I tested the sketch from:
with MIT APP on my phone, that works well.
I added two lines of:
digitalPotWrite(wiper0writeAddr, motorSpeedA); // Send PWM signal to motor A
digitalPotWrite(wiper1writeAddr, motorSpeedB); // Send PWM signal to motor B
at line 131, and void digitalPotWrite(int address, int value)
at line 168, no led on at all, why?
Thanks
Adam
#include "CONFIG.h"
#define enA 8
#define in1 10
#define in2 11
#define in3 12
#define in4 13
#define enB 9
int xAxis = 140, yAxis = 140;
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
Serial1.begin(9600); // Default communication rate of the Bluetooth module
// Default value - no movement when the Joystick stays in the center
//xAxis = 140;
//yAxis = 140;
// Read the incoming data from the Smartphone Android App
while (Serial1.available() >= 2) {
xAxis = Serial1.read();
delay(10);
yAxis = Serial1.read();
Serial.print(xAxis);
Serial.print(",");
Serial.println(yAxis);
Serial.print("xAxis=");
Serial1.print("yAxis=");
Serial1.print(yAxis);
delay(10);
// Makes sure we receive corrent values
if (xAxis > 130 && xAxis < 150 && yAxis > 130 && yAxis < 150) {
Stop();
if (yAxis > 130 && yAxis < 150) {
if (xAxis < 130) {
turnRight();
motorSpeedA = map(xAxis, 130, 60, 0, 255);
motorSpeedB = map(xAxis, 130, 60, 0, 255);
if (xAxis > 150) {
turnLeft();
motorSpeedA = map(xAxis, 150, 220, 0, 255);
motorSpeedB = map(xAxis, 150, 220, 0, 255);
if (xAxis > 130 && xAxis < 150) {
if (yAxis < 130) {
forword();
if (yAxis > 150) {
backword();
if (yAxis < 130) {
motorSpeedA = map(yAxis, 130, 60, 0, 255);
motorSpeedB = map(yAxis, 130, 60, 0, 255);
if (yAxis > 150) {
motorSpeedA = map(yAxis, 150, 220, 0, 255);
motorSpeedB = map(yAxis, 150, 220, 0, 255);
if (yAxis < 130) {
forword();
if (yAxis > 150) {
backword();
if (xAxis < 130) {
motorSpeedA = map(xAxis, 130, 60, 255, 50);
motorSpeedB = 255;
if (xAxis > 150) {
motorSpeedA = 255;
motorSpeedB = map(xAxis, 150, 220, 255, 50);
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
Serial.print("motorSpeedA128=");
Serial.print(motorSpeedA);
digitalPotWrite(wiper0writeAddr, motorSpeedA); // Send PWM signal to motor A // THE CODE doesn't work when added these two lines ? why?
// digitalPotWrite(wiper1writeAddr, motorSpeedB); // Send PWM signal to motor B
void forword() {
Serial.println("forword");
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
void backword() {
Serial.println("backword");
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
void turnRight() {
Serial.println("turnRight");
void turnLeft() {
Serial.println("turnLeft");
void Stop() {
Serial.println("stop");
void digitalPotWrite(int address, int value) {
digitalWrite(slaveSelectPin, LOW);
digitalWrite(shutdownPin, HIGH); //Turn off shutdown THIS MAKE WRITEABLE OR DISABLE THIS CAN'T WRITE
// send in the address and value via SPI:
SPI.transfer(address);
SPI.transfer(value);
