gonna apply it to a boost converter. When I the voltage is too much, I should be able to decrease it.)
Thanks
PS: Here is the code for PWM of the boost converter, the output is an Arduino Pin11, The feedback(Input) is the Pin (A0)
#include <PID_v1_corrected.h>
//Define Variables we'll be connecting to
double voltage=0.000;
double Setpoint, Output, Input, duty;
int Input_int=0;
double Kp=5, Ki=1.000, Kd=0.000;
const int sampleRate=1;
int Out_int=0;
PID myPID(&Input, &Output, &Setpoint,Kp,Ki,Kd, DIRECT);
//Specify the links and initial tuning parameters
  Input = analogRead(A0);
  pinMode(11, OUTPUT);
  TCCR2A = _BV(COM2A1) | _BV(WGM21) | _BV(WGM20);
  analogReference(DEFAULT);
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(sampleRate);
  myPID.SetTunings(Kp, Ki, Kd);
  voltage = 170.000;
  Setpoint= map_double(voltage, 0.000, 170.000, 0.000, 1023.000);
  Serial.print("Setpoint=");
  Serial.print(Setpoint);
  Serial.print("\n");
  Input_int = analogRead(A0);
  if (Input_int>=1023)
  Input_int=1023;
  else if (Input_int<=0)
  Input_int=0;
  Input = (double)Input_int;
  Serial.print("Input=");
  Serial.print(Input);
  Serial.print("\n");
  myPID.Compute();
  if (Output>255.000)
  Output=255.000;
  else if (Output<0.000)
  Output=0.000;
  Serial.print("Output=");
  Serial.print(Output);
  Serial.print("\n");
  Out_int=(int)Output;
  if (Out_int>250)
  Out_int=250;
  else if (Out_int<0)
  Out_int=0;
  OCR2A=Out_int;//Digital Pin 11 as an O/P
  Serial.print("OCR2A=");
  Serial.print(OCR2A);
  Serial.print("\n");
  duty = map_double(Output,0.000,255.000,0.000,100.000);
  Serial.print("Duty=");
  Serial.print(duty);
  Serial.print("\n\n");
  digitalWrite(13,HIGH);
double mapnew(double x, long in_min, long in_max, double out_min, double out_max)
  in_min = (double)in_min;
  in_max = (double)in_max;
  return ((x - in_min) * (out_max - out_min) / (in_max - in_min)) + out_min;
double map_double(double x, double in_min, double in_max, double out_min, double out_max)
  return ((x-in_min)*(out_max-out_min)/(in_max-in_min))+out_min;
This usually means that the program cannot find the library, it has not been #included, the library name and/or library files or folder do not match what is expected or the IDE has not been stopped/started after the library has been installed.
Do any of these sound possible in your case ?
As to you query about limits, I have successfully used the PID_v1 library with limits set to negative and positive values as in
trackPID.SetOutputLimits(-20,20);
