Hi friends ,I have made a project consisting of a PCA9685 module and 5 servo motors, the board used a UNO board,but when i use 3 servo motors,it could activate well,but when i add to 5 servo motors,they don't work,the external power supply ,i use 7.4V and 1A power supply ,the servo motor is MG996R servo,here are the code and Wiring diagram
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// 定义PCA9685的地址,默认为0x40
#define PCA9685_ADDRESS 0x40
// 定义伺服电机脉冲宽度范围
#define SERVOMIN 150 // 最小脉冲宽度计数(对应0度)
#define SERVOMAX 600 // 最大脉冲宽度计数(对应180度)
#define SERVO_CENTER ((SERVOMAX - SERVOMIN)/2 +SERVOMIN) // 中心位置脉冲宽度计数(对应90度)
// 定义伺服电机通道
#define SERVO_CHANNEL_1 0
#define SERVO_CHANNEL_2 1
#define SERVO_CHANNEL_3 2
#define SERVO_CHANNEL_4 3
#define SERVO_CHANNEL_5 4
int SERVO1;
int SERVO2;
int SERVO3;
int SERVO4;
int SERVO5;
int TURN=1;
int a=SERVO_CENTER;
int b=SERVO_CENTER;
int c=SERVO_CENTER;
int d=SERVO_CENTER;
int e=600;
// 初始化PCA9685对象
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// Arduino pin numbers
const int SW_1 = 7; // digital pin connected to switch output
const int X_1 = A0; // analog pin connected to X output
const int Y_1 = A1; // analog pin connected to Y output
const int SW_2 = 6; // digital pin connected to switch output
const int X_2 = A2; // analog pin connected to X output
const int Y_2 = A3; // analog pin connected to Y output
int a_1=0;
int b_1=0;
int digitalSW1=0;
int a_2=0;
int b_2=0;
int digitalSW2=0;
// 初始化PCA9685
pwm.begin();
pinMode(SW_1, INPUT);
digitalWrite(SW_1, HIGH);
pinMode(SW_2, INPUT);
digitalWrite(SW_2, HIGH);
pwm.setOscillatorFrequency(27000000);
pwm.setPWMFreq(20); // 设置PWM频率为50Hz
// 将所有伺服电机设置到90度位置
pwm.setPWM(SERVO_CHANNEL_1, 0, SERVO_CENTER);
pwm.setPWM(SERVO_CHANNEL_2, 0, SERVO_CENTER);
pwm.setPWM(SERVO_CHANNEL_3, 0, SERVO_CENTER);
pwm.setPWM(SERVO_CHANNEL_4, 0, SERVO_CENTER);
pwm.setPWM(SERVO_CHANNEL_5, 0, SERVO_CENTER);
a_1=analogRead(X_1);
b_1=analogRead(Y_1);
digitalSW1=!digitalRead(SW_1);
a_2=analogRead(X_2);
b_2=analogRead(Y_2);
digitalSW2=digitalRead(SW_2);
rebuild();
motor();
Serial.print("a");
Serial.print(a);
Serial.print(" ; ");
Serial.print("b");
Serial.print(b);
Serial.print("c");
Serial.print(c);
Serial.print("d");
Serial.print(d);
Serial.print("e");
Serial.println(e);
void motor(){
SERVO1=a;
SERVO2=b;
SERVO3=c;
SERVO4=d;
SERVO5=e;
// 将所有伺服电机设置到90度位置
pwm.setPWM(SERVO_CHANNEL_1, 0, SERVO1);
pwm.setPWM(SERVO_CHANNEL_2, 0, SERVO2);
pwm.setPWM(SERVO_CHANNEL_3, 0, SERVO3);
pwm.setPWM(SERVO_CHANNEL_4, 0, SERVO4);
pwm.setPWM(SERVO_CHANNEL_5, 0, SERVO5);
void rebuild(){
//tern left
if(a_1>1000&&b_1>400&&b_1<600){
a=a+20;
a=min(a,480);
//turn right
if(a_1<100&&b_1>400&&b_1<600){
a=a-20;
a=max(260,a);
//1st big arm turn down
if(b_1<100&&a_1>500&&a_1<600){
c=c+20;
c=min(475,c);
//1st big arm turn up
if(b_1>1000&&a_1>500&&a_1<600){
c=c-20;
c=max(c,195);
//2nd forearm turn up
if(b_2<100&&a_1>500&&a_1<600){
b=b+20;
b=min(480,b);
//2nd forearm turn down
if(b_2>1000&&a_2>500&&a_2<600){
b=b-20;
b=max(b,170);
if(a_2>1000&&b_2>400&&b_2<600){
d=d+20;
d=min(d,480);
//turn right
if(a_2<100&&b_2>400&&b_2<600){
d=d-20;
d=max(260,d);
e=600-375*digitalSW1;
and i also use two 2-Axis module to control the 5 motor
