The mouse does not work right click ?
Hi, I need help, I don't know how to modify the code so that the right mouse button works, when I turn on the steamvr application, it doesn't register a right click, what about it (it works normally on the desktop, but not in steamvr, I use mobile on vr) :frowning:
here is the code
#include <Mouse.h>
// Mouse buttons
#define MOUSE_SWITCH 2 // switch to turn on and off mouse control
#define MOUSE_LEFT_BTN 5
#define MOUSE_RIGHT_BTN 3
#define MOUSE_X_AXIS_INPT A0
#define MOUSE_Y_AXIS_INPT A1
#define MOUSE_SENSITIVITY 10
#define JOYSTICK_DEADZONE 1
#define LOOP_DELAY 5
// Operation modes for readMouseButton function
#define INPUT_LOW_MODE 1
#define INPUT_HIGH_MODE 2
#define INPUT_CHANGED_MODE 3
bool mouseActive = false; // whether or not to control the mouse
bool lastSwitchState = HIGH; // previous switch state
bool lastMouseRightState = HIGH;
bool lastMouseLeftState = HIGH;
pinMode(MOUSE_SWITCH, INPUT); // the switch pin
pinMode(MOUSE_LEFT_BTN, INPUT);
pinMode(MOUSE_RIGHT_BTN, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
void handleMouse() {
int xReading = analogRead(MOUSE_X_AXIS_INPT);
int yReading = analogRead(MOUSE_Y_AXIS_INPT);
// map the reading from the analog input range to the output range:
int mouseX = map(xReading, 0, 1024, -MOUSE_SENSITIVITY, MOUSE_SENSITIVITY);
int mouseY = map(yReading, 0, 1024, MOUSE_SENSITIVITY, -MOUSE_SENSITIVITY);
// if joystick moved out of the deadzone, move the mouse
if (mouseX > JOYSTICK_DEADZONE || mouseX < -JOYSTICK_DEADZONE || mouseY < -JOYSTICK_DEADZONE || mouseY > JOYSTICK_DEADZONE)
Mouse.move(mouseX, mouseY, 0);
  • Has folloving operation modes:
    1. INPUT_LOW_MODE - returns true when btn state changes from HIGH to LOW
    1. INPUT_HIGH_MODE - returns true when btn state changes from LOW to HIGH
    1. INPUT_CHANGED_MODE - return true when btn state changes from HIGH to LOW or from LOW to HIGH
      bool readMouseButton(int button, bool &lastState, unsigned char mode = INPUT_LOW_MODE) {
      bool ret = false;
      bool state = digitalRead(button);
      if (state != lastState) {
      if ((mode == INPUT_LOW_MODE && state == LOW) || (mode == INPUT_HIGH_MODE && state == HIGH) || mode == INPUT_CHANGED_MODE) {
      ret = true;
      lastState = state;
      return ret;
// check if mouse in ON/OFF
if (readMouseButton(MOUSE_SWITCH, lastSwitchState)) {
if (mouseActive) {
Mouse.end();
Mouse.begin();
mouseActive = true;
digitalWrite(LED_BUILTIN, mouseActive);
if (mouseActive) {
handleMouse();
// check left mouse btn
if (readMouseButton(MOUSE_LEFT_BTN, lastMouseLeftState, INPUT_CHANGED_MODE)) {
if (lastMouseLeftState == HIGH && !Mouse.isPressed()) {
Mouse.press();
} else if (lastMouseLeftState == LOW && Mouse.isPressed())
Mouse.release();
// check right mouse btn
if (readMouseButton(MOUSE_RIGHT_BTN, lastMouseRightState, INPUT_HIGH_MODE)) {
Mouse.press(MOUSE_RIGHT);
Mouse.release(MOUSE_RIGHT);
delay(LOOP_DELAY);
Does the issue only occur with the right mouse button, or do you have the same problem with any mouse button?
right button, left button works thank you in advance. :slight_smile:
As the mouse.press and mouse.release come directly after each other you may need a slight delay between them or you could try using mouse.click(MOUSE_RIGHT) that does both.
thanks, it works, but it doesn't work in steamvr (so i can't move) when i hold down the right button and the left button on a purchased mouse so can move but when i do it on my made mouse it doesn't work what about it? can it be solved somehow?
Why are left button and right button treated completely differently?!?
        Mouse.press();
        Mouse.release();
the code is not mine, i downloaded it from one side and now i will try to connect it to work for steamvr thank you in advance for the reply i don't know how to set up two buttons as on a mouse (i'm a beginner) :slight_smile:
thank you all that it already works, i had to try it more ways, it's solved :slight_smile:
I would still like to ask something how can I add more mouse buttons?
stromecek_555:
Find the documentation for the Mouse.press() and Mouse.release()functions. See what values can be passed to them. Your code already passes no argument for Left and MOUSE_RIGHT for Right so if there are other valid values they could be used for other buttons.
Thank you :slight_smile:
I have to ask why this code does not work, for me only the left button works, not the right button why? Thank you in advance for your reply
#include <Mouse.h>
#define left 3
#define right 2
  pinMode(left, INPUT);
  pinMode(right, INPUT);
  //initiate the Mouse library
  Mouse.begin();
  if (digitalRead(left) == HIGH) {
    Mouse.press();
    delay(20);
    if (digitalRead(left) == LOW) {
      Mouse.release();
      delay(100);
      if (digitalRead(right) == HIGH) {
        Mouse.press();
        if (digitalRead(right) == LOW) {
          Mouse.release();
    Mouse.press();
    delay(20);
      Mouse.release();
      delay(100);
        Mouse.press();
          Mouse.release();
Problems:
Your 'if' statements are nested very deeply so all the outer 'if' statements have to be true before the inner 'if' statements get to execute.
You only check for "digitalRead(left) == LOW" 20 milliseconds after it was HIGH.
You only check for "digitalRead(right) == HIGH" 100 milliseconds after you find that 'left' was HIGH and then LOW.
You use "Mouse.press()" and "Mouse.release()" for both left and right buttons. In your earlier code you used "Mouse.press(MOUSE_RIGHT)" and "Mouse.release(MOUSE_RIGHT)" for the right button.
You should add State Change Detection for the two buttons. See: File->Examples->02.Digital->StateChangeDetection for an example.
@stromecek_555
this seems very related to your other post...
please keep everything into one discussion..
