The problem on board ESP8266 WEMOS D1 R1 with module P10 LED
Hi Guys,
I have the problem on board ESP8266 WEMOS D1 R1 with module P10 LED.
after upload completed and run about one minutes, the found error CUT HERE FOR EXCEPTION DECODER see below picture. you can copy paste my code on below.
could you help me? i'm appreciate who is help me. Thanks
#include "NTPClient.h"
#include "ESP8266WiFi.h"
#include "WiFiUdp.h"
#include "HJS589.h"
#include <ESP8266WebServer.h>
#include "fonts/Mono5x7.h"
#include "fonts/bmz15x32.h"
#include "fonts/bmz10x16.h"
#include "fonts/angka6x13.h"
#include "fonts/TimesNewRoman12.h"
#include "fonts/ElektronMart6x8.h"
// SETUP DMD HJS589
#define DispS_WIDE 2
#define DispS_HIGH 1
HJS589 Disp(DispS_WIDE, DispS_HIGH);  // Jumlah Panel P10 yang digunakan (KOLOM,BARIS)
// SETUP region sd card
#include <SPI.h>
#include <SD.h>
File root;
const int chipSelect = 2;  // change ss spi to D9 wemos d1 R1
// end region
// SETUP RTC
#include <RTClib.h>
#include <Wire.h>
#include <Time.h>
#include <TimeLib.h>
RTC_DS3231 rtc;
// end region RTC
// SETUP JSON
#include <ArduinoJson.h>
File myFile;
// end JSON
ESP8266WebServer server(80);
static char *nama[] = { "Test" };
uint8_t tampilanjam;
// HJS589 P10 FUNGSI TAMBAHAN UNTUK NODEMCU ESP8266
void ICACHE_RAM_ATTR refresh() {
  Disp.refresh();
  timer0_write(ESP.getCycleCount() + 80000);
void Disp_init() {
  Disp.start();
  noInterrupts();
  timer0_isr_init();
  timer0_attachInterrupt(refresh);
  interrupts();
  Disp.clear();
// Global variable
const char *MESSAGE = "A";
int hh, mm, ss;
long nowMillis;
const char *ssid = "AR Project";
const char *password = "987987987987";
const long utcOffsetInSeconds = 25200;
char daysOfTheWeeks[7][12] = { "Minggu", "Senin", "Selasa", "Rabu", "Kamis", "Jumat", "Sabtu" };
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "asia.pool.ntp.org", utcOffsetInSeconds);
  server.begin();
  SetupSdCard();
  WiFi.begin(ssid, password);
    Serial.print(".");
  timeClient.begin();
  // DMD
  Disp_init();
  Disp.setBrightness(50);
  Disp.setFont(Mono5x7);
  Disp.drawText(0, 0, "Connecting.");
  Disp.drawText(0, 0, "Connecting..");
  Disp.drawText(0, 0, "Connecting...");
  Disp.drawText(0, 0, "Connecting....!");
  Disp.clear();
  SetupRTC();
  if ((WiFi.status() == WL_CONNECTED)) {
    server.handleClient();
    // TeksJalanNama();
    // delay(10000);
    RunningTextLeftoRight(0, 10);
    time_t TimeRTC = LoopRTC();
    Serial.println(1);
void RunningTextLeftoRight(long from, long to) {
  for (int i = from; i <= to; i++) {
    Disp.drawText(0, 0, MESSAGE);
    Disp.drawText(i, 8, "B");
    delayInLoop(200);
    Disp.clear();
    TampilanJamP10();
void TampilanJamP10() {
  timeClient.update();
  hh = timeClient.getHours();
  mm = timeClient.getMinutes();
  ss = timeClient.getSeconds();
  // Serial.print(daysOfTheWeek[timeClient.getDay()]);
  //  Serial.print(", ");
  //  Serial.print(hh);
  //  Serial.print(":");
  //  Serial.print(mm);
  //  Serial.println(ss);
  char BuffH1[20];
  char BuffH2[20];
  char BuffM1[20];
  char BuffM2[20];
  char BuffD1[20];
  char BuffD2[20];
  int s1, s2, m1, m2, h1, h2;
  s1 = ss % 10 / 1;
  s2 = ss % 100 / 10;
  m1 = mm % 10 / 1;
  m2 = mm % 100 / 10;
  h1 = hh % 10 / 1;
  h2 = hh % 100 / 10;
  sprintf(BuffD1, "%.1d", s1);
  sprintf(BuffD2, "%.1d", s2);
  sprintf(BuffM1, "%.1d", m1);
  sprintf(BuffM2, "%.1d", m2);
  sprintf(BuffH1, "%.1d", h1);
  sprintf(BuffH2, "%.1d", h2);
  Disp.setFont(TimesNewRoman12);
  Disp.drawText(93, 0, BuffH2);
  Disp.drawText(100, 0, BuffH1);
  Disp.drawText(109, 0, ":");
  Disp.drawText(112, 0, BuffM2);
  Disp.drawText(120, 0, BuffM1);
  //  Disp.drawText(86, 0, BuffD2);
  //  Disp.drawText(98, 0, BuffD1);
  //  Disp.drawCircle(47, 3, 2);
  //  Disp.drawCircle(47, 12, 2);
  //  Disp.drawCircle(80, 3, 2);
  //  Disp.drawCircle(80, 12, 2);
  //  Disp.drawCircle(47, 3, 1);
