The round TFT 1.28" GC9A01 tested out error of
Error compiling for board AI Thinker ESP32-CAM. .
The sketch from example of GFX_Library_for_Arduino.
Questions:
  1. the sketch compiling passed and uploaded into Arduino UNO + GC9A01 does't work;
  2. the sketch compiling passed and uploaded into NANO + GC9A01 work well;
  3. the sketch compiling error for AI Thinker and ESP32 Dev Module
    why?
    Thanks for help.
    Adam
#include <Arduino_GFX_Library.h>
#define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
//// Arduino_GFX *gfx = new Arduino_ILI9341(bus, DF_GFX_RST, 0 /* rotation */, false /* IPS */);
Arduino_GFX *gfx = new Arduino_GC9A01(bus, 7 /* DF_GFX_RST*/, 0 /* rotation */, true /* IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) */
 * End of Arduino_GFX setting
#define BACKGROUND BLACK
#define MARK_COLOR WHITE
#define SUBMARK_COLOR DARKGREY // LIGHTGREY
#define HOUR_COLOR WHITE
#define MINUTE_COLOR BLUE // LIGHTGREY
#define SECOND_COLOR RED
#define SIXTIETH 0.016666667
#define TWELFTH 0.08333333
#define SIXTIETH_RADIAN 0.10471976
#define TWELFTH_RADIAN 0.52359878
#define RIGHT_ANGLE_RADIAN 1.5707963
static uint8_t conv2d(const char *p)
    uint8_t v = 0;
    return (10 * (*p - '0')) + (*++p - '0');
static int16_t w, h, center;
static int16_t hHandLen, mHandLen, sHandLen, markLen;
static float sdeg, mdeg, hdeg;
static int16_t osx = 0, osy = 0, omx = 0, omy = 0, ohx = 0, ohy = 0; // Saved H, M, S x & y coords
static int16_t nsx, nsy, nmx, nmy, nhx, nhy;                         // H, M, S x & y coords
static int16_t xMin, yMin, xMax, yMax;                               // redraw range
static int16_t hh, mm, ss;
static unsigned long targetTime; // next action time
static int16_t *cached_points;
static uint16_t cached_points_idx = 0;
static int16_t *last_cached_point;
void setup(void)
    gfx->begin();
    gfx->fillScreen(BACKGROUND);
#ifdef GFX_BL
    pinMode(GFX_BL, OUTPUT);
    digitalWrite(GFX_BL, HIGH);
#endif
    // init LCD constant
    w = gfx->width();
    h = gfx->height();
    if (w < h)
        center = w / 2;
        center = h / 2;
    hHandLen = center * 3 / 8;
    mHandLen = center * 2 / 3;
    sHandLen = center * 5 / 6;
    markLen = sHandLen / 6;
    cached_points = (int16_t *)malloc((hHandLen + 1 + mHandLen + 1 + sHandLen + 1) * 2 * 2);
    // Draw 60 clock marks
    draw_round_clock_mark(
    // draw_square_clock_mark(
        center - markLen, center,
        center - (markLen * 2 / 3), center,
        center - (markLen / 2), center);
    hh = conv2d(__TIME__);
    mm = conv2d(__TIME__ + 3);
    ss = conv2d(__TIME__ + 6);
    targetTime = ((millis() / 1000) + 1) * 1000;
    unsigned long cur_millis = millis();
    if (cur_millis >= targetTime)
        targetTime += 1000;
        ss++; // Advance second
        if (ss == 60)
            ss = 0;
            mm++; // Advance minute
            if (mm > 59)
                mm = 0;
                hh++; // Advance hour
                if (hh > 23)
                    hh = 0;
    // Pre-compute hand degrees, x & y coords for a fast screen update
    sdeg = SIXTIETH_RADIAN * ((0.001 * (cur_millis % 1000)) + ss); // 0-59 (includes millis)
    nsx = cos(sdeg - RIGHT_ANGLE_RADIAN) * sHandLen + center;
    nsy = sin(sdeg - RIGHT_ANGLE_RADIAN) * sHandLen + center;
    if ((nsx != osx) || (nsy != osy))
        mdeg = (SIXTIETH * sdeg) + (SIXTIETH_RADIAN * mm); // 0-59 (includes seconds)
        hdeg = (TWELFTH * mdeg) + (TWELFTH_RADIAN * hh);   // 0-11 (includes minutes)
        mdeg -= RIGHT_ANGLE_RADIAN;
        hdeg -= RIGHT_ANGLE_RADIAN;
        nmx = cos(mdeg) * mHandLen + center;
        nmy = sin(mdeg) * mHandLen + center;
        nhx = cos(hdeg) * hHandLen + center;
        nhy = sin(hdeg) * hHandLen + center;
        // redraw hands
        redraw_hands_cached_draw_and_erase();
        ohx = nhx;
        ohy = nhy;
        omx = nmx;
        omy = nmy;
        osx = nsx;
        osy = nsy;
        delay(1);
void draw_round_clock_mark(int16_t innerR1, int16_t outerR1, int16_t innerR2, int16_t outerR2, int16_t innerR3, int16_t outerR3)
  float x, y;
  int16_t x0, x1, y0, y1, innerR, outerR;
  uint16_t c;
  for (uint8_t i = 0; i < 60; i++)
    if ((i % 15) == 0)
      innerR = innerR1;
      outerR = outerR1;
      c = MARK_COLOR;
    else if ((i % 5) == 0)
      innerR = innerR2;
      outerR = outerR2;
      c = MARK_COLOR;
      innerR = innerR3;
      outerR = outerR3;
      c = SUBMARK_COLOR;
    mdeg = (SIXTIETH_RADIAN * i) - RIGHT_ANGLE_RADIAN;
    x = cos(mdeg);
    y = sin(mdeg);
    x0 = x * outerR + center;
    y0 = y * outerR + center;
