The System Cannot find the Path specified using Arduino IDE
I've installed the Latest Arduino IDE 2.0.1 aswell as 1.8.18, and get the same Error with every Program i try to verify (even blank).
Specs:
Win10, Adafruit Feather V2, IDE 2.0.1 and 1.8.18 produce same Error. When Compiling i get the following.
After searching for several hours i cannot solve the Problem. Reboot, Fresh install dont seem to help.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\yanni\AppData\Local\Arduino15\packages -hardware C:\Users\yanni\OneDrive\Dokumente\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\yanni\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\yanni\OneDrive\Dokumente\Arduino\libraries -fqbn=espressif:esp32:adafruit_feather_esp32_v2:LoopCore=1,EventsCore=1,PSRAM=enabled,PartitionScheme=default_8MB,CPUFreq=240,FlashFreq=80,FlashSize=8M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0000_0000 -ide-version=10818 -build-path C:\Users\yanni\AppData\Local\Temp\arduino_build_435492 -warnings=all -build-cache C:\Users\yanni\AppData\Local\Temp\arduino_cache_888601 -prefs=build.warn_data_percentage=75 -verbose C:\Users\yanni\AppData\Local\Temp\untitled1143876486.tmp\sketch_nov08a\sketch_nov08a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\yanni\AppData\Local\Arduino15\packages -hardware C:\Users\yanni\OneDrive\Dokumente\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\yanni\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\yanni\OneDrive\Dokumente\Arduino\libraries -fqbn=espressif:esp32:adafruit_feather_esp32_v2:LoopCore=1,EventsCore=1,PSRAM=enabled,PartitionScheme=default_8MB,CPUFreq=240,FlashFreq=80,FlashSize=8M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0000_0000 -ide-version=10818 -build-path C:\Users\yanni\AppData\Local\Temp\arduino_build_435492 -warnings=all -build-cache C:\Users\yanni\AppData\Local\Temp\arduino_cache_888601 -prefs=build.warn_data_percentage=75 -verbose C:\Users\yanni\AppData\Local\Temp\untitled1143876486.tmp\sketch_nov08a\sketch_nov08a.ino
Using board 'adafruit_feather_esp32_v2' from platform in folder: C:\Users\yanni\OneDrive\Dokumente\Arduino\hardware\espressif\esp32
Using core 'esp32' from platform in folder: C:\Users\yanni\OneDrive\Dokumente\Arduino\hardware\espressif\esp32
cmd /c if exist "C:\\Users\\yanni\\AppData\\Local\\Temp\\untitled1143876486.tmp\\sketch_nov08a\\partitions.csv" COPY /y "C:\\Users\\yanni\\AppData\\Local\\Temp\\untitled1143876486.tmp\\sketch_nov08a\\partitions.csv" "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\partitions.csv"
cmd /c if not exist "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\partitions.csv" if exist "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_feather_esp32_v2\\partitions.csv" COPY "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_feather_esp32_v2\\partitions.csv" "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\partitions.csv"
cmd /c if not exist "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\partitions.csv" COPY "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\tools\\partitions\\default_8MB.csv" "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\yanni\\AppData\\Local\\Temp\\untitled1143876486.tmp\\sketch_nov08a\\bootloader.bin" ( COPY /y "C:\\Users\\yanni\\AppData\\Local\\Temp\\untitled1143876486.tmp\\sketch_nov08a\\bootloader.bin" "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\sketch_nov08a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_feather_esp32_v2\\bootloader.bin" ( COPY "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_feather_esp32_v2\\bootloader.bin" "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\sketch_nov08a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32/tools/esptool/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 8MB -o "C:\\Users\\yanni\\AppData\\Local\\Temp\\arduino_build_435492\\sketch_nov08a.ino.bootloader.bin" "C:\\Users\\yanni\\OneDrive\\Dokumente\\Arduino\\hardware\\espressif\\esp32\\tools\\sdk\\esp32\\bin\\bootloader_dio_80m.elf" ) )
The system cannot find the path specified.
exit status 1
Error compiling for board Adafruit Feather ESP32 V2.