  //  Disp.drawCircle(47, 12, 1);
  //  Disp.drawCircle(80, 3, 1);
  //  Disp.drawCircle(80, 12, 1);
  //  Disp.drawCircle(47, 3, 0);
  //  Disp.drawCircle(47, 12, 0);
  //  Disp.drawCircle(80, 3, 0);
  //  Disp.drawCircle(80, 12, 0);
  //  Disp.drawLine(0, 0, 0, 15, 1);
  //  Disp.drawLine(15, 0, 15, 15, 1);
  //  Disp.drawLine(0, 0, 15, 0, 1);
  //  Disp.drawLine(0, 15, 15, 15, 1);
  //  Disp.drawLine(2, 2, 4, 4, 1);
  //  Disp.drawLine(4, 2, 2, 4, 1);
  //  Disp.drawLine(11, 2, 13, 4, 1);
  //  Disp.drawLine(13, 2, 11, 4, 1);
  //  Disp.drawLine(2, 11, 4, 13, 1);
  //  Disp.drawLine(4, 11, 2, 13, 1);
  //  Disp.drawLine(11, 11, 13, 13, 1);
  //  Disp.drawLine(13, 11, 11, 13, 1);
  //  Disp.drawLine(6, 6, 9, 9, 1);
  //  Disp.drawLine(6, 9, 9, 6, 1);
  //  Disp.drawLine(112, 0, 112, 15, 1);
  //  Disp.drawLine(127, 0, 127, 15, 1);
  //  Disp.drawLine(112, 0, 127, 0, 1);
  //  Disp.drawLine(112, 15, 127, 15, 1);
  //  Disp.drawLine(114, 2, 116, 4, 1);
  //  Disp.drawLine(116, 2, 114, 4, 1);
  //  Disp.drawLine(123, 2, 125, 4, 1);
  //  Disp.drawLine(125, 2, 123, 4, 1);
  //  Disp.drawLine(114, 11, 116, 13, 1);
  //  Disp.drawLine(116, 11, 114, 13, 1);
  //  Disp.drawLine(123, 11, 125, 13, 1);
  //  Disp.drawLine(125, 11, 123, 13, 1);
  //  Disp.drawLine(118, 6, 121, 9, 1);
  //  Disp.drawLine(118, 9, 121, 6, 1);
void SetupRTC() {
  Wire.begin(4, 5);  // Setting wire (5 untuk SDA dan 4 untuk SCL)
  rtc.begin();
  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));  // Setting Time
  // Kalian dapat menambahkan bagian dibawah ini untuk set manual jam
  // rtc.adjust(DateTime(2024, 3, 12, 17, 34, 0));
void SetupSdCard() {
  Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  root = SD.open("/");
  printDirectory(root, 0);
  Serial.println("done!");
  loadDataSD();
void printDirectory(File dir, int numTabs) {
  while (true) {
    File entry = dir.openNextFile();
    if (!entry) {
      // no more files
    for (uint8_t i = 0; i < numTabs; i++) {
      Serial.print('\t');
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println("/");
      printDirectory(entry, numTabs + 1);
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.print(entry.size(), DEC);
      time_t cr = entry.getCreationTime();
      time_t lw = entry.getLastWrite();
      struct tm *tmstruct = localtime(&cr);
      Serial.printf("\tCREATION: %d-%02d-%02d %02d:%02d:%02d", (tmstruct->tm_year) + 1900, (tmstruct->tm_mon) + 1, tmstruct->tm_mday, tmstruct->tm_hour, tmstruct->tm_min, tmstruct->tm_sec);
      tmstruct = localtime(&lw);
      Serial.printf("\tLAST WRITE: %d-%02d-%02d %02d:%02d:%02d\n", (tmstruct->tm_year) + 1900, (tmstruct->tm_mon) + 1, tmstruct->tm_mday, tmstruct->tm_hour, tmstruct->tm_min, tmstruct->tm_sec);
    entry.close();
String getValue(String data, char separator, int index) {
  int found = 0;
  int strIndex[] = { 0, -1 };
  int maxIndex = data.length() - 1;
  for (int i = 0; i <= maxIndex && found <= index; i++) {
    if (data.charAt(i) == separator || i == maxIndex) {
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
void loadDataSD() {
  JsonObject obj;
  DynamicJsonDocument doc(8192);
  File file = SD.open("Test1.txt");
  if (!file) {
    Serial.println(F("Failed to create file, probably not exists"));
    Serial.println(F("Create an empty one!"));
    obj = doc.to<JsonObject>();
    // Extract each characters by one by one
    //    while (file.available()) {
    //      Serial.print((char) file.read());
    //    Serial.println();
    DeserializationError error = deserializeJson(doc, file);
    if (error) {
      Serial.println(F("Error parsing JSON "));
      Serial.println(error.c_str());
      Serial.println(F("No error "));
      obj = doc["data"].as<JsonObject>();
      for (JsonPair data_item : obj) {
        const char *data_item_key = data_item.key().c_str();                 // "2024-03-01", "2024-03-02", "2024-03-03", ...
