THE ZERO AND RS485
I have a fully working set of Master/Slave sketch for RS485 Communications between two UNOS, using the standard MAX 485 Modems. Here below is a simplified Master sketch. Is there a charitable soul that can give me the mods to the sketch to make it work with a Zero Master? I would still use a UNO as Slave.
#include <SoftwareSerial.h>
//DECLARE CONSTANTS -
#define SSerialRX        7 //Serial Receive pin.
#define SSerialTX        8  //Serial Transmit pin.
#define SSerialTxControl 2  //Serial RS485 Rx/TX command pin.
#define RS485Transmit    HIGH // When Pin 2 HIGH, Transmit.
#define RS485Receive     LOW // When Pin 2 LOW, Receive.
//DECLARE OBJECTS
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); //Software Comms RX & TX
//DECLARE VARIABLES
//Operating Variables
int synComm; //Sync byte generated by the Master and sent to the Slave.
int syncRec; //Sync byte read by the Slave and sent back to the Master for verification.
unsigned long k = 0; //Number of Iterations: set below.
int t = 0; //Recycle time: set below.
int inByte = 0; //Used in the SWITCH Command.
//Inputs
int sensorValue_0; //Sensor value received from the Slave.
int Vy0 = 0; //Float variable for Sensor value received from Slave.
//outputs
const int analogOutPin1 = 3; //Outputs sensorValue_0 in Analogue form.
int powerPin = 4; // Used for command of external local device.
//SETTING UP
  Serial.begin(115200);//Starts (USB) Serial Port & sets Data Rate.
  //SETTINGS: These constants to be set up prior to switch-on.
  k = 100;  //SET NUMBER OF ITERATIONS AT k
  t = 1000; //SET RECYCLE TIME, e.g. 1000 = 1 sec.
  delay(200); //This delay gives time to Serial to turn-on & print labels following.
  Serial.println("=========RS485 DrDAQ DATA COMMUNICATIONS=========");
  Serial. println("===Stand-By/Reset = a; Start = b; press RESET to Stop===");
  Serial.print("              ITERATION SETTING =  ");
  Serial.println(k);
  delay(10);
  pinMode(powerPin, OUTPUT); // Sets Digital Pin 4 as output.
  digitalWrite(powerPin, LOW); //Initially sets power Pin LOW.
  pinMode(SSerialTxControl, OUTPUT); //Sets Digital Pin 2 as output.
  digitalWrite(SSerialTxControl, RS485Receive); //Initial setting of Pin 2: LOW for receive.
  RS485Serial.begin(28800); //Starts software RS485 Serial Port & sets Data Rate.
//OPERATION
  if (Serial.available() > 0) // The Byte written in Serial Monitor starts System: see cases "a" & "b" below.
     int inByte = Serial.read(); // Byte written in Serial Monitor
     switch (inByte)              // Switch operator selects alternative cases "a" or "b".
    case 'a': // Slave reset & System St-By.
        digitalWrite(4, LOW); //power Pin confirmed LOW in Stand-By.
        synComm = 111;
        Serial.println("=========RS485 SIX CHANNEL PICO DATA COMMUNICATIONS=========");
        Serial.println("======RESET TO SLAVE // SLAVE READY // SYSTEM IN ST-BY======");
        digitalWrite(SSerialTxControl, RS485Transmit); //Sets TX/RX control HIGH to transmit.
        delay(20);
        RS485Serial.write(synComm); //Sends the Sync Byte to Slave.
        delay(300);
        delay(300);
    case 'b': // System operation.
    for (int i = 0; i < k; i++) //This is the iteration counter: number of iterations = K.
     synComm = 123; // This is the Sync byte sent to the Slave for control.If Sync Byte received is not "123", system does not start.
     float R = (t);  // Calculates recycle time in mSeconds.
     int S = (R * (k) / 60000); // Calculates total data acquisition time.
     delay(t);
    // We are in RX condition: now we transmit the Sync Byte to the Slave to start the System.
        digitalWrite(SSerialTxControl, RS485Receive); //Sync Byte sent, now we seek data from Slave, RX/TX to receive.
        if (RS485Serial.available()>0) // System carries on if it received data from the Slave.
          syncRec = RS485Serial.read(); //Reads the Sync Byte sent back from the Slave as a check.
           if(syncRec == synComm)
             digitalWrite(powerPin, HIGH); //Turns power Pin on for external device command.
             sensorValue_0 = RS485Serial.read(); //Reads the sensor data (Value_0) of Channel 0 sent by the Slave in 8 bit format 0-255.
             analogWrite(analogOutPin1, sensorValue_0); // Writes Value_0 to output Pin 1 IN ANALOGUE format as PWM's duty Cycle.
             float Vy0 = (sensorValue_0 * 19.8039); // Converts Value_0 to Analogue format to display on Serial Monitor.
             Serial.print("SLAVE CHANNEL/0 = ");
             Serial.print(sensorValue_0);
             Serial.print("  -  mV ");
             Serial.println(Vy0);
             delay(200);
              Serial.println("ALARM - ERROR OR NO CONNECTION TO SLAVE");
              delay(2000);
              exit(0);
       } //End of Iteration - Iteration re-starts.
I reply to myself:
The modified sketch for RS485 COMMS using ARDUINO/GENUINO ZERO should look like this (based on Lady Ada work):
#include <Arduino.h>
#include"wiring_private.h"
Uart Serial2(&sercom1, 11, 10, SERCOM_RX_PAD_0,UART_TX_PAD_2); //PIN 11 RX - PIN 10 TX
void SERCOM1_Handler()
 Serial2.IrqHandler();
#define SSerialRX        11 //Serial Receive pin.
#define SSerialTX        10  //Serial Transmit pin.
//DECLARE VARIABLES
//Inputs
//outputs
//SETTING UP
  Serial.begin  (115200);
  Serial2.begin(115200);
  //SERCOM WORKS ON PINS 10 AND 11
  pinPeripheral(10, PIO_SERCOM);
  pinPeripheral(11, PIO_SERCOM);
  Serial.println("=========RS485 DATA COMMUNICATIONS=========");
  Serial.println(k);
  delay(10);
//OPERATION
  if (Serial.available() > 0) // This Byte in Serial Monitor starts System: see cases "a" & "b" below.
        synComm = 111;
        Serial.println("======RS485 SIX CHANNEL PICO DATA COMMUNICATIONS=======");
        delay(20);
        Serial2.write(synComm); //Sends the Sync Byte to Slave.
        delay(300);
        delay(300);
          delay(t);
        digitalWrite(SSerialTxControl, RS485Receive); //Sync Byte sent, now we seek data from Slave.
        if (Serial2.available()>0) // System carries on if it received data from the Slave.
           syncRec = Serial2.read(); //Reads the Sync Byte sent back from the Slave as a check.
             sensorValue_0 = Serial2.read(); //Reads the sensor data of Channel 0 sent by the Slave.
             analogWrite(analogOutPin1, sensorValue_0); // Writes Value_0 to output Pin 1 as PWM.
             float Vy0 = (sensorValue_0 * 19.8039); // Converts Value_0 to Analogue format for S.M.
             delay(200);
                delay(2000);
                exit(0);
Here below complete, working and tested RS485 DEMO sketches for one ARDUINO ZERO MASTER and an ARDUINO UNO SLAVE. Adding onto this basis it is possible to implement RS485 COMMS with 10 Bit input (ANALOGUE)/output(PWM) resolution.
sketch_RS485_ZERO_MASTERDEMO.ino (1.73 KB)
sketch_RS485_UNO_SLAVEDEMO.ino (1.23 KB)
