The Serial.monitor attached, where the forword_motorSpeedA=131/ forword_motorSpeedB=255
came from even the xAxis=0 / yAxis=0
without Bluetooth connected?
need help please.
Thanks
Adam
#include <Bridge.h>
#include <BridgeClient.h>
#include <BridgeServer.h>
#include <BridgeSSLClient.h>
#include <BridgeUdp.h>
#include <Console.h>
#include <FileIO.h>
#include <HttpClient.h>
#include <Mailbox.h>
#include <Process.h>
#include <YunClient.h>
#include <YunServer.h>
#include <TimedAction.h> //this library is outdated and it won't work with the newest versions of Arduino. After you downloaded the library - https://playground.arduino.cc/Code/TimedAction/ - you must open the libraries folder, open the TimedAction folder, open the TimedAction.h file and change the 33/34 line (from #include "TimedAction.h" to #include "Arduino.h"). If it is already changed, then you shouldn't have any problems.
#include <Servo.h>
#define Start_Relay 12 /// WAS: #define Pin12 12
#define Stop_Relay 13 //// WAS: #define Pin13 13
char caracter;
uint8_t xAxis = 140, yAxis = 140;
////uint8_t xAxis, yAxis; // WAS: 140
uint8_t x = 0;
uint8_t y = 0;
uint8_t motorSpeedA = 0;
uint8_t motorSpeedB = 0;
#define enA 8
#define in1 4
#define in2 5
#define in3 6
#define in4 7
#define enB 9
//char caracter;
int temperature = 0;
int humidity = 0;
String tempera_humidity;
#define DHTPIN 2 // Digital pin connected to the DHT sensor
////////////////////////////////////////////////////////////////////////// 20211207:
uint8_t V0 = 510;
//// uint8_t Median = V0 / 2; ///// when connected to Joystick PAD use this line
uint8_t Median = 140;
uint8_t MedianL = Median - 10;
uint8_t MedianH = Median + 10;
///////////////////////////////////////////// add MCP4261
Matthew McMillan
@matthewmcmillan
http://matthewcmcmillan.blogspot.com
Created 12 Mar 2014
Digital Pot Control (MCP4251)
// set pin 10 as the slave select for the digital pot:
//const int slaveSelectPin = 10; // Uno
const int slaveSelectPin = 53; // Mega
const int shutdownPin = 49;
const int wiper0writeAddr = B00000000;
const int wiper1writeAddr = B00010000;
const int tconwriteAddr = B01000000;
const int tcon_0off_1on = B11110000;
const int tcon_0on_1off = B00001111;
const int tcon_0off_1off = B00000000;
const int tcon_0on_1on = B11111111;
uint8_t scurt = 500;
uint8_t lung = 3000;
uint8_t PotWiperVoltage0 = 0;
uint8_t RawVoltage0 = 0;
float Voltage0 = 0;
uint8_t PotWiperVoltage1 = 1;
uint8_t RawVoltage1 = 0;
float Voltage1 = 0;
///////////////////////////////////// OLED
int val, cnt = 0, v[8]; /// was: v[4];
int pos1 = 90, pos2 = 90, pos3 = 90, pos4 = 90;
int val1, val2, val3, val4;
int val5, val6, val7, val8; /// Add: val5, val6 , val7, val8
int timer1, timer2, timer3;
int timer5, timer6, timer7, timer8; /// add timer4, timer5, timer6, timer7
int Ok1 = 1, Ok2 = 1, Ok3 = 1;
int Ok5 = 1, Ok6 = 1, Ok7 = 1, Ok8 = 1; //add Ok4 = 1,Ok5=1, Ok6 = 1, Ok7 = 1;
int delayy2, delayx1, delayy1;
int delay5, delay6, delay7, delay8; // ADD: delay4, delay5, delay6, delay7;
void readbt() {
Serial1.available();
val = Serial1.read(); ////
cnt++;
v[cnt] = val;
if (v[1] == 1 && cnt == 3) { // J1 data: mark '1' + 'x'/'y' datas ;
cnt = 0;
if (v[1] != 1 && cnt == 2) { // J2 mark '2'+ 'y'; slider data: mark '3'+ thumbPosition data;
cnt = 0; // added: button_a: mark '5'+ 'a'; button_b: mark '6'+ 'b'; button_c: mark '7'+ 'c'; button_d: mark '8'+ 'd';
void program() {
timer1++;
