The T-DisplayS3 + MAX30105+OLED1306 test
Hi all.
tested MAX30105 with T-Display S3 works well with little code modification:
 //if (sensor.begin() && sensor.setSamplingRate(kSamplingRate)) {
    //  Serial.println("Sensor initialized");
    else {
      Serial.println("Sensor not found");
      while (1);
as:
sensor.begin() && sensor.setSamplingRate(kSamplingRate);
and added:
Wire.begin(43, 44);
inside setup.
code from: Oximeter Monitor with OLED screen and MAX30105 sensor on NodeMCU
Question is it doesn't work when removed OLED, and modified the code relatively
(Phenomenon is the S3 shown the first screen and stuck at "no_finger", actually the MAX30105 didn't on ):
void initDrawScreen(void) {
  //  display.clearDisplay();
  tft.fillScreen(TFT_BLACK);
  tft.setTextSize(1);             // Normal 1:1 pixel scale
  tft.setTextColor(TFT_WHITE);        // Draw white text
  tft.setCursor(0, 0);            // Start at top-left corner
  tft.println(F("    Taste The Code"));
  tft.println(F(""));
  tft.setCursor(5, tft.getCursorY());
  tft.setTextSize(2);
  tft.println(F("BPM  %SpO2"));
  //  display.display();
bool display_reset = true;
void displayMeasuredValues(bool no_finger, int32_t beatAvg, int32_t spo2) {
  tft.setCursor(5, 35);
  if (no_finger) {
    tft.setTextSize(2);
    tft.println(F("NO Finger            "));
  } else if (beatAvg < 30 && display_reset) {
    tft.setTextSize(2);
    tft.println(F("Pls.  Wait             "));
    display_reset = false;
  } else if (beatAvg >= 30) {
    tft.setTextSize(2);
    tft.println(F("             "));
    tft.setTextSize(3);
    tft.print(beatAvg);
    tft.print(F(" "));
    if (spo2 >= 20 && spo2 <= 100) {
      tft.print(spo2);
      tft.print(F("--"));
the code for OLED:
#include <MAX3010x.h>
#include <Adafruit_SSD1306.h>
#include "filters.h"
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Sensor (adjust to your sensor type)
MAX30105 sensor;
const auto kSamplingRate = sensor.SAMPLING_RATE_400SPS;
const float kSamplingFrequency = 400.0;
// Finger Detection Threshold and Cooldown
const unsigned long kFingerThreshold = 10000;
const unsigned int kFingerCooldownMs = 500;
// Edge Detection Threshold (decrease for MAX30100)
const float kEdgeThreshold = -2000.0;
// Filters
const float kLowPassCutoff = 5.0;
const float kHighPassCutoff = 0.5;
// Averaging
const bool kEnableAveraging = true;
const int kAveragingSamples = 5;
const int kSampleThreshold = 5;
  delay(5000);
  Serial.println("ESP32_MAX30102_OLED_gd_S3_2!");
  Wire.begin(43, 44); //SDA, SCL
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    while (1);
  /*  //if (sensor.begin() && sensor.setSamplingRate(kSamplingRate)) {
    else {
      while (1);
  initDrawScreen();
// Filter Instances
LowPassFilter low_pass_filter_red(kLowPassCutoff, kSamplingFrequency);
LowPassFilter low_pass_filter_ir(kLowPassCutoff, kSamplingFrequency);
HighPassFilter high_pass_filter(kHighPassCutoff, kSamplingFrequency);
Differentiator differentiator(kSamplingFrequency);
MovingAverageFilter<kAveragingSamples> averager_bpm;
MovingAverageFilter<kAveragingSamples> averager_r;
MovingAverageFilter<kAveragingSamples> averager_spo2;
// Statistic for pulse oximetry
MinMaxAvgStatistic stat_red;
MinMaxAvgStatistic stat_ir;
// R value to SpO2 calibration factors
// See https://www.maximintegrated.com/en/design/technical-documents/app-notes/6/6845.html
float kSpO2_A = 1.5958422;
float kSpO2_B = -34.6596622;
float kSpO2_C = 112.6898759;
// Timestamp of the last heartbeat
long last_heartbeat = 0;
// Timestamp for finger detection
long finger_timestamp = 0;
bool finger_detected = false;
// Last diff to detect zero crossing
float last_diff = NAN;
bool crossed = false;
long crossed_time = 0;
  auto sample = sensor.readSample(1000);
  float current_value_red = sample.red;
  float current_value_ir = sample.ir;
  // Detect Finger using raw sensor value
  if (sample.red > kFingerThreshold) {
    if (millis() - finger_timestamp > kFingerCooldownMs) {
      finger_detected = true;
  else {
    // Reset values if the finger is removed
    differentiator.reset();
    averager_bpm.reset();
    averager_r.reset();
    averager_spo2.reset();
    low_pass_filter_red.reset();
    low_pass_filter_ir.reset();
    high_pass_filter.reset();
    stat_red.reset();
    stat_ir.reset();
    finger_timestamp = millis();
  if (finger_detected) {
    displayMeasuredValues(false, 0, 0);
    current_value_red = low_pass_filter_red.process(current_value_red);
    current_value_ir = low_pass_filter_ir.process(current_value_ir);
    // Statistics for pulse oximetry
    stat_red.process(current_value_red);
    stat_ir.process(current_value_ir);
    // Heart beat detection using value for red LED
    float current_value = high_pass_filter.process(current_value_red);
    float current_diff = differentiator.process(current_value);
    // Valid values?
