"The site can't be reached" for ESP32
Hello, for some reasons, I am not able to access the site for my ESP32 NodeMCU IP address. I found the sketch I'm trying to run here: ESP32 Web Server - Arduino IDE | Random Nerd Tutorials by Rui Santos. I'm not getting any errors, but it just keep saying that the site can't be reached, and that it took too long to respond.
Code:
// Load Wi-Fi library
#include <WiFi.h>
// Replace with your network credentials
const char* ssid = "ssid";
const char* password = "pass";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output26State = "off";
String output27State = "off";
// Assign output variables to GPIO pins
const int output26 = 26;
const int output27 = 27;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
  // Initialize the output variables as outputs
  pinMode(output26, OUTPUT);
  pinMode(output27, OUTPUT);
  // Set outputs to LOW
  digitalWrite(output26, LOW);
  digitalWrite(output27, LOW);
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    previousTime = currentTime;
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected() && currentTime - previousTime <= timeoutTime) {  // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /26/on") >= 0) {
              Serial.println("GPIO 26 on");
              output26State = "on";
              digitalWrite(output26, HIGH);
            } else if (header.indexOf("GET /26/off") >= 0) {
              Serial.println("GPIO 26 off");
            } else if (header.indexOf("GET /27/on") >= 0) {
              Serial.println("GPIO 27 on");
              output27State = "on";
              digitalWrite(output27, HIGH);
            } else if (header.indexOf("GET /27/off") >= 0) {
              Serial.println("GPIO 27 off");
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #555555;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP32 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 26
            client.println("<p>GPIO 26 - State " + output26State + "</p>");
            // If the output26State is off, it displays the ON button
            if (output26State=="off") {
              client.println("<p><a href=\"/26/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/26/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 27
            client.println("<p>GPIO 27 - State " + output27State + "</p>");
            // If the output27State is off, it displays the ON button
            if (output27State=="off") {
              client.println("<p><a href=\"/27/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/27/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
Did you got any diagnostic messages like "WiFi connected." and printing the IP address?
Yes, I'm getting that message, which confuses me the most.
(Serial monitor):
WiFi connected.
IP address:
Followed by the numbers.
The numbers is a very important. Is it a valid IP address? Is this address belongs to your local network?
Sorry, I completely missed the point the IP was for my ESP32 and not something confidential (lol) , this was the full message along with the 'numbers':
WiFi connected.
IP address:
192.168.43.108
How did you try to connect - via smartphone? Did the phone connected to your local WiFi that moment?
What exact URL did you use in the browser?
Yes, I was using a Samsung hotspot. And the Samsung was connected to a WiFi.
The URL I used is exactly the IP address.
Do you think there might be a way to debug and test the situation to know where the problem resides?
Sorry, I do know nothing about any "magic ways" to diagnose the issue, just testing and debug.
Perhaps you have a firewall on your WiFi router that prevents intruders to go into local network?
My computer in which the code is from has firewall, but does that have the ability to block ESP32 IP addresses and URLs?
I dont clearly understand your network configuration. Could you please to draw a brief schematic?
I'm sorry, do you mean how they are connected?
My computer --> (uploads the code to the ESP32)
House WiFi --> My Phone (Hotspot) --> ESP32 (Uses my phone's Hotspot SSID and Password)
Then using my computer, I enter the IP address in Google.
I think the problem is here:
Try to connect ESP32 to you House Wifi rather than to Hotspot, so that the phone and ESP32 both are clients of the same access point.
Or let Hotspot and esp32 remain as they are now, but try to connect to esp32 from another phone, connecting it via Wi-Fi to the same hotspot
In any way, the idea that the server (esp32) and the client (phone using to connect) must be in the same logical net segment
The problem is that I don't know the house's WiFi details, it was given to me (strict situation). That's why I'm using a hotspot, but I'll try to talk and somehow try it. It might take some time for my next reply , but I'll get back and tell you if it worked.
Then try to connect from another phone, using the WiFi from the same hotspot
I tried connecting to another Samsung device, the same result occurred. I attempted Apple iPhone hotspot, but I guess ESP32 can't connect to it, or I did something wrong.
When you say that, you mean using another phone's hotspot for the ESP32?
Wait, that actually worked. I'm not sure why, but the unlike the Hotspots that gave that same IP address I posted, the WiFi gave a different IP address which worked. Thanks so much!
