Hi all,
Does anyone know which LoRa module can be used on MKR Zero board? I am doing a project of designing a LoRa sender which can stay at sleep mode for the most time and wake up periodically to send the data.
The module I am using now is RFM95W, and the code is found from online https://randomnerdtutorials.com/esp32-lora-rfm95-transceiver-arduino-ide/but when I use the command of
LoRa.setPins(ss,rst,dio0);
The board cannot wake up from sleep mode (standby mode), I guess the problem is choosing a wrong module?
I was stuck in this problem for a long time. Please does anyone have some experience about using MKR Zero board to design a LoRa sender?
I also found that MKR WAN 1300 has a built-in LoRa function, however, I will need to add a Bluetooth module to the board later. Is MKR WAN 1300 capable of using the Bluetooth? Do I have to change to MKR WAN 1300?
