the time for DS3231 froze on one value 19-36-5 it is not moving
the time for DS3231 froze on one value 19-36-5 it is not moving I read in one of the answers in the forum to a different question to change the halt in the serial monitor, there is no halt there can anyone help, thanks.
post your code
#include <Wire.h>
#include <DS3231.h>
#include <Wire.h> // For the i2c devices
#include <LiquidCrystal_I2C.h> // For the LCD
LiquidCrystal_I2C lcd(0x27,20,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define DS3231_I2C_ADDRESS 104 // RTC is connected, address is Hex68 (Decimal 104)
// SCL - pin A5
// SDA - pin A4
// To set the clock, run the sketch and use the serial monitor.
// Enter T1124154091014; the code will read this and set the clock. See the code for full details.
byte seconds, minutes, hours, day, date, month, year;
char weekDay[4];
byte tMSB, tLSB;
float my_temp;
char my_array[100]; // Character array for printing something.
char my_array1[100]; // character arry for date
Wire.begin();
lcd.init(); // initialize the lcd
watchConsole();
get3231Date();
Serial.print(weekDay); Serial.print(", "); Serial.print(date, DEC); Serial.print("/"); Serial.print(month, DEC);
Serial.print("/"); Serial.print(year, DEC); Serial.print(" - ");
Serial.print(hours, DEC); Serial.print(":"); Serial.print(minutes, DEC); Serial.print(":"); Serial.print(seconds, DEC);
my_temp = (float)get3231Temp();
Serial.print(" - Temp: ");
Serial.println(my_temp);
// NOTE: Arduino does NOT implement printing floats to a string.
// If you use the std C function : sprintf(my_array, "Temp: %4.2f", my_temp), It will NOT CONVERT.
// So I abandoned this, since I don't need to print the float to the LCD anyway.
sprintf(my_array, "Time: %d-%d-%d", hours, minutes, seconds);
sprintf(my_array1, "Date: %d-%d-%d", day, month, year);
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Hello World");
lcd.setCursor(0,1);
lcd.print(my_array);
lcd.setCursor(0,2);
lcd.print(my_array1);
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
void watchConsole()
if (Serial.available()) { // Look for char in serial queue and process if found
if (Serial.read() == 84) { //If command = "T" Set Date
set3231Date();
get3231Date();
Serial.println(" ");
void set3231Date()
//T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year)
//T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99)
//Example: 02-Feb-09 @ 19:57:11 for the 3rd day of the week -> T1157193020209
// T1124154091014
seconds = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
minutes = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
hours = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
day = (byte) (Serial.read() - 48);
date = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
month = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
year = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0x00);
Wire.write(decToBcd(seconds));
Wire.write(decToBcd(minutes));
Wire.write(decToBcd(hours));
Wire.write(decToBcd(day));
Wire.write(decToBcd(date));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.endTransmission();
void get3231Date()
// send request to receive data starting at register 0
Wire.beginTransmission(DS3231_I2C_ADDRESS); // 104 is DS3231 device address
Wire.write(0x00); // start at register 0
Wire.requestFrom(DS3231_I2C_ADDRESS, 7); // request seven bytes
if(Wire.available()) {
seconds = Wire.read(); // get seconds
minutes = Wire.read(); // get minutes
hours = Wire.read(); // get hours
day = Wire.read();
date = Wire.read();
month = Wire.read(); //temp month
year = Wire.read();
seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111)); // convert BCD to decimal
minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111)); // convert BCD to decimal
hours = (((hours & B00110000)>>4)*10 + (hours & B00001111)); // convert BCD to decimal (assume 24 hour mode)
day = (day & B00000111); // 1-7
date = (((date & B00110000)>>4)*10 + (date & B00001111)); // 1-31
month = (((month & B00010000)>>4)*10 + (month & B00001111)); //msb7 is century overflow
year = (((year & B11110000)>>4)*10 + (year & B00001111));
else {
//oh noes, no data!
switch (day) {
case 1:
strcpy(weekDay, "Sun");
case 2:
strcpy(weekDay, "Mon");
case 3:
strcpy(weekDay, "Tue");
case 4:
strcpy(weekDay, "Wed");
case 5:
strcpy(weekDay, "Thu");
case 6:
strcpy(weekDay, "Fri");
case 7:
strcpy(weekDay, "Sat");
float get3231Temp()
float temp3231;
//temp registers (11h-12h) get updated automatically every 64s
Wire.write(0x11);
Wire.requestFrom(DS3231_I2C_ADDRESS, 2);
tMSB = Wire.read(); //2's complement int portion
tLSB = Wire.read(); //fraction portion
temp3231 = (tMSB & B01111111); //do 2's math on Tmsb
temp3231 += ( (tLSB >> 6) * 0.25 ); //only care about bits 7 & 8
else {
//oh noes, no data!
return temp3231;
You check Serial.available() once, then charge away and Serial.read() dozens of characters. How do you know that any characters after the first one are available?
Please read these two posts:
General Guidance and How to use the Forum
and
Read this before posting a programming question ...
You may also find useful information that would answer your question here:
Useful links - check here for reference posts / tutorials
You have posted code without using code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons. The "Code: [Select]" feature allows someone to select the entire sketch so it can be easily copied and pasted into the IDE for testing or review.
If you have already posted without using code tags, open your message and select "modify" from the pull down menu labelled, "More", at the lower right corner of the message. Highlight your code by selecting it (it turns blue), and then click on the "</>" icon at the upper left hand corner. Click on the "Save" button. Code tags can also be inserted manually in the forum text using the code and /code metatags.
thank you for the advice.
Please edit your post to add code tags.
shawkat123:
You're welcome. Did it work?