    if (!isnan(current_diff) && !isnan(last_diff)) {
      // Detect Heartbeat - Zero-Crossing
      if (last_diff > 0 && current_diff < 0) {
        crossed = true;
        crossed_time = millis();
      if (current_diff > 0) {
        crossed = false;
      // Detect Heartbeat - Falling Edge Threshold
      if (crossed && current_diff < kEdgeThreshold) {
        if (last_heartbeat != 0 && crossed_time - last_heartbeat > 300) {
          // Show Results
          int bpm = 60000 / (crossed_time - last_heartbeat);
          float rred = (stat_red.maximum() - stat_red.minimum()) / stat_red.average();
          float rir = (stat_ir.maximum() - stat_ir.minimum()) / stat_ir.average();
          float r = rred / rir;
          float spo2 = kSpO2_A * r * r + kSpO2_B * r + kSpO2_C;
          if (bpm > 50 && bpm < 250) {
            // Average?
            if (kEnableAveraging) {
              int average_bpm = averager_bpm.process(bpm);
              int average_r = averager_r.process(r);
              int average_spo2 = averager_spo2.process(spo2);
              // Show if enough samples have been collected
              if (averager_bpm.count() >= kSampleThreshold) {
                Serial.print("Time (ms): ");
                Serial.println(millis());
                Serial.print("Heart Rate (avg, bpm): ");
                Serial.println(average_bpm);
                Serial.print("R-Value (avg): ");
                Serial.println(average_r);
                Serial.print("SpO2 (avg, %): ");
                Serial.println(average_spo2);
                displayMeasuredValues(false, average_bpm, average_spo2);
            else {
              Serial.print("Heart Rate (current, bpm): ");
              Serial.println(bpm);
              Serial.print("R-Value (current): ");
              Serial.println(r);
              Serial.print("SpO2 (current, %): ");
              Serial.println(spo2);
              displayMeasuredValues(false, bpm, spo2);
          // Reset statistic
          stat_red.reset();
          stat_ir.reset();
        crossed = false;
        last_heartbeat = crossed_time;
    last_diff = current_diff;
    displayMeasuredValues(true, 0, 0);
  display.setTextSize(1);             // Normal 1:1 pixel scale
  display.setTextColor(WHITE);        // Draw white text
  display.setCursor(0, 0);            // Start at top-left corner
  display.println(F("    Taste The Code"));
  display.println(F(""));
  display.setCursor(5, display.getCursorY());
  display.setTextSize(2);
  display.println(F("BPM  %SpO2"));
  display.display();
  display.setCursor(5, 35);
  display.setTextColor(WHITE, BLACK);
  if (no_finger) {
    display.println(F("NO Finger            "));
    display.display();
    display.println(F("Pls.  Wait             "));
    display.display();
    display.println(F("             "));
    display.setTextSize(3);
    display.print(beatAvg);
    display.print(F(" "));
      display.print(spo2);
      display.print(F("--"));
    display.display();
filters.h:
#ifndef FILTERS_H
#define FILTERS_H
 * @brief Statistic block for min/nax/avg
class MinMaxAvgStatistic {
 float min_;
 float max_;
 float sum_;
 int count_;
public:
  * @brief Initialize the Statistic block
 MinMaxAvgStatistic() :
  min_(NAN),
  max_(NAN),
  sum_(0),
  count_(0){}
  * @brief Add value to the statistic
 void process(float value) {
  min_ = isnan(min_) ? value : min(min_, value);
  max_ = isnan(max_) ? value : max(max_, value);
  sum_ += value;
  count_++;
  * @brief Resets the stored values
 void reset() {
  min_ = NAN;
  max_ = NAN;
  sum_ = 0;
  count_ = 0;
  * @brief Get Minimum
  * @return Minimum Value
 float minimum() const {
  return min_;
  * @brief Get Maximum
  * @return Maximum Value
 float maximum() const {
  return max_;
  * @brief Get Average
  * @return Average Value
 float average() const {
  return sum_/count_;
 * @brief High Pass Filter
class HighPassFilter {
 const float kX;
 const float kA0;
 const float kA1;
 const float kB1;
 float last_filter_value_;
 float last_raw_value_;
public:
  * @brief Initialize the High Pass Filter
  * @param samples Number of samples until decay to 36.8 %
  * @remark Sample number is an RC time-constant equivalent
 HighPassFilter(float samples) :
  kX(exp(-1/samples)),
  kA0((1+kX)/2),
  kA1(-kA0),
  kB1(kX),
  last_filter_value_(NAN),
  last_raw_value_(NAN){}
  * @param cutoff Cutoff frequency
