The value of "data" can not be averaged. How do this?
https://bitbucket.org/itiadasm/ldc16xx_lib-arduino/src/master/examples/LDC16xx_example.ino
I used this example from particular library to measure inductance of a coil from a TI device. But I could not averaged that. Any loop does not implement for the part which above from "data" observing. I do not have deep C knowledge. If anyone know solution for this, please tell me.
Thank you.
Add the value of data to the total each time that it is read and divide the total by the number of readings to get the average
The OP's code
[code] /**
  • File Name          : LDC1614_example
  • Description        : Example program for LDC16xx_lib ******************************************************************************
  • Copyright (c) 2018 CNR-STIIMA DASM Group
  • All rights reserved.
  • Redistribution and use in source and binary forms, with or without modification,
  • are permitted provided that the following conditions are met: *
  • 1. Redistributions of source code must retain the above copyright notice,
  •    this list of conditions and the following disclaimer.
  • 2. Redistributions in binary form must reproduce the above copyright notice,
  •    this list of conditions and the following disclaimer in the documentation
  •    and/or other materials provided with the distribution.
  • 3. The name of the author may not be used to endorse or promote products
  •    derived from this software without specific prior written permission. *
  • THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
  • WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  • MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
  • SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  • EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
  • OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
  • INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
  • CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
  • IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
  • OF SUCH DAMAGE. *
  • Credits go to Jeremi Wójcicki (and the current maintainers) of this software. * **/
include "LDC16xx_lib.h"
// user selecatable comppile option // 0 - use user polling to read sensor data // 1 - use syncronized sensor read with INTB pin interrupt
define IRQ_HANDLER 0
// single channel conversion setup with disabled INTB by default LDC_configReg default_config[] = {  { LDC16xx_MUX_CONFIG,           LDC16xx_BITS_DEGLITCH_3_3Mhz },  { LDC16xx_CONFIG,               LDC16xx_BITS_ACTIVE_CHAN_CH0 | LDC16xx_BITS_AUTO_AMP_DIS | LDC16xx_BITS_INTB_DIS },  { LDC16xx_SETTLECOUNT_CH0,      0x0050 },  { LDC16xx_RCOUNT_CH0,           0xffff }, };
define LDC_CONFIG_SIZE sizeof(default_config)/sizeof(LDC_configReg)
// global sensor object pointer LDC16xx *ldc;
// an ISR control flag for pending sensor data volatile bool drdy = 0;
// interrupt service routine - when sensor conversion is complete // this code should be light not to block the main loop for too long void onDataReady(){  drdy = true; }
void setup() {  // put your setup code here, to run once:
 Serial.begin(115200);  Serial.println("Starting execution ...");
 // create a new LDC sensor object, initialize interface  // I2C clock of 100kHz or 400kHz is allowed  ldc = new LDC16xx(Wire, 400000);
 // verify chip ID. On fail halt program  uint16_t id, manuf;  ldc->readRegister(LDC16xx_DEVICE_ID, &id);  ldc->readRegister(LDC16xx_MANUFACTURER_ID, &manuf);
 Serial.print("Chip ID: 0x");  Serial.println(id, HEX);  Serial.print("Manufacturer ID: 0x");  Serial.println(manuf,HEX);      if(id == LCD16xx_DEFAULT_DEVICE_ID && manuf == LDC16xx_DEFAULT_MANUFACTURER_ID){    Serial.println("Verification OK");  } else {    Serial.println("Wrong chip or manufacturer ID, stopping execution...");    while(1);  }
 // reset device wiping previous configuration  ldc->resetDevice();
 // load our config  ldc->loadConfig(default_config, LDC_CONFIG_SIZE);
if IRQ_HANDLER == 1
 // attach IRQ and set appropriate LDC registers to enable INTB interrupt  // depending on used board consult https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/ for possible pin configurations  // user pin 2 for INTB  ldc->enableDataReadyInterrupt(2, onDataReady);
endif
 // for debug, dump values of all register to the console  ldc->registerDump(Serial);
// main loop void loop() {
if IRQ_HANDLER == 1
   while(!drdy);      drdy = false;
endif
     uint32_t data;    uint16_t status;
   // read the channel no 0. data    ldc->readChannel(0, &data);
if IRQ_HANDLER == 1
   // in IRQ mode status must be read to re-enable conversion and re-assert INTB    ldc->readRegister(LDC16xx_STATUS, &status);
endif
   // print read data in the console    Serial.println(data, DEC);
if IRQ_HANDLER == 0
   // we time the loop by ourselves (optionally we could ask the chip periodically for status)    // ideally you should make sure we are syncronized with sensor conversion rate (RCOUNT + clock source)    delay(24); // ~41.5 sps
endif
} [/code]
...R
