First, I am not a developper, and I am French so sorry for my English.
I am doing my first project with Arduino Yun Mini.
I try to put some leds on a trolley, and control these leds by wifi.
It works. The electronic part is ok, and the code also.
But I want to make a little modification, and I am not able to do it.
I want to use the "Theatre Style Crawling lights" effect, but it need to do it until there is a new ordre from the web interface.
I try to use "Do...While" and "While" instruction, but when I do than, my web server is dead.
Do you avec any idea?
My code:
Arduino YUN Put-to-light
* "/arduino/digital/1" -> switch On BIN 1
* "/arduino/digital/2" -> switch On BIN 2
* "/arduino/digital/3" -> switch On BIN 3
* "/arduino/digital/4" -> switch On BIN 4
* "/arduino/digital/5" -> switch On BIN 5
* "/arduino/digital/6" -> switch On BIN 6
* "/arduino/digital/7" -> switch On BIN 7
* "/arduino/digital/8" -> switch On BIN 8
* "/arduino/digital/9" -> switch On BIN 9
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
int NewRequest;
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
// Listen to the default port 5555, the Yún webserver
// will forward there all the HTTP requests you send
YunServer server;
// Bridge startup
Bridge.begin();
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.listenOnLocalhost();
server.begin();
strip.begin();
theaterChase(0, strip.numPixels(),strip.Color(127, 127, 127), 50); // White
blackout();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "ptl") {
ptlCommand(client);
void ptlCommand(YunClient client) {
int bin;
// Read bin number
bin = client.parseInt();
blackout();
switch (bin) {
case 1:
theaterChase(0,10,strip.Color(0,255,0),50); //Bin 1 green
case 2:
theaterChase(12,18,strip.Color(255,0,0),50); //Bin 2 red
case 3:
theaterChase(20,26,strip.Color(0,0,255),50); //Bin 3 blue
case 4:
theaterChase(20,26,strip.Color(255,255,0),50); //Bin 4 yelow
case 5:
theaterChase(27,33,strip.Color(255,0,0),50); //Bin 5 red
case 6:
theaterChase(35,41,strip.Color(255,0,0),50); //Bin 6 red
case 7:
theaterChase(42,48,strip.Color(255,255,0),50); //Bin 7 yelow
case 8:
theaterChase(42,48,strip.Color(0,0,255),50); //Bin 8 Blue
case 9:
theaterChase(49,60,strip.Color(0,255,0),50); //Bin 9 green
default:
Lighton(0,strip.numPixels(),strip.Color(255,0,0),50); //Error
// Send feedback to client
client.print(F("Bin "));
client.print(bin);
void blackout()
for (int i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i,0,0,0);
strip.show();
void Lighton(int firstled, int lastled,uint32_t c, uint8_t wait)
for (int i=firstled; i<lastled; i++) {
strip.setPixelColor(i,c);
strip.show();
//Theatre-style crawling lights.
void theaterChase(int firstled, int lastled,uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (int i=firstled; i < lastled; i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
for (int i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, 0); //turn every third pixel off