        const char *data_item_value_tanggal = data_item.value()["tanggal"];  // "Jumat, 01/03/2024", "Sabtu, ...
        const char *data_item_value_imsak = data_item.value()["imsak"];      // "04:34", "04:34", "04:34", "04:34", ...
        const char *data_item_value_subuh = data_item.value()["subuh"];      // "04:44", "04:44", "04:44", "04:44", ...
        const char *data_item_value_terbit = data_item.value()["terbit"];    // "05:56", "05:56", "05:56", "05:56", ...
        const char *data_item_value_dhuha = data_item.value()["dhuha"];      // "06:24", "06:24", "06:24", "06:24", ...
        const char *data_item_value_dzuhur = data_item.value()["dzuhur"];    // "12:10", "12:10", "12:09", "12:09", ...
        const char *data_item_value_ashar = data_item.value()["ashar"];      // "15:12", "15:11", "15:10", "15:09", ...
        const char *data_item_value_maghrib = data_item.value()["maghrib"];  // "18:16", "18:16", "18:15", ...
        const char *data_item_value_isya = data_item.value()["isya"];
        //        Serial.println(data_item_key);
        //        Serial.println(data_item_value_tanggal);
        //        Serial.println(data_item_value_imsak);
        //        Serial.println(data_item_value_subuh);
        //        Serial.println(data_item_value_terbit);
        //        Serial.println(data_item_value_dhuha);
        //        Serial.println(data_item_value_dzuhur);
        //        Serial.println(data_item_value_ashar);
        //        Serial.println(data_item_value_maghrib);
        //        Serial.println(data_item_value_isya);
  // Close the file
  file.close();
  //  String Tahun = getValue(data_item_key, '-', 1);
  //  String Bln = getValue(data_item_key, '-', 2);
  //  String Tanggal = getValue(data_item_key, '-', 3);
  //  Serial.println(Tahun);
  //  Serial.println(Bln);
  //  Serial.println(Tanggal);
time_t tmConvert_t(int YYYY, byte MM, byte DD, byte hh, byte mm, byte ss) {
  tmElements_t tmSet;
  tmSet.Year = YYYY - 1970;
  tmSet.Month = MM;
  tmSet.Day = DD;
  tmSet.Hour = hh;
  tmSet.Minute = mm;
  tmSet.Second = ss;
  return makeTime(tmSet);
time_t LoopRTC() {
  DateTime now = rtc.now();
  //  Serial.print("Hari : ");
  //  Serial.println(daysOfTheWeeks[now.dayOfTheWeek()]);
  //  Serial.print("Tanggal : ");
  //  String Date = String(now.year()) + "-" + String(now.month()) + "-" + String(now.day());
  //  Serial.print(Date);
  //  Serial.print("Jam : ");
  //  Serial.print(now.hour());       //Menampilkan Jam
  //  Serial.print(now.minute());     //Menampilkan Menit
  //  Serial.print(now.second());     //Menampilkan Detik
  time_t timeRTC = tmConvert_t(now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
  return timeRTC;
void delayInLoop(long seconds) {
  unsigned long start = millis();
  while (millis() - start < seconds) {
    yield();
void textCenter(int y, String Msg) {
  int center = int((Disp.width() - Disp.textWidth(Msg)) / 2);
  Disp.drawText(center, y, Msg);
void TeksJalanNama() {
  static uint32_t pM;
  static uint32_t x;
  static uint32_t Speed = 50;
  int width = Disp.width();
  Disp.setFont(ElektronMart6x8);
  textCenter(0, "#");
  Disp.drawRect(0, 6, Disp.width(), 6, 1, 1);
  int fullScroll = Disp.textWidth(nama[0]) + width;
  if ((millis() - pM) > Speed) {
    pM = millis();
    if (x < fullScroll) {
      ++x;
      x = 0;
      Disp.clear();
      tampilanjam = 3;
    Disp.drawText(width - x, 8, nama[0]);
Hi @ar_project. When the ESP8266 throws an exception like this, you can copy the exception message from the Arduino IDE Serial Monitor into a special tool called an "exception decoder". This will translate it into something human readable that will point you to the specific parts of your sketch program code that triggered the exception. You can then closely examine that specific code to try to understand what is wrong with it.
If you are using Arduino IDE 1.x, you can install this Tool that adds an exception decoder to the IDE:
If you are using Arduino IDE 2.x, use this extension instead of the Arduino IDE 1.x-specific tool I linked above:
Second method to narrow down what is causing the exception is to add serial prints everywhere in your code to see what commands are executed properly and at which point in your code the exception occurs
which means at some point the next serial print does not appear in the serial monitor
