The loop repeat call interval may be 2ms.
I looked up the Arduino overhead in the sketch below.
//#define MILLI
#ifdef MILLI
#define TIME millis
#else
#define TIME micros
#endif
volatile unsigned long oldTimerVal;
volatile unsigned long defTimerVal;
volatile unsigned long defMaxOver;
unsigned long loopCount = 0;
#ifdef MILLI
Serial.println(" start Milli");
#else
Serial.println(" start Micro");
#endif
Serial.flush();
oldTimerVal = TIME();
unsigned long timerVal;
loopCount++;
timerVal = TIME();
defTimerVal = timerVal - oldTimerVal;
#if 1 // Milli check
if(defMaxOver < defTimerVal){
#else
if(defTimerVal > 1){
#endif
defMaxOver = defTimerVal;
Serial.print(" loop count:"); Serial.print(loopCount);
#ifdef MILLI
Serial.print(" Milli:");
#else
Serial.print(" Micro:");
#endif
Serial.print(timerVal);
Serial.print(" def:"); Serial.print(defTimerVal);
Serial.print(" old:"); Serial.print(oldTimerVal);
Serial.flush();
else {
oldTimerVal = timerVal;
The execution result is as follows.
start Micro
loop count:1 Micro:1212 def:4 old:1208
loop count:2 Micro:4724 def:8 old:4716
loop count:12 Micro:8308 def:12 old:8296
loop count:50 Micro:12296 def:16 old:12280
The first time is from setup to loop, and the second time is from loop to loop. I understand that the 12th and 50th times are Arduino overheads.
I think it's a UART interrupt and a timer interrupt.
Next, the execution result when #define MILLI is enabled is as follows.
start Milli
loop count:145 Milli:2 def:1 old:1
loop count:6610 Milli:43 def:2 old:41
Since the error of millis () is + 1ms, it is understood that the 145th display is when an error occurs.
There is a display with a difference of 2ms at the 6610th time.
The maximum value of micro () is 16 macroseconds, so the error should not be 2 milliseconds.
Is there an error in my program?
In addition, when displaying with a difference of 1 ms or more, it will be as follows. (Corrected to #if 1 // Milli check)
start Milli
loop count:7823 Milli:43 def:2 old:41
loop count:15232 Milli:86 def:2 old:84
loop count:22433 Milli:128 def:2 old:126
loop count:29793 Milli:171 def:2 old:169
loop count:37153 Milli:214 def:2 old:212
loop count:44322 Milli:256 def:2 old:254
loop count:51683 Milli:299 def:2 old:297
loop count:59043 Milli:342 def:2 old:340
loop count:66212 Milli:384 def:2 old:382
loop count:73572 Milli:427 def:2 old:425
loop count:80933 Milli:470 def:2 old:468
It occurs every 42,43ms.
