The Ultimate Altimeter - A super-compact, DIY altimeter for RC planes and more
Hey guys! I just made this Arduino powered Altimiter for RC planes, quadcopters, rockets, and other flying devices. Check it out!
http://tinyurl.com/UAInstructable
Neat!
Have you tried driving around with it to see how accurate it is?
CrossRoads:
Since the altitude is measured by air pressure, the absolute height can sometimes be a little off (it would be a tad different depending on weather), but the relative height (diFF) mode should be accurate. I haven't tried doing super-accurate comparison tests yet, but around my area it measures around 900 feet, which is correct, and I went to Boston and it measured around sea level, which also seems right. It is a pretty good quality sensor, so I expect that it is accurate. :slight_smile:
Is there a way to enter barometric pressure to correct for air pressure differences?
Standard atmospheric pressure & temperature is 29.92 & 59F, any variation from that affects the air-pressure alone altitude.
Not that I know of, but the effect of weather on the altitude shouldn’t throw it off that much. Here are some things I found:
(From a datasheet I think)
(From the Sparkfun page for the sensor)
Hope this helps!
You get altitude from a GPS module also :slight_smile:
Why did you use a LED display?
They draw loads of power compared to an LCD like the Nokia display.
Nice project anyways :slight_smile:
janost:
The biggest constraints were space and weight. The seven segment Bubble Display was super tiny and feather light, and that's what I was looking for. Also all we needed were 4 digits, not a 48x84 pixel screen.
Thanks!
