The SD card damaged after inserted into ESP32CAM, why?
Hi everyone,
tested the example of ESP32CAM take picture and save to SD card from:
https://randomnerdtutorials.com/esp32-c ... rosd-card/
the strange thing is the SD card can't be read after inserted to ESP32CAM, and said need format every time, why?
Thanks
Adam
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-cam-take-photo-save-microsd-card
  IMPORTANT!!!
   - Select Board "AI Thinker ESP32-CAM"
   - GPIO 0 must be connected to GND to upload a sketch
   - After connecting GPIO 0 to GND, press the ESP32-CAM on-board RESET button to put your board in flashing mode
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include "esp_camera.h"
#include "Arduino.h"
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include "driver/rtc_io.h"
#include <EEPROM.h>            // read and write from flash memory
// define the number of bytes you want to access
#define EEPROM_SIZE 1
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
int pictureNumber = 0;
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  //Serial.setDebugOutput(true);
  //Serial.println();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  //Serial.println("Starting SD Card");
  if(!SD_MMC.begin()){
    Serial.println("SD Card Mount Failed");
    return;
  uint8_t cardType = SD_MMC.cardType();
  if(cardType == CARD_NONE){
    Serial.println("No SD Card attached");
    return;
  camera_fb_t * fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    return;
  // initialize EEPROM with predefined size
  EEPROM.begin(EEPROM_SIZE);
  pictureNumber = EEPROM.read(0) + 1;
  // Path where new picture will be saved in SD Card
  String path = "/picture" + String(pictureNumber) +".jpg";
  fs::FS &fs = SD_MMC;
  Serial.printf("Picture file name: %s\n", path.c_str());
  File file = fs.open(path.c_str(), FILE_WRITE);
  if(!file){
    Serial.println("Failed to open file in writing mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved file to path: %s\n", path.c_str());
    EEPROM.write(0, pictureNumber);
    EEPROM.commit();
  file.close();
  esp_camera_fb_return(fb);
  // Turns off the ESP32-CAM white on-board LED (flash) connected to GPIO 4
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);
  rtc_gpio_hold_en(GPIO_NUM_4);
  delay(2000);
  Serial.println("Going to sleep now");
  delay(2000);
  esp_deep_sleep_start();
  Serial.println("This will never be printed");
Where does it say this? If on a PC, ignore the error. How did you originally format the SD card?
thank.
SD card formatted on pc, and inserted into ESP32CAM to take pictures and then check the pictures on pc, doesn't read and said card need format.
tested 2 cards, 32G / 4G.
Can you open it in File Explorer?
How did you originally format the SD card? ExFAT, FAT16, FAT32, xExif, NTFS?
If you remove or plug in an SD card on an MCU board where this SD card slot is enabled (hot) - you get bounces on the power during insertion/removing.
Make sure to change the SD card (into or remove) when the SD card slot is disabled.
Or:
Just insert or remove the card when the board is not powered.
I have seen this so often when inserting or removing SD card from a running system!
Other issue:
when you write to SD card, a file, data - it is not flashed all to SD card. Some data sits still in a cache, esp. the File System.
On Windows you have to say "eject" just to make sure all caches are flashed. On an MCU it does not have this "command" but potentially part of your data sits still in the MCU and was not yet written to SD Card.
Esp. this happens for the File System data. Your file system is corrupted at the end.
No idea which FW you use, how long does it take to update all on SD card, to flash the File System info. Or if you have a command, option to "eject" (to let flush all).
I would never change a SD Card on a running MCU system.
Next time:
wait long enough, power down the board, then remove the SD card. But no guarantee:
if your FW caches the File System and just writes on request (or a new command comes in), it can be still incomplete on SD card (and File System is corrupted).
Or:
before you power down: read back the same file, access the SD Card for read ... (so that the caches are flushed and card is not corrupted).
Can't open after pullout from ESP32CAM.
sdcard
sdcard2
Thank you tjaekel.
IT works!!!
best.
Again, is it makes sense that different sketch made different effect on SD card?
because my test shown that even the one sketch made only a little modification from other one, two sketches got different result with SD card at same operating.
different result I mean one sketch made SD card can be used repeatedly, while the other cannot.
are there any solution to end writing?
