The problem with the Modbus library and MAX485
I am a beginner in Arduino
I am using the Modbus library Modbus Library and I want to use the sample project from the library.
This code compile succesfull
#include <SimpleModbusSlave.h>
#define  LED 9
enum
  ADC_VAL,
  PWM_VAL,
  HOLDING_REGS_SIZE
unsigned int holdingRegs[HOLDING_REGS_SIZE];
  modbus_configure(&Serial, 9600, SERIAL_8N2, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  modbus_update_comms(9600, SERIAL_8N2, 1);
    pinMode(LED, OUTPUT);
  modbus_update();
  holdingRegs[ADC_VAL] = analogRead(A0);
  analogWrite(LED, holdingRegs[PWM_VAL]>>2);
Schematic
When i upload this code to arduino i giving error like this:
avrdude: stk500_getsync(): not in sync: resp=0x00
To connect the Arduino using the Modbus protocol with Laptop i use Converter rs485 to USB (pic related)
Converter ch340
if i unplug Converter it's giving that same error.
Please tell me, what im doing wrong?
Hi, Try to disconnect from arduino Pin 0 and Pin 1 while you upload the new program from Arduino Ide
Thanks for the reply. I did this and now upload correctly.
Unfortunately, I now have another problem. I used a program modscan64 to test communication. I get the message:
** MODBUS Message TIME-OUT **
Screenshot Modscan64 with my configuration
This is the Device Manager:
COM Ports
What am I doing wrong?