    x1 = x * innerR + center;
    y1 = y * innerR + center;
    gfx->drawLine(x0, y0, x1, y1, c);
void draw_square_clock_mark(int16_t innerR1, int16_t outerR1, int16_t innerR2, int16_t outerR2, int16_t innerR3, int16_t outerR3)
    float x, y;
    uint16_t c;
        if ((i % 15) == 0)
            innerR = innerR1;
            outerR = outerR1;
            c = MARK_COLOR;
            innerR = innerR2;
            outerR = outerR2;
            c = MARK_COLOR;
            innerR = innerR3;
            outerR = outerR3;
            c = SUBMARK_COLOR;
        if ((i >= 53) || (i < 8))
            x = tan(SIXTIETH_RADIAN * i);
            x0 = center + (x * outerR);
            y0 = center + (1 - outerR);
            x1 = center + (x * innerR);
            y1 = center + (1 - innerR);
        else if (i < 23)
            y = tan((SIXTIETH_RADIAN * i) - RIGHT_ANGLE_RADIAN);
            x0 = center + (outerR);
            y0 = center + (y * outerR);
            x1 = center + (innerR);
            y1 = center + (y * innerR);
        else if (i < 38)
            x0 = center - (x * outerR);
            y0 = center + (outerR);
            x1 = center - (x * innerR);
            y1 = center + (innerR);
        else if (i < 53)
            x0 = center + (1 - outerR);
            y0 = center - (y * outerR);
            x1 = center + (1 - innerR);
            y1 = center - (y * innerR);
void redraw_hands_cached_draw_and_erase()
    gfx->startWrite();
    draw_and_erase_cached_line(center, center, nsx, nsy, SECOND_COLOR, cached_points, sHandLen + 1, false, false);
    draw_and_erase_cached_line(center, center, nhx, nhy, HOUR_COLOR, cached_points + ((sHandLen + 1) * 2), hHandLen + 1, true, false);
    draw_and_erase_cached_line(center, center, nmx, nmy, MINUTE_COLOR, cached_points + ((sHandLen + 1 + hHandLen + 1) * 2), mHandLen + 1, true, true);
    gfx->endWrite();
void draw_and_erase_cached_line(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t color, int16_t *cache, int16_t cache_len, bool cross_check_second, bool cross_check_hour)
#if defined(ESP8266)
    yield();
#endif
    bool steep = _diff(y1, y0) > _diff(x1, x0);
    if (steep)
        _swap_int16_t(x0, y0);
        _swap_int16_t(x1, y1);
    int16_t dx, dy;
    dx = _diff(x1, x0);
    dy = _diff(y1, y0);
    int16_t err = dx / 2;
    int8_t xstep = (x0 < x1) ? 1 : -1;
    int8_t ystep = (y0 < y1) ? 1 : -1;
    x1 += xstep;
    int16_t x, y, ox, oy;
    for (uint16_t i = 0; i <= dx; i++)
        if (steep)
            x = y0;
            y = x0;
            x = x0;
            y = y0;
        ox = *(cache + (i * 2));
        oy = *(cache + (i * 2) + 1);
        if ((x == ox) && (y == oy))
            if (cross_check_second || cross_check_hour)
                write_cache_pixel(x, y, color, cross_check_second, cross_check_hour);
            if ((ox > 0) || (oy > 0))
                write_cache_pixel(ox, oy, BACKGROUND, cross_check_second, cross_check_hour);
            *(cache + (i * 2)) = x;
            *(cache + (i * 2) + 1) = y;
        if (err < dy)
            y0 += ystep;
            err += dx;
        err -= dy;
        x0 += xstep;
    for (uint16_t i = dx + 1; i < cache_len; i++)
        *(cache + (i * 2)) = 0;
        *(cache + (i * 2) + 1) = 0;
void write_cache_pixel(int16_t x, int16_t y, int16_t color, bool cross_check_second, bool cross_check_hour)
    int16_t *cache = cached_points;
    if (cross_check_second)
        for (uint16_t i = 0; i <= sHandLen; i++)
            if ((x == *(cache++)) && (y == *(cache)))
                return;
            cache++;
    if (cross_check_hour)
        cache = cached_points + ((sHandLen + 1) * 2);
        for (uint16_t i = 0; i <= hHandLen; i++)
                return;
            cache++;
    gfx->writePixel(x, y, color);
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None"
Multiple libraries were found for "Arduino_GFX_Library.h"
 Used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\GFX_Library_for_Arduino
 Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino_GFX-master
In file included from C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\GFX_Library_for_Arduino\src/Arduino_GFX_Library.h:4,
                 from E:\ENGINEERING\DIY\Electronic\ARDUINO\LCD\00_LCD_Module_code\Clock_M\Clock_M.ino:26:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\GFX_Library_for_Arduino\src/Arduino_DataBus.h:138:10: fatal error: lcd_cam_reg.h: No such file or directory
 #include <lcd_cam_reg.h>
compilation terminated.
exit status 1
Error compiling for board ESP32 Dev Module.
option enabled in File -> Preferences.