timer2++;
timer3++;
timer5++;
timer6++;
timer7++;
timer8++;
TimedAction readbtThread = TimedAction(10, readbt);
TimedAction timerThread = TimedAction(1, program);
Serial1.begin(9600);
Serial.print("setup!");
Serial1.print("setup!");
Serial.print("File : "), Serial.println(__FILE__);
Serial.print("Date : "), Serial.println(__DATE__);
pinMode(Start_Relay, OUTPUT);
pinMode(Stop_Relay, OUTPUT);
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
Bluetooth();
Motor();
void Bluetooth()
if (Serial1.available()) {
while (Serial1.available() == 0);
readbtThread.check();
timerThread.check();
if (v[1] == 1) { // got the 'mark' of Joystick1(J1) indicated J1 is sending data
Ok1 = 0;
val1 = v[2];
val2 = v[3];
if (v[1] == 2) {
Ok2 = 0;
val3 = v[2];
if (v[1] == 3) {
Ok3 = 0;
val4 = v[2];
/////////////////////////////////////////////MDF
if (v[1] == 5) {
Ok5 = 0;
val5 = v[2];
if (v[1] == 6) {
Ok6 = 0;
val6 = v[2];
if (v[1] == 7) {
Ok7 = 0;
val7 = v[2];
if (v[1] == 8) {
Ok8 = 0;
val8 = v[2];
if (Ok5 == 0) {
if (v[1] == 5 && v[2] == 'a' ) { //// got data from: MAI: when {a} Click
Ok5 = 1;
Serial1.println("test t and r");
// Serial.println("test t and r");
//Serial.print("l21v[1]=");
//Serial.println(v[1]);
if (Ok6 == 0) {
if (v[1] == 6 && v[2] == 'b' ) { //// got data from: MAI: when {a} Click
Ok6 = 1;
// Serial1.println(v[2]);
Serial1.print("v[2]=");
void Motor()
xAxis = val1;
yAxis = val2;
//xAxis = 140;
//yAxis = 140;
Serial.print("xAxis=");
Serial.println(xAxis);
Serial.print("yAxis=");
Serial.println(yAxis);
if (xAxis > MedianL && xAxis < MedianH && yAxis > MedianL && yAxis < MedianH) { ////// if (xAxis > 130 && xAxis < 150 && yAxis > 130 && yAxis < 150) {
Stop();
if (yAxis > MedianL && yAxis < MedianH) {
if (xAxis < MedianL) {
turnRight();
motorSpeedA = map(xAxis, MedianL, 60, 0, 255);
motorSpeedB = map(xAxis, MedianL, 60, 0, 255);
if (xAxis > MedianH) {
turnLeft();
motorSpeedA = map(xAxis, MedianH, 220, 0, 255);
motorSpeedB = map(xAxis, MedianH, 220, 0, 255);
if (xAxis > MedianL && xAxis < MedianH) {
if (yAxis < MedianL) {
forword();
if (yAxis > MedianH) {
backword();
motorSpeedA = map(yAxis, MedianL, 60, 0, 255);
motorSpeedB = map(yAxis, MedianL, 60, 0, 255);
motorSpeedA = map(yAxis, MedianH, 220, 0, 255);
motorSpeedB = map(yAxis, MedianH, 220, 0, 255);
forword();
backword();
motorSpeedA = map(xAxis, MedianL, 60, 255, 50);
motorSpeedB = 255;
motorSpeedA = 255;
motorSpeedB = map(xAxis, MedianH, 220, 255, 50);
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
void forword() {
Serial.println("forword");
Serial1.println("forword");
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
Serial.print("forword_motorSpeedA=");
Serial.println(motorSpeedA);
Serial.print("forword_motorSpeedB=");
Serial.println(motorSpeedB);
void backword() {
Serial.println("backword");
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
Serial.print("backword_motorSpeedA=");
void turnRight() {
Serial.println("turnRight");
Serial.print("turnRight_motorSpeedA=");
void turnLeft() {
Serial.println("turnLeft");
Serial.print("turnLeft_motorSpeedA=");
void Stop() {
Serial.println("stop");
Serial Monitor:
lsetup!File : E:\ENGINEERING\design_info\DIY\SNOWREMOVEROBOT
\00_A_GPS_BT_Robot\CODE\JMMAGCOR_V5.3_post\JMMAGCOR_V5.3_post.ino
Date : Dec 9 2021
xAxis=0
yAxis=0
forword
forword_motorSpeedA=0
forword_motorSpeedB=0
xAxis=0
yAxis=0
forword
xAxis=0
yAxis=0
forword
xAxis=0
yAxis=0
forword
