The basic idea is having the lights on the Christmas Tree turning on everytime someone tweets "Merry Christmas".
It's still pretty much a prototype but you get the idea. Sometimes the live stream gets out of synch with the tweet overlays, but generally it stays on track.
The actual setup is really all based off a lot of relays running 12V 1W LED's. I started out with 10W halogens and after a few burnt tree branches I decided to try and find an LED which gave off as little heat as possible! It also meant a 20Amp powerpack could run all 30 lights.
Any feedback welcome! (I'm sure there is an easier way to wire this :)
Do you have any links to the type of LED you mentioned. I had a look around but just couldnt find something that would do the job. Would be good to know for next time!
Next time you could try using something like these: http://hackaday.com/2010/12/01/hacked-led-christmas-lights/ Essentially you can hack them so that they are individually addressable lights. You wouldn't need any other external components, just your arduino.
