Hey…
My servo gets disabled by the TMRpcm
when I uncheck SD.Begin the servo works fine. But if its active the servo wont work. Any help? Thanks all.
I use Arduino UNO R3 Dev.
void loop(){
SD.begin(SD_ChipSelectPin);
Rest of the code:
#include <Servo.h>
#include <Keypad.h>
#include <SD.h>
#define SD_ChipSelectPin 10
#include <TMRpcm.h>
TMRpcm som;
Servo servolock;
const char* password = "2403";
const char* sleepPassword = "8624";
const char* pwrOff = "24032001";
int position = 0;
int switchcount = 0;
int buttonTap = 0;
int freezed = 0;
int moreFreezed = 0;
int positionReset = 0;
int sleepPosition = 0;
int pwrOffPosition = 0;
int wakePin = 2;
int servo = 7;
const byte rows = 4;
const byte cols = 3;
char keys[rows][cols] = {
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rowPins[rows] = {1, 6, 5, 3};
byte colPins[cols] = {2, 0, 4};
Keypad keypad = Keypad(makeKeymap(keys),
rowPins, colPins,
rows, cols);
int redPin = 8;
int greenPin = A0;
boolean sleepEnable = false;
boolean unlocked = false;
boolean locked = true;
boolean notfreezed = true;
boolean sleepNow = false;
som.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
//pinMode(A1, OUTPUT);
// pinMode(A2, OUTPUT);
// pinMode(A3, OUTPUT);
som.volume(7);
som.play("lock.wav");
servolock.attach(servo);
char key = keypad.getKey();
//UNLOCKED - UNLOCKED - UNLOCKED - UNLOCKED - UNLOCKED
if (unlocked == true) {
freezed = 0;
moreFreezed = -1;
buttonTap = 0;
digitalWrite(greenPin, HIGH);
digitalWrite(redPin, LOW);
digitalWrite(A1, LOW);
digitalWrite(A2, LOW);
digitalWrite(A3, LOW);
if (key == '*' || key == '#') {
position = 0;
locked = true;
notfreezed = true;
unlocked = false;
servolock.write(0);
if (key == '1') {
Serial.println("1");
switchcount++;
digitalWrite(greenPin, LOW);
delay(50);
som.play("test1.wav");
if (key == '2') {
delay(50);
som.play("faded.wav");
if (key == '3') {
delay(50);
digitalWrite(som.speakerPin, LOW);
som.play("faded2.wav");
if (key == '0') {
som.pause();
// END - END - END - END - END - END - END - END - END
//LOCKED - LOCKED - LOCKED - LOCKED - LOCKED - LOCKED
if (notfreezed == true) {
buttonTap = buttonTap - 1;
delay(100);
if (buttonTap < 0) {
buttonTap = 0;
if (key == password[position]) {
position++;
if (position == 4) {
servolock.write(180);
som.play("startup.wav");
sleepEnable = true;
unlocked = true;
locked = false;
if (locked == true) {
digitalWrite(redPin, HIGH);
if (key == '1' || key == '2' || key == '3' || key == '4' || key == '5' || key == '6' || key == '7' || key == '8' || key == '9' || key == '0') {
som.play("beep.wav");
delay(100);
buttonTap++;
if (buttonTap == 4) {
som.play("wrong.wav");
position = 0;
freezed++;
buttonTap = 0;
delay(100);
delay(100);
delay(100);
delay(100);
delay(25);
if (freezed == 1) {
digitalWrite(A1, HIGH);
if (freezed == 2) {
digitalWrite(A2, HIGH);
if (freezed == 3) {
digitalWrite(A3, HIGH);
moreFreezed++;
if (moreFreezed == 1) {
notfreezed = false;
delay(7000);
moreFreezed = 2;
freezed = 0;
notfreezed = true;
if (moreFreezed == 2) {
if (moreFreezed == 3) {
notfreezed = false;
delay(27000);
moreFreezed = 4;
freezed = 0;
notfreezed = true;
if (moreFreezed == 4) {
if (moreFreezed == 5) {
notfreezed = false;
delay(57000);
freezed = 0;
notfreezed = true;
moreFreezed = 4;
