The possibility of making burglar alarm
hello. But the possibility of making burglar alarm is possible with arduino home. what should be the NBA. Sorry if I didn't explain clearly, because English is poor
Yes, it is.
The National Basketball Association should be abolished. If you mean something else, do not use abbreviations.
Next Best Alternative, I think...
What features are you wanting other than the obvious of reading intrusion sensors, a way to arm and disarm it? You probably want to consider the Mega which has lots of pins for inputs. A GSM shield allows sending text alerts etc, some sort of small keypad and display too.
How much work are you prepared to put into such a project?
"Burglar Alarm" is a term with very broad meaning. If you put a string across a doorway and attach a bell, that is a burglar alarm. But neither strings nor bells nor even strings with bells are are burglar alarms - it's when you put them across a doorway that they become so.
An arduino can work with many types of hardware, many types of sensors. It can work with proximity sensors, cameras, microphones, various kinds of switches - many things which if you put them across a doorway, they might perhaps serve as a burglar alarm.
What you have asked is too broad. It is like asking "can electronics be used to transmit images?". The answer is yes, but actually putting together some image-transmitting electronics requires quite a bit more detail.
