The router IP address cannot be changed
I tried changing the IP address of the WiFi connected to the router, when I applied it the IP address wouldn't change. What is wrong?
#include <WiFi.h>
#include <ModbusIP_ESP8266.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <FS.h>
#include <SPIFFS.h>
// WiFi credentials
String routerSSID = "";
String routerPassword = "";
// AP Mode credentials
const char* apSSID = "ESP_AP";
const char* apPassword = "password123";
// Static IP configuration
IPAddress staticIP;
IPAddress gateway;
IPAddress subnet(255, 255, 255, 0);
IPAddress dns1(8, 8, 8, 8);  // Google DNS
IPAddress dns2(8, 8, 4, 4);  // Google DNS alternate
bool useStaticIP = false;
// Modbus TCP server
ModbusIP mb;
const int modbusPort = 502; // Default Modbus port
// GPIO pin definitions
const int touchPin1 = T0;
const int touchPin2 = T3;
const int touchPin3 = T6;
const int touchPin4 = T7;
const int outputPin = 4; // Using GPIO4 as output
const int buttonPin = 5; // Using GPIO5 as button pin
// Modbus registers
const int REG_TOUCH1 = 0;
const int REG_TOUCH2 = 1;
const int REG_TOUCH3 = 2;
const int REG_TOUCH4 = 3;
const int REG_OUTPUT = 4;
AsyncWebServer server(80);
bool isServerRunning = false;
unsigned long lastWiFiCheckMillis = 0;
const long wifiCheckInterval = 30000; // Check WiFi connection every 30 seconds
int failedWiFiConnections = 0;
bool isAPMode = false;
void resetSettings() {
  routerSSID = "";
  saveWiFiCredentials();
  saveStaticIPConfig();
  Serial.println("Semua pengaturan direset ke nilai default");
void loadWiFiCredentials() {
  if (SPIFFS.exists("/wifi_creds.txt")) {
    File file = SPIFFS.open("/wifi_creds.txt", "r");
    if (file) {
      routerSSID = file.readStringUntil('\n');
      routerPassword = file.readStringUntil('\n');
      routerSSID.trim();
      routerPassword.trim();
      Serial.println("Kredensial WiFi dimuat: " + routerSSID);
      file.close();
void saveWiFiCredentials() {
  File file = SPIFFS.open("/wifi_creds.txt", "w");
  if (file) {
    file.println(routerSSID);
    file.println(routerPassword);
    file.close();
    Serial.println("Kredensial WiFi disimpan");
void saveStaticIPConfig() {
  File file = SPIFFS.open("/static_ip.txt", "w");
  if (file) {
    file.println(useStaticIP);
    file.println(staticIP.toString());
    file.println(gateway.toString());
    file.println(subnet.toString());
    file.println(dns1.toString());
    file.println(dns2.toString());
    file.close();
    Serial.println("Konfigurasi IP statis disimpan");
void loadStaticIPConfig() {
  if (SPIFFS.exists("/static_ip.txt")) {
    File file = SPIFFS.open("/static_ip.txt", "r");
    if (file) {
      useStaticIP = file.readStringUntil('\n').toInt();
      staticIP.fromString(file.readStringUntil('\n'));
      gateway.fromString(file.readStringUntil('\n'));
      subnet.fromString(file.readStringUntil('\n'));
      dns1.fromString(file.readStringUntil('\n'));
      dns2.fromString(file.readStringUntil('\n'));
      file.close();
      Serial.println("Konfigurasi IP statis dimuat");
void saveWiFiMode(WiFiMode_t mode) {
  File file = SPIFFS.open("/wifi_mode.txt", "w");
  if (file) {
    file.println(static_cast<int>(mode));
    file.close();
    Serial.println("Mode WiFi disimpan");
WiFiMode_t loadWiFiMode() {
  WiFiMode_t mode = WIFI_AP_STA;  // Default mode
  if (SPIFFS.exists("/wifi_mode.txt")) {
    File file = SPIFFS.open("/wifi_mode.txt", "r");
    if (file) {
      String modeStr = file.readStringUntil('\n');
      modeStr.trim();
      mode = (WiFiMode_t)modeStr.toInt();
      file.close();
  return mode;
bool checkInternetConnection() {
  WiFiClient client;
  if (!client.connect("www.google.com", 80)) {
    Serial.println("Gagal terhubung ke www.google.com");
    return false;
  Serial.println("Berhasil terhubung ke www.google.com");
  client.stop();
  return true;
void startAPMode() {
  WiFi.mode(WIFI_AP);
  WiFi.softAP(apSSID, apPassword);
  isAPMode = true;
  Serial.println("Mode AP dimulai");
  Serial.print("IP Address AP: ");
  Serial.println(WiFi.softAPIP());
void connectToWiFi() {
  int attempts = 0;
  const int maxAttempts = 20;
  Serial.println("Menghubungkan ke WiFi...");
  if (useStaticIP) {
    if (!WiFi.config(staticIP, gateway, subnet, dns1, dns2)) {
      Serial.println("Gagal mengonfigurasi Static IP");
  WiFi.begin(routerSSID.c_str(), routerPassword.c_str());
  while (WiFi.status() != WL_CONNECTED && attempts < maxAttempts) {
    Serial.print(".");
    attempts++;
  if (WiFi.status() == WL_CONNECTED) {
    isAPMode = false;
    Serial.println("\nTerhubung ke WiFi");
    Serial.print("Alamat IP: ");
    Serial.print("Modbus port: ");
    Serial.println(modbusPort);
    unsigned int signalStrength = WiFi.RSSI();
    int signalQuality = getSignalQuality(signalStrength);
    Serial.print("Kekuatan sinyal WiFi: ");
    Serial.println(signalQuality);
    Serial.println("\nGagal terhubung ke WiFi");
    startAPMode();
void resetWiFiConnection() {
  WiFi.disconnect(true);
  connectToWiFi();
void setupServerRoutes() {
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/index.html", "text/html");
  server.on("/assets/css/foundation.css", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send(SPIFFS, "/assets/css/foundation.css", "text/css");
  server.on("/reset", HTTP_POST, [](AsyncWebServerRequest *request) {
    resetSettings();
    request->send(200, "text/plain", "Semua pengaturan direset. Memulai ulang...");
    ESP.restart();
  server.on("/setwifi", HTTP_POST, [](AsyncWebServerRequest *request) {
    if (request->hasParam("ssid", true) && request->hasParam("password", true)) {
      routerSSID = request->getParam("ssid", true)->value();
      routerPassword = request->getParam("password", true)->value();
      request->send(200, "text/plain", "Kredensial WiFi diperbarui. Memulai ulang...");
      ESP.restart();
      request->send(400, "text/plain", "Permintaan tidak valid");
  server.on("/setstaticip", HTTP_POST, [](AsyncWebServerRequest *request) {
    if (request->hasParam("ip", true) && request->hasParam("gateway", true)) {
      String ip = request->getParam("ip", true)->value();
      String gw = request->getParam("gateway", true)->value();
      if (staticIP.fromString(ip) && gateway.fromString(gw)) {
        useStaticIP = true;
        request->send(200, "text/plain", "Konfigurasi IP statis diperbarui. Memulai ulang...");
        ESP.restart();
        request->send(400, "text/plain", "Format IP tidak valid");
  server.on("/disablestaticip", HTTP_POST, [](AsyncWebServerRequest *request) {
    request->send(200, "text/plain", "IP statis dinonaktifkan. Memulai ulang...");
    ESP.restart();
  server.on("/devicestatus", HTTP_GET, [](AsyncWebServerRequest *request) {
    String response = "{";
    response += "\"ssid\":\"" + String(isAPMode ? apSSID : WiFi.SSID()) + "\",";
    response += "\"ip\":\"" + (isAPMode ? WiFi.softAPIP().toString() : WiFi.localIP().toString()) + "\",";
    response += "\"freeHeap\":\"" + String(ESP.getFreeHeap()) + "\",";
    response += "\"signalStrength\":\"" + String(isAPMode ? 5 : getSignalQuality(WiFi.RSSI())) + "\",";
    response += "\"mode\":\"" + String(isAPMode ? "AP" : "STA") + "\",";
    response += "\"staticIP\":\"" + String(useStaticIP ? "true" : "false") + "\"";
    response += "}";
    request->send(200, "application/json", response);
void toggleServer() {
  if (isServerRunning) {
    server.end();
    Serial.println("Server dimatikan");
    server.begin();
    isServerRunning = true;
    Serial.println("Server dihidupkan");
  Serial.println("Memulai Setup...");
  if (!SPIFFS.begin(true)) {
    Serial.println("Terjadi kesalahan saat memasang SPIFFS");
    return;
  Serial.println("SPIFFS berhasil dipasang");
  loadWiFiCredentials();
  loadStaticIPConfig();
  WiFiMode_t savedMode = loadWiFiMode();
  WiFi.mode(savedMode);
  connectToWiFi();
  setupServerRoutes();
  Serial.println("Server siap untuk dihidupkan");
  Serial.printf("Free heap: %d bytes\n", ESP.getFreeHeap());
  // Initialize Modbus TCP server
  mb.server();
  // Add Modbus registers
  mb.addCoil(REG_OUTPUT);
  mb.addCoil(REG_TOUCH1);
  mb.addCoil(REG_TOUCH2);
  mb.addCoil(REG_TOUCH3);
  mb.addCoil(REG_TOUCH4);
  // Initialize GPIO pins
  pinMode(outputPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  static bool lastButtonState = HIGH;
  bool currentButtonState = digitalRead(buttonPin);
  if (lastButtonState == HIGH && currentButtonState == LOW) {
    delay(50); // debounce
    if (digitalRead(buttonPin) == LOW) {
      toggleServer();
  lastButtonState = currentButtonState;
  if (!isAPMode && currentMillis - lastWiFiCheckMillis >= wifiCheckInterval) {
    lastWiFiCheckMillis = currentMillis;
    if (WiFi.status() != WL_CONNECTED) {
      Serial.println("WiFi terputus. Mencoba menghubungkan kembali...");
      connectToWiFi();
        failedWiFiConnections++;
        if (failedWiFiConnections >= 3) {
          Serial.println("Mengatur ulang koneksi WiFi...");
          resetWiFiConnection();
  // Handle Modbus requests
  mb.task();
  delay(10);
  // Read touch sensor values
  bool touch1 = touchRead(touchPin1) < 20;
  bool touch2 = touchRead(touchPin2) < 20;
  bool touch3 = touchRead(touchPin3) < 20;
  bool touch4 = touchRead(touchPin4) < 20;
  // Update Modbus registers
  mb.Coil(REG_TOUCH1, touch1);
  mb.Coil(REG_TOUCH2, touch2);
  mb.Coil(REG_TOUCH3, touch3);
  mb.Coil(REG_TOUCH4, touch4);
  // Control GPIO output based on Modbus register
  bool outputState = mb.Coil(REG_OUTPUT);
  digitalWrite(outputPin, outputState ? HIGH : LOW);
  // Debugging: Print touch sensor values
  Serial.print("Touch1: ");
  Serial.print(touch1);
  Serial.print(" Touch2: ");
  Serial.print(touch2);
  Serial.print(" Touch3: ");
  Serial.print(touch3);
  Serial.print(" Touch4: ");
  Serial.println(touch4);
// Function to convert RSSI to signal quality (1 to 5)
int getSignalQuality(int rssi) {
  if (rssi >= -50) {
    return 5; // Sangat Bagus
  } else if (rssi >= -60) {
    return 4; // Bagus
  } else if (rssi >= -70) {
    return 3; // Sedang
  } else if (rssi >= -80) {
    return 2; // Buruk
    return 1; // Sangat Buruk
You want to set Static IP While viewing webserver from AP .Can you try printing the static ip you inputed is storing correctly. i had littile bit trouble with that and i had to store in multiple varaiables just check it out
I suggest you don't use a static IP address configured on the board, instead set it to DHCP and configure the router with the MAC address of the board and reserve an IP address for that MAC address, so the board gets its IP address by DHCP and the router always supplies the reserved address. If you want to change then do so in the router.
If you really do want to assign a static IP address to the board then make sure it is outside the DHCP range of the router.
Either that or I have completely misunderstood your question as there are parts of it that I am making guesses as to what you really mean.
