The second 'while' command doesn't wait for user input
Hello all,
I'm using an Arduino Uno R3. Software is Arduino 1.8.8
My project is a small program that can be used to average grades. The end goal is to learn more about arrays.
I followed a tutorial on youtube. That instructor (Paul McWhorter) used Arduino 1.6.8
The code ran properly for him. For me, once I input the number of grades I am then prompted to input a grade. Once I do the code spits out a grade average instead of prompting me for the remaining grades.
(ex. If I input 3 for "How many grades?" it should prompt me for all 3 grades then report the grade average to me.)
As you can see I noted all the {} in my code to be certain they were correct.
After searching many forums and googling the issue I can find no pertinent info on this problem.
I have tried changing "i" to 1 in my second 'for' statement along with different combinations of <,>,= to no avail.
The entire code is posted. Any suggestions will be most appreciated.
Thanks,
Tim
float grades[25];   //an array, it sets the number of grades
int numGrades;      //creates a variable for the number of grades
float av;           //a variable for grade averages
int i;              //a variable to hold grades
float sumGrades=0;  //a variable to add grades
  Serial.begin(9600);  //turn on serial printer
void loop() {                                                         //void loop begins
  Serial.println("How many grades? ");                                //prompt used for input
  while(Serial.available()==0){                                       //while there is no data we wait ---while loop 1 begins
 }        //while loop 1 ends
  numGrades=Serial.parseInt();                                        //(use Serial.parseInt to read ints') - this line reads the # of grades input by the user
  for(i=0; i<numGrades; i=i+1);{                                      //for loop 1 begins---this will loop until numGrades is reached.
  Serial.println("Please input your grade: ");                        //prompt used for grades
  while(Serial.available()==0){                                       //while loop 2 begins
  }        //while loop 2 ends
  grades[i]=Serial.parseFloat();                                      //reads the grades
  }        //for loop 1 ends
  for(i=0; i<=numGrades; i=i+1);{                                     //for loop 2 begins
  sumGrades=sumGrades+grades[i];
  }        //for loop 2 ends
  av=sumGrades/numGrades;
  Serial.print("Your average is ");
  Serial.println(av);
  Serial.println("");
  sumGrades=0;
}        //void loop ends
You have a semicolon where one should not be here:
Same thing further down too.
Thanks wildbill, sometimes one can look at something for hours and not see something so simple and basic as that mistake.
I appreciate you taking time to respond.
Tim
