I have this code that I run into the void loop and it works, then, I copy and paste the same code to make a function, and call this function in the void loop with a char array as an argument (this is the only difference, calling the array instead of just read it directly) but for some reason, it works some time (maybe 50 iterations) and then throw garbish.
Code in loop:
float data;
union u_tag {
byte b[4];
float fval;
} u;
u.b[3] = respuesta[3];
u.b[2] = respuesta[4];
u.b[1] = respuesta[5];
u.b[0] = respuesta[6];
data = u.fval;
char flotante[6];
dtostrf(data, 4, 1, flotante);
String flotanteStr = flotante;
flotanteStr.replace(" ", "");
valores_trama = "";
valores_trama += flotanteStr;
valores_trama += ",";
Serial.println(valores_trama);
Serial.flush();
delay(10);
Code in function:
floatAstring(reply);
String floatAstring(char respuesta[]) {
///////same code as above/////////
Char array used:
char respuesta [9] = {0x01, 0x03, 0x04, 0x43, 0x5D, 0xA3, 0xD7, 0x46, 0xCB}; //OR renamed "reply" if used with function.
What am I doing wrong?
