The meaning of (int)
Thank you.
I am trying to turn on LED D13 using <TimeLord.h>.
However, since the data type is a byte array type, I am looking for a way to convert it to an int.
It looks like you can take a serial value and change it to int type, but in the code below, “Serial.print((int) today[tl_hour]);” I don’t understand the part.
Question 1) What does the (int) part mean in particular?
Question 2) Is there a way to convert byte type array to int type integer in Arduino?
if (tardis.SunRise(today)) // if the sun will rise today (it might not, in the [ant]arctic)
    Serial.print("Sunrise: ");
    Serial.print(":");
    Serial.println((int) today[tl_minute]);
You can learn about it here (note there are two different syntax styles for type casts):
https://www.arduino.cc/reference/en/language/variables/conversion/intcast/
Thank you.
Good luck to you. :joy:
