I have the following problem in my arduino project. When I power the 2 arduino master and slave via usb, the LCD lights up, I press the start button and the 3 parameters appear on the LCD, when I press the stop button on the LCD it displays system stopped, from this moment when I want to restart the project and press the start button again nothing happens, instead if I press the stop button on the lcd again the 3 parameters reappear, practically when the start button is pressed again the circuit should restart and the parameters reappear on the lcd, to nothing happens to me, it restarts if I press the stop button again. Thanks in advance for your help.
Code master:
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define DHTPIN A1
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
#define SS 10
#define LED_RED_PIN 8
#define BUTTON_START_PIN 7
bool isRunning = false;
unsigned long lastButtonPressTime = 0;
unsigned long debounceDelay = 50;
dht.begin();
pinMode(SS, OUTPUT);
pinMode(LED_RED_PIN, OUTPUT);
pinMode(BUTTON_START_PIN, INPUT_PULLUP);
digitalWrite(SS, HIGH);
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV8);
void sendFloat(float value) {
byte *data = (byte*)&value;
for (int i = 0; i < sizeof(float); i++) {
SPI.transfer(data[i]);
delay(10); // Mici întârzieri pentru stabilizarea transferului
// Citeste starea butonului de pornire
bool startButtonPressed = digitalRead(BUTTON_START_PIN) == LOW;
if (startButtonPressed && (millis() - lastButtonPressTime) > debounceDelay) {
isRunning = !isRunning; // Toggle the running state
lastButtonPressTime = millis();
if (isRunning) {
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
float current = analogRead(A0) * (5.0 / 1023.0);
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.print(", Humidity: ");
Serial.print(humidity);
Serial.print(", Current: ");
Serial.println(current);
digitalWrite(LED_RED_PIN, HIGH); // Aprinde LED-ul roșu
digitalWrite(SS, LOW);
delay(10);
sendFloat(temperature);
sendFloat(humidity);
sendFloat(current);
digitalWrite(LED_RED_PIN, LOW); // Stinge LED-ul roșu
Code slave:
#include <Wire.h>
#include <SPI.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define SS 10
#define LED_GREEN_PIN 7
#define BUTTON_STOP_PIN 6
bool isRunning = false; // Start with the system stopped
unsigned long lastDebounceTime = 0;
lcd.init();
lcd.backlight();
lcd.clear(); // Clear the LCD at startup
pinMode(SS, INPUT_PULLUP);
pinMode(SCK, INPUT);
pinMode(MOSI, INPUT);
pinMode(MISO, OUTPUT);
pinMode(LED_GREEN_PIN, OUTPUT);
pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
SPCR = (1 << SPE); // Enable SPI slave
float receiveFloat() {
byte data[sizeof(float)];
while (!(SPSR & (1 << SPIF))); // Așteaptă finalizarea recepției
data[i] = SPDR; // Citește byte-ul primit
return *(float*)data; // Convertește byte-urile în float
int buttonState = digitalRead(BUTTON_STOP_PIN);
if (buttonState == LOW && (millis() - lastDebounceTime) > debounceDelay) {
lastDebounceTime = millis();
if (isRunning) {
while (digitalRead(SS)) delay(1); // Așteaptă ca SS să fie LOW
float temperature = receiveFloat();
float humidity = receiveFloat();
float current = receiveFloat();
Serial.print("Received Temperature: ");
digitalWrite(LED_GREEN_PIN, HIGH); // Aprinde LED-ul verde
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("T: ");
lcd.print(temperature);
lcd.print(" H: ");
lcd.print(humidity);
lcd.setCursor(0, 1);
lcd.print("C: ");
lcd.print(current);
digitalWrite(LED_GREEN_PIN, LOW); // Stinge LED-ul verde
while (!digitalRead(SS)) delay(1); // Așteaptă ca SS să fie HIGH
lcd.clear(); // Curăță LCD-ul
lcd.print("System Stopped");
// Oprește LED-ul verde dacă sistemul este oprit
