The Sync didn't work
I'm using the MEGA2560 and when I'm trying to change the light speed, the sync doesn't work.
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,066 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xec
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xec
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
(deleted)
That didn't help is there any type of fix or why this is happening?
(deleted)
SpyCatcher2k was telling you that if you turn on VERBOSE in preferences and then post that here it may be more use to help fix the issue...
He didn't say turning it on would fix it !!! LOL
BTW ( means "By The Way" ) please use CODE TAGS to post the output or sketches ( </> )
