The texts displayed on TFT LCD screen are more than expected
Hi all,
I'm working on a project reading the illuminance values from a light meter and display it in real time. When displaying the illuminance value on Serial Monitor, I stored the received data from the light meter into an array and then read the part of the array I needed(only need illumiance) using 'for' loop. It works well. As shown in the serial monitor results below, only the 685.5 is the value that I what.
Serial Monitor Result:
I received: 685.5   lux
However, when I try to use the TFTscreen.text() function to display the illuminance value on the TFT screen, the displayed information is more than what I wanted because in addition to illuminance value, it also includes other data( 685.5 .3961 ). I defined a new array called luxChars[5] and then store the data from receivedChars[6~10] into luxChars[5], which is used in the TFTscreen.text() function to print the value on the TFT screen. Even though the size of luxchars array is only 5, the displayed characters are much more than 5. So does anyone know how to fix this?
Here is my code:
#include <SPI.h>
#include <TFT.h>
#define cs   10   //pin defintion for Arduino
#define dc   9
#define rst  8
TFT TFTscreen = TFT(cs, dc, rst);
char receivedChars[13];
char luxChars[5];
  Serial1.begin(9600,SERIAL_7E1); //according to the light meter communication method
  TFTscreen.begin();
  TFTscreen.background(0, 0, 0);
  TFTscreen.stroke(255, 255, 255);
  TFTscreen.setTextSize(1);
  TFTscreen.text("Illuminance:\n ", 35, 10);
  LuxReading(); //Call LuxReading
  delay(500);  // if I delete this delay code, it won't work. So it seems it takes some time to receive the data
  TFTscreen.text(luxChars, 40, 30);
  delay(250);
  TFTscreen.stroke(0, 0, 0);
void LuxReading()  //Lux Reading Function
  int ndx = 0;  //variable for receivedChars array
  int a = 0;    //variable for luxChars array
  while (Serial1.available() > 0) //when press the D-OUT button of the light meter, read data
    char c = Serial1.read();  // store received data into array
    if (c != '\n')
      receivedChars[ndx] = c;
      ndx++;
       Serial.print("I received: ");  // print received data on serial monitor
       for (int i=6; i<=10; i++)
       Serial.print(receivedChars[i]);
       luxChars[a] = receivedChars[i];
       a++;
       a = 0;
       Serial.println(" lux");  // print illuminance unit
Thanks in advance.
Hi Delta,
Thank you for your reply. I changed the array size to be 6 but it still doesn't work.
The texts displayed on the TFT screen are still redundant.
Hi Delta,
It's fixed after putting 0 at the last position. Thank you so much.
But I'm still confused why the redundant information was printed. I didn't store any data after array[5], how can it print the data that wasn't even stored in the array?
