The SD of the keylogger reads alone AAAAA
this my code
#include <PS2Keyboard.h>
#include <SD.h>
const int DataPin = 2;
const int IRQpin =  3;
const int chipSelect = 10;
File myFile;
PS2Keyboard keyboard;
  pinMode(10, OUTPUT);
  while(!SD.begin(chipSelect));                                              // initialize the SD card
  keyboard.begin(DataPin, IRQpin);
  if(keyboard.available())
    char c = keyboard.read();
    while(!(myFile = SD.open("01.txt", FILE_WRITE)));
    myFile.print(c);
    myFile.close();
  else;
Hola que tal como estan
Only appears this in the sd
`````````````````````````````aaaaaaaaaaaa0000000000000000aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa````aaaaaaaaaaaaaaa1aaaaaaaaaaaaaaazaaaaaaaaaaaaaaa```````````````e00aaaa1````````````````````````eaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
There's no way that code will compile so if you are getting that output in an SD file, it isn't from that code.
Pete
Then what could it be?
el_supremo:
Pete
Zomber:
The last sketch someone programmed into it.
aarg:
Then reset arduino and re-upload the code?
Zomber:
Yes, but if it won't compile you can't.
@Zomber: you need to focus on your other thread and get the code to compile before you even think about what is in the SD file.
Pete
