the random command is generating no random number.
#include <LiquidCrystal.h>
void display_a(float a[4][1]);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 lcd.begin(16,2);
 lcd.clear();
  float a[4][1]={0,1,2,3};
for(int i=0;i<4;i++){
   a[i][0]=random(0,1);
display_a(a);
void display_a(float a[4][1]){
  for(int i=0;i<=3;i++){
  lcd.setCursor(0,0);
  lcd.print("V=");
  lcd.setCursor(5,0);
  lcd.print(a[i][0]);
[\code]
it would be worth your while to read what the function "random()" does.
Look here
https://www.arduino.cc/en/Reference/Random
Returns
a random number between min and max-1 (long)
So random(0,1) returns a number between 0 and 0 - you want random(0,2).
Also, if you want different results each time it runs, you need to feed something to randomSeed() - the go-to trick is to do randomSeed(analogRead(pin)); in setup, where the 'pin' is a floating input.. randomSeed() - Arduino Reference
Groove:
Look here
But, those zeroes are randomly distributed!!