  * @pram sampling_frequency Sampling frequency
 HighPassFilter(float cutoff, float sampling_frequency) :
  HighPassFilter(sampling_frequency/(cutoff*2*PI)){}
  * @brief Applies the high pass filter
 float process(float value) {
  if(isnan(last_filter_value_) || isnan(last_raw_value_)) {
   last_filter_value_ = 0.0;
  else {
    kA0 * value
    + kA1 * last_raw_value_
    + kB1 * last_filter_value_;
  last_raw_value_ = value;
  return last_filter_value_;
 void reset() {
  last_raw_value_ = NAN;
  last_filter_value_ = NAN;
 * @brief Low Pass Filter
class LowPassFilter {
 const float kX;
 const float kA0;
 const float kB1;
 float last_value_;
public:
  * @brief Initialize the Low Pass Filter
 LowPassFilter(float samples) :
  kA0(1-kX),
  kB1(kX),
  last_value_(NAN){}
 LowPassFilter(float cutoff, float sampling_frequency) :
  LowPassFilter(sampling_frequency/(cutoff*2*PI)){}
  * @brief Applies the low pass filter
  if(isnan(last_value_)) {
   last_value_ = value;
  else {
   last_value_ = kA0 * value + kB1 * last_value_;
  return last_value_;
 void reset() {
  last_value_ = NAN;
 * @brief Differentiator
class Differentiator {
 const float kSamplingFrequency;
 float last_value_;
public:
  * @brief Initializes the differentiator
 Differentiator(float sampling_frequency) :
  kSamplingFrequency(sampling_frequency),
  last_value_(NAN){}
  * @brief Applies the differentiator
   float diff = (value-last_value_)*kSamplingFrequency;
   return diff;
 void reset() {
  last_value_ = NAN;
 * @brief MovingAverageFilter
 * @tparam buffer_size Number of samples to average over
template<int kBufferSize> class MovingAverageFilter {
 int index_;
 int count_;
 float values_[kBufferSize];
public:
  * @brief Initalize moving average filter
 MovingAverageFilter() :
  index_(0),
  count_(0){}
  * @brief Applies the moving average filter
   // Add value
   values_[index_] = value;
   // Increase index and count
   index_ = (index_ + 1) % kBufferSize;
   if(count_ < kBufferSize) {
    count_++;
   // Calculate sum
   float sum = 0.0;
   for(int i = 0; i < count_; i++) {
     sum += values_[i];
   // Calculate average
   return sum/count_;
 void reset() {
  index_ = 0;
  count_ = 0;
  * @brief Get number of samples
  * @return Number of stored samples
 int count() const {
  return count_;
#endif // FILTERS_H
output ERROR:
@shanren - You have been submitting requests long enough to know that you must post your entire code, not just parts of it, post your entire error report, not just parts of it, and post a wiring diagram with an understandable description of what your project is expected to do versus your observations and problems.
here is the modified code:
same filters.h
#include <TFT_eSPI.h>
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI();
//Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
MAX30105 sensor;
// Filters
// Averaging
   tft.init();
  tft.setRotation(1);
  tft.setTextSize(1);
  tft.setTextColor(TFT_GREEN);
  tft.print("ADAM-DIY");
  delay(2000);
  delay(5000);
  //display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  /*  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
      while (1);
    else {
      while (1);
  initDrawScreen();
// Filter Instances
  else {
    averager_r.reset();
    stat_red.reset();
    stat_ir.reset();
    // Valid values?
        crossed = true;
        crossed = false;
          // Show Results
            // Average?
            else {
              Serial.println(r);
          // Reset statistic
          stat_red.reset();
          stat_ir.reset();
        crossed = false;
  tft.println(F(""));
  tft.setTextSize(2);
//bool display_reset = true;
  if (no_finger) {
    tft.setTextSize(2);
   // display_reset = true;
  } ///else if (beatAvg < 30 && display_reset) {
  else if (beatAvg < 30) {
    tft.setTextSize(2);
  ///  display_reset = false;
    tft.setTextSize(2);
    tft.setTextSize(3);
    tft.print(beatAvg);
    tft.print(F(" "));
      tft.print(spo2);
      tft.print(F("--"));
What is the full error?
no error.
Post #3 code does not compile.
What is S3?
I got it compiled.
S3 = T-Display S3, sorry didn't say it.
The libraries in my library folder:
SparkFun_MAX3010x_Pulse_and_Proximity_Sensor_Library-1.1.2
MAX3010x-Sensor-Library-main
You did not get the code in post #3 to compile.
What do you mean?
My mistake. Your code compiles. I pasted poorly and deleted lines.
