The loop () function and Firebase function doesn't work for Arduino
Hope you are well. I have a problem with my Arduino code. I have LED_Function() which is working in Loop () fine, what I want, when I send “ON” from the firebase (the Arduino has got the message) the LED_Function()
is stop working and execute the (DeviceStatus.stringData() == "ON")
conditions (continuous condition till I send OFF). When I send “OFF”, LED_Function() is stop working and the code execute (DeviceStatus.stringData() == "OFF") conditions. If I didn’t send anything, the LED_Function()
is working continuously. Please, I appreciate if you could help me in this matter. :frowning:
  LED_Function();
  Firebase.getString(DeviceStatus, "LED_STATUS/LED");
  Serial.print("The signal is:  ");
  Serial.println(DeviceStatus.stringData());
  if (DeviceStatus.stringData() == "ON") {
    Firebase.setFloat(DeviceStatus, "LED_STATUS/LED", 55);
    digitalWrite(led2, HIGH);
    digitalWrite(led, LOW);
    Serial.println("Led Turned ON");
  if (DeviceStatus.stringData() == "OFF") {
    digitalWrite(led2, LOW);
    digitalWrite(led, HIGH);
    Serial.println("Led Turned OFF");
void LED_Function() {
  int Detect = analogRead(SensorRec);
  if (isnan(Detect)) {
    Serial.println(F("Failed to read from Laser sensor!"));
    return;
  if (Detect < 300) {
    Serial.println("Laser Cut. Data is disptched to the Firebase!");
    digitalWrite(led5, LOW);
    digitalWrite(led7, LOW);
    float  val = 1.0;
    Serial.println(val);
  else {
    float   val = 2.0;
    digitalWrite(led7, HIGH);
the loop() loops. if you don't want to call LED_Function() at every loop, then you need to have some sort of Boolean variable (say callLedFunction) that remembers what to do or not and do if (callLedFunction) LED_Function(). the callLedFunction variable could be a global variable that you set to true or false when you get the right DeviceStatus.stringData() (I assume)
Thanks J-M-L for your reply,
However, the firebase sends only one time ON/OFF message. how to set the boolean to false or true?
I'm a bit unclear on what you do, but what I had in mind was something like this
  static bool callLedFunction = false; // or true, whatever initial value you want to have
  Serial.print(F("The signal is:  "));
    callLedFunction = true; // or false whatever makes sense
  } else if (DeviceStatus.stringData() == "OFF") {
    callLedFunction = false; // or true whatever makes sense
  if (callLedFunction) LED_Function();
